Doosan Forklift BC20S5 BC25S5 BC30S5 BC32S5 BC25SE5 Spare Parts Catalog SB1082
Brand: Doosan
Type of Machine: Forklift, Electric 2 Ton CUSHION, Electric Powered Truck
Model: Doosan BC20S5, BC25S5, BC30S5, BC32S5, BC25SE5 Forklift
Part Number: SB1082
Number of Pages: 2904 Pages
[CHASSIS] Chassis
AXLE GROUP,STEER
CYLINDER,STEERING
WEIGHT GROUP,COUNTER
BRAKE GROUP
PARKING SYSTEM
CONTROL UNIT
CYLINDER,MASTER
LINE GROUP
PANEL
HOOD GROUP
WIRING GP(80V)
PANEL,CONTROL
TANK,HYDRAULIC
PANEL ASSY
RESERVOIR ASSY
WIRING GP(36/48)
CONTROLLER ASSY
CONTROLLER GROUP,DRIVE
PUMP,GEAR
MOUNT GROUP
TOOL GROUP
TOOL GP
SPARE PARTS
ARRANGEMENT,CHANGEOVER
FLOOR
CHASSIS,36V,SME MOTOR
MODULE,BASIC
GUARD GROUP
MODULE,PERFORMANCE
ARRANGEMENT
MODULE,CAPACITY
CHASSIS,48V,SME MOTOR
CHASSIS,80V,SME MOTOR
CHANGEOVER
WIRING GP - CABIN
CYLINDER GROUP,TILT
CYLINDER ASSY,TILT
CYLINDER,TILT
MOUNTING
VALVE ASSY,PRIORITY
[CHASSIS] Driving Module
HUB ASSY
TRANSFER ASSY
HOUSING ASSY,AXLE
[CHASSIS] Electric Power
CONNECTER GROUP,BATTERY
CHARGER ASSY,BATTERY
CHARGER ASSY
CHARGER,BATTERY
CHARGER,220V,3P,50HZ,930~1100A
CHARGER,380V,3P-60HZ/440AH
CHARGER,220V,3P-60HZ/440AH
CHARGER,440V,3P,50HZ,700~770AH
CHARGER,220V,3P,50HZ,600~700AH
CHARGER,380V,3P-50HZ/740AH
CHARGER,440V,3P-60HZ/400~460AH
CHARGER,440V 3P-60HZ
CHARGER,380V 3P-60HZ
CHARGER,220V 3P-60HZ
CHARGER GP; BATTERY
BATTERY,EEC,80V,365AH
BATTERY,LOCAL,80V,365AH
BATTERY,NON EEC,48V,685AH
CHARGER,220V,3P,50HZ,360~440AH
CHARGER,220V,3P,60HZ,360~440AH
CHARGER,380V,3P,50HZ,360~440AH
CHARGER,380V,3P,60HZ,360~440AH
CHARGER,440V,3P,50HZ,380~440AH
CHARGER,440V,3P,60HZ,360~440AH
BATTERY,NON EEC,48V,750AH
BATTERY,EEC,80V,450AH
BATTERY,LOCAL,80V,450AH
BATTERY,NON EEC,48V,825AH
BATTERY,STD
BATTERY,LOCAL,36V,1050AH
BATTERY,LOCAL,36V,820AH
BATTERY ASSY
CHARGER,220V,3P,50HZ,660~770AH
CHARGER,220V,3P,50HZ,800~870AH
CHARGER,220V,3P,60HZ,740~850AH
CHARGER,380V,3P,50HZ,740~850AH
CHARGER,380V,3P,50HZ,660~770AH
CHARGER,380V,3P,60HZ,740~850AH
CHARGER,380V,3P,60HZ,930~1100A
CHARGER,220V,3P,50HZ,450~550AH
CHARGER,380V,3P,50HZ,930~1100A
CHARGER,440V,3P,50HZ,740~850AH
CHARGER,440V,3P,50HZ,660~770AH
CHARGER,440V,3P,50HZ,800~870AH
CHARGER,440V,3P,60HZ,740~850AH
CHARGER,220V,3P,60HZ,930~1100A
CHARGER,220V,3P,60HZ,450~550AH
CHARGER,440V,3P,60HZ,930~1100A
CHARGER,380V,3P,50HZ,450~550AH
CHARGER,380V,3P,60HZ450~550AH
CHARGER,440V,3P,50HZ,930~1100A
CHARGER,440V,3P,50HZ,450~550AH
CHARGER,220V 3P-60HZ/440~585AH
CHARGER,380V 3P-60HZ/440~585AH
CHARGER,440V,3P-60HZ/400~585AH
CHARGER,440V,3P,60HZ,450~550AH
CHARGER,220V,1P,60HZ,400~460AH
RETAINER
CHARGER,380V,3P-50HZ,NON EEC
MOTOR ASSY,DRIVE
MOTOR GROUP,DRIVE
MOTOR GROUP,HYDRAULIC
MOTOR ASSY,PUMP
[CHASSIS] Operating Module
TRAYGP
VALVE ARRANGEMENT
BRACKET ASSY,VALVE
SWITCH ASSY
VALVE ASSY
BRACKET ASSY
BRACKET,VALVE MOUNTING
REST,ARM
INSTRUMENT GROUP
EXTINGUISHER ASSY,FIRE
LAMP GROUP
LAMP ASSY
LAMP ASSY,HEAD
MIRROR GP
BAR
BELT GROUP,SEAT
SEAT ASSY
SEAT
SEAT GROUP
TANK GROUP,WASHER
DOOR ASSY,OPEN
DOOR ASSY,REAR
CABIN A TYPE,MODULAR
CABIN GROUP,MODULAR
COVER ASSY,REAR
CABIN ASSY
VALVE,CONTROL
COVER GROUP
FCU
STEERING GROUP
WIPER
HEATER GROUP
LAMP GP-COMB F/R,LED
INSTALLATION
HARNESS ASSY
MODULAR CABIN;SIN-HEUNG
SEAT GROUP-AMA
WIRING GROUP
SEAT BELT INTERLOCK GP
STRAP
PUMP ASSY,WATER
AUTO TILT GP.-WITH FINGERTIP
MONO-PED CONTROL-(FCU)
STROBE ASSY
LAMP
LAMP ASSY,COMBINATION
WIPER ASSY
RECEPTACLE
GRIP
CABIN,MODULAR C
FAN ASSY
FRONT COCKPIT UNIT,BASIC
SWITCH,LAMP
OVERHEAD GUARD,2108MM,83"
OVERHEAD GUARD,2210MM
GUARD ASSY,OVERHEAD
GUARD GROUP,OVERHEAD
OVERHEAD GUARD,2184MM,86"R-BAR
LIGHT GROUP
MODULAR CABIN;FINE
MIRROR
CHANGEOVER AR.
CABIN,MODULAR B
CABIN,MODULAR A
ALARM GROUP
CONNECTOR
WASHER TANK,WITHOUT HEATER
EXTINGUISHER,FIRE
KNOB-WHEEL
INSTALL
[FRONT END] Mast
PIPE ASSY
HOSE GROUP,HYDRAULIC
HOSE,HYDRAULIC
LINE GROUP,ATTACHMENT
PIPE,LINE
RELAY ASSY
SHEAVE GROUP
RELAY
LIFTER GROUP
MAST ASSY
LIFT GROUP
CYLINDER GROUP,LIFT
MAST GROUP
MOUNT GROUP,LIFT
UPRIGHT ASSY,STATIONARY
CYLINDER,SECONDARY
UPRIGHT ASSY
UPRIGHT ASSY,INNER
MAST ASSY,INTER
CYLINDER,PRIMARY
CYLINDER ASSY
MAST ARRANGEMENT
CYLINDER ASSY,LIFT
ACCUMULATOR GROUP
MERCHANDIZING
MAST
MOUNT
BEARING
ARRANGEMENT,MERCHANDISING
ACCUMULATOR
SHEAVE,HOSE
LIFT GROUP,STANDARD
LIFT ASSY
LIFT,CYLINDER
[FRONT END] Fork
FORK
FORK ASSY
FORK, ATTACHMENT
POSITIONER,FORK
FORK EXTENSION GROUP
FORK CAP
[FRONT END] Carriage
MOUNT ASSY
CYLINDER,GAS
REST,BACK
SHIFT GROUP,SIDE
SIDE SHIFTER ASSY
SHIFTER,INTEGRAL SIDE CARRIAGE
LIFT,MOVEABLE HYDRAULIC
CARRIAGE ASS'Y
LOAD BACKREST
SIDE SHIFTER
CARRIAGE ARRANGEMENT
COUPLING GROUP
REST ASSY,BACK
POSITIONER GROUP,FORK
CARRIAGE GROUP
COUPLING,QUICK
[MISCELLANEOUS] Location Chart
CHART,LOCATION
Brand: Doosan
Part Number: SB1082
[CHASSIS] Chassis
AXLE GROUP,STEER
CYLINDER,STEERING
BRAKE GROUP
PARKING SYSTEM
CONTROL UNIT
CYLINDER,MASTER
LINE GROUP
PANEL
HOOD GROUP
WIRING GP(80V)
PANEL,CONTROL
TANK,HYDRAULIC
PANEL ASSY
RESERVOIR ASSY
WIRING GP(36/48)
CONTROLLER ASSY
PUMP,GEAR
MOUNT GROUP
TOOL GROUP
TOOL GP
SPARE PARTS
FLOOR
MODULE,BASIC
GUARD GROUP
MODULE,PERFORMANCE
ARRANGEMENT
MODULE,CAPACITY
CHANGEOVER
WIRING GP - CABIN
CYLINDER GROUP,TILT
CYLINDER ASSY,TILT
CYLINDER,TILT
MOUNTING
VALVE ASSY,PRIORITY
HUB ASSY
TRANSFER ASSY
HOUSING ASSY,AXLE
CHARGER ASSY
CHARGER,BATTERY
CHARGER GP; BATTERY
BATTERY,STD
BATTERY ASSY
RETAINER
MOTOR ASSY,DRIVE
MOTOR GROUP,DRIVE
MOTOR ASSY,PUMP
TRAYGP
VALVE ARRANGEMENT
BRACKET ASSY,VALVE
SWITCH ASSY
VALVE ASSY
BRACKET ASSY
REST,ARM
INSTRUMENT GROUP
LAMP GROUP
LAMP ASSY
LAMP ASSY,HEAD
MIRROR GP
BAR
BELT GROUP,SEAT
SEAT ASSY
SEAT
SEAT GROUP
TANK GROUP,WASHER
DOOR ASSY,OPEN
DOOR ASSY,REAR
CABIN GROUP,MODULAR
COVER ASSY,REAR
CABIN ASSY
VALVE,CONTROL
COVER GROUP
FCU
STEERING GROUP
WIPER
HEATER GROUP
INSTALLATION
HARNESS ASSY
SEAT GROUP-AMA
WIRING GROUP
STRAP
PUMP ASSY,WATER
STROBE ASSY
LAMP
WIPER ASSY
RECEPTACLE
GRIP
CABIN,MODULAR C
FAN ASSY
SWITCH,LAMP
GUARD ASSY,OVERHEAD
LIGHT GROUP
MODULAR CABIN;FINE
MIRROR
CHANGEOVER AR.
CABIN,MODULAR B
CABIN,MODULAR A
ALARM GROUP
CONNECTOR
EXTINGUISHER,FIRE
KNOB-WHEEL
INSTALL
[FRONT END] Mast
PIPE ASSY
HOSE,HYDRAULIC
PIPE,LINE
RELAY ASSY
SHEAVE GROUP
RELAY
LIFTER GROUP
MAST ASSY
LIFT GROUP
CYLINDER GROUP,LIFT
MAST GROUP
MOUNT GROUP,LIFT
CYLINDER,SECONDARY
UPRIGHT ASSY
UPRIGHT ASSY,INNER
MAST ASSY,INTER
CYLINDER,PRIMARY
CYLINDER ASSY
MAST ARRANGEMENT
CYLINDER ASSY,LIFT
ACCUMULATOR GROUP
MERCHANDIZING
MAST
MOUNT
BEARING
ACCUMULATOR
SHEAVE,HOSE
LIFT GROUP,STANDARD
LIFT ASSY
LIFT,CYLINDER
[FRONT END] Fork
FORK
FORK ASSY
FORK, ATTACHMENT
POSITIONER,FORK
FORK CAP
MOUNT ASSY
CYLINDER,GAS
REST,BACK
SHIFT GROUP,SIDE
SIDE SHIFTER ASSY
CARRIAGE ASS'Y
LOAD BACKREST
SIDE SHIFTER
COUPLING GROUP
REST ASSY,BACK
CARRIAGE GROUP
COUPLING,QUICK
CHART,LOCATION
- DOOSAN Lift Trucks Model D20S-3, D25S-3, D30S-3, D32S-3, D33S-3 Parts Book
- DOOSAN Lift Trucks Model G20S-2, G25S-2, G30S-2 Parts Book
- DOOSAN Lift Trucks Model G35S-2, G40S-2, G45S-2, G50C-2, G40SC-2, G45SC-2, G50SC-2 Parts Book
- DOOSAN Lift Trucks Model D35S-2, D40S-2, D45S-2, D50C-2, D40SC-2, D45SC-2, D50SC-2 Parts Book
- Daewoo Lift Trucks Electric System Schematic
- Daewoo Lift Trucks G430 LP Engine Service Manual
- Doosan Forklift Service Manual G420FE LP/Dual Fuel Engine G420F LP/Gasoline Dual Fuel Engine
- Daewoo Lift Trucks Hydraulic System Schematic
- Daewoo Lift Trucks Diesel Engine 3.3 Liter (DB33A) Service Manual
- Doosan Forklift Service Manual G424FE LP/Dual Fuel Engine G424F LP Engine
- Daewoo Lift Trucks Power Train Disassembly & Assembly
- Daewoo Doosan Forklift G20S-3 G25S-3 G30S-3 Service Manual
- Doosan LIFT TRUCKS Operation & Maintenance Manual
- Daewoo Lift Trucks Vehicle Systems Specifications Systems Operation Testing & Adjusting
- Deawoo Doosan Forklift B20S-2 Operation Testing & Adjusting
