Doosan Forklift BR13S5 BR15S5 BR18S5 Spare Parts Catalog SB1115Y
Brand: Doosan
Type of Machine: Forklift, BR 1 Ton Standing REACH, Electric Powered Truck
Model: Doosan BR 1 Ton BR13S5, BR15S5, BR18S5 Forklift
Part Number: SB1115Y
Number of Pages: 342 Pages
Section 1
Chassis Component
Wiring Gp-SME
Wiring Gp-CTS
EPS Kit
Instruments Gp-SME
Instruments Gp-CTS
Tank Gp - Hydaulic-SME
Tank Gp - Hydaulic-CTS
Lines Gp - Mast Operating
Mounting Gp - Head Guard
Mounting Gp - Reach Cylinder
Reach Cylinder Ass’y
Motor Gp - Drive-SME
Motor Gp - Drive-CTS
Motor Ass’y-SME
Motor Ass’y-CTS
Motor Gp - Hydraulic-SME
Motor Gp - Hydraulic-CTS
Motor Gp - Pump-SME
400702-00071
Lighting Gp
Control Gp - Accel
Pump Gp - Hydraulic
Pump - Hydraulic
Panel Gp - Control-SME
Panel Gp - Control-CTS
Controller Ass’y-SME
Controller Ass’y-CTS
Section 2
Power Train&Brake System
Mounting Gp - Transfer
Transfer Gp Part 1 of 2
Transfer Gp Part 2 of 2
Control Gp - Brake
Drive Wheel Mounting Gp
Load Wheel Mounting Gp-Urethane/Rubber
Caster Wheel Ass’y
Section 3
Steer Axle Gp
Handle & Linkage Gp
Section 4
Control Valve & Options
Valve Ar. - 3 Section
Valve Gp - Control - 3 Section
Valve Ar. - 4 Section
Valve Gp - Control - 4 Section
Lighting Gp - Option
Tool Gp
Connector Gp-Battery(SB Type)-Non EEC-SME
430208-00183
Connector Gp-Battery(SBE Type)-EEC-SME
Connector Gp-Battery(SBE Type)-EEC-CTS
Battery Ass’y
Charger Ass’y-Battery,Non EEC-3P-60Hz-AC 220 Volt-230AH/300AH
Charger Ass’y-Battery,Non EEC-3P-60Hz-AC 380 Volt-230AH/300AH
Charger Ass’y-Battery,Non EEC-3P-60Hz-AC 440 Volt-230AH/300AH
Charger Ass’y-Battery,Non EEC-3P-50Hz-AC 220 Volt-230AH/300AH
Charger Ass’y-Battery,Non EEC-3P-50Hz-AC 380 Volt-230AH/300AH
Charger Ass’y-Battery,Non EEC-3P-50Hz-AC 440 Volt-230AH/300AH
Charger Ass’y-Battery,Non EEC-3P-50~60Hz-AC 380 Volt-300AH
Charger Ass’y
Safety Kit Gp
Section 5
Frame & Panel Group
Panel Gp - Outer-SME
Panel Gp - Outer-CTS
Battery Bed Gp
Bed Ass’y
Battery Carrier
Location Chart-SME
Location Chart-CTS
Section 6
Mast - Hydraulic
Lift&Tilt Mounting Gp-STD
Lift&Tilt Mounting Gp-FFT
Tilt Cylinder Mounting Gp-STD
Tilt Cylinder - LH
Tilt Cylinder - RH
Tilt Cylinder Mounting Gp-FFT
Lines Gp-Attachment-Primary-4 Way-STD
Lines Gp-Attachment-Primary-4 Way-FFT
Lines Gp-Side Shifter-STD
Lines Gp-Side Shifter-FFT
Side Shifter Gp
Cylinder Gp
Section 7
Mast - Implements
Mast Gp - STD
Mast Gp - FFT
Mast Ass’y - STD
Mast Ass’y - FFT
Relay Gp - Lift - STD
Relay Gp - Lift - FFT
Mounting Gp - Reach
Carriage Ass’y-STD/FFT
Carriage Mounting Gp
Lift Gp-Secondary Cylinder-STD
Lift Gp-Secondary Cylinder-FFT
Lift Gp-Primary Cylinder-FFT
Board Ass’y
Backrest Gp
Fork Gp
Brand: Doosan
Section 1
Chassis Component
Wiring Gp-SME
Wiring Gp-CTS
EPS Kit
Instruments Gp-SME
Instruments Gp-CTS
Motor Ass’y-SME
Motor Ass’y-CTS
Motor Gp - Pump-SME
400702-00071
Lighting Gp
Control Gp - Accel
Pump Gp - Hydraulic
Pump - Hydraulic
Section 2
Control Gp - Brake
Caster Wheel Ass’y
Section 3
Steer Axle Gp
Handle & Linkage Gp
Section 4
Tool Gp
430208-00183
Battery Ass’y
Charger Ass’y
Safety Kit Gp
Section 5
Frame & Panel Group
Battery Bed Gp
Bed Ass’y
Battery Carrier
Location Chart-SME
Location Chart-CTS
Section 6
Mast - Hydraulic
Tilt Cylinder - LH
Tilt Cylinder - RH
Side Shifter Gp
Cylinder Gp
Section 7
Mast - Implements
Mast Gp - STD
Mast Gp - FFT
Mast Ass’y - STD
Mast Ass’y - FFT
Mounting Gp - Reach
Board Ass’y
Backrest Gp
Fork Gp
- DOOSAN Lift Trucks Model D20S-3, D25S-3, D30S-3, D32S-3, D33S-3 Parts Book
- DOOSAN Lift Trucks Model G20S-2, G25S-2, G30S-2 Parts Book
- DOOSAN Lift Trucks Model G35S-2, G40S-2, G45S-2, G50C-2, G40SC-2, G45SC-2, G50SC-2 Parts Book
- DOOSAN Lift Trucks Model D35S-2, D40S-2, D45S-2, D50C-2, D40SC-2, D45SC-2, D50SC-2 Parts Book
- Daewoo Lift Trucks Electric System Schematic
- Daewoo Lift Trucks G430 LP Engine Service Manual
- Doosan Forklift Service Manual G420FE LP/Dual Fuel Engine G420F LP/Gasoline Dual Fuel Engine
- Daewoo Lift Trucks Hydraulic System Schematic
- Daewoo Lift Trucks Diesel Engine 3.3 Liter (DB33A) Service Manual
- Doosan Forklift Service Manual G424FE LP/Dual Fuel Engine G424F LP Engine
- Daewoo Lift Trucks Power Train Disassembly & Assembly
- Daewoo Doosan Forklift G20S-3 G25S-3 G30S-3 Service Manual
- Doosan LIFT TRUCKS Operation & Maintenance Manual
- Daewoo Lift Trucks Vehicle Systems Specifications Systems Operation Testing & Adjusting
- Deawoo Doosan Forklift B20S-2 Operation Testing & Adjusting
