Doosan Forklift BC15S5 BC18S5 BC20SC5 Spare Parts Catalog SB1087
Brand: Doosan
Type of Machine: Forklift, Electric 1 Ton CUSHION, Electric Powered Truck
Model: Doosan BC15S5, BC18S5, BC20SC5 Forklift
Part Number: SB1087
Number of Pages: 1529 Pages
[CHASSIS] Chassis
AXLE GROUP,STEER
CYLINDER,STEERING
MOUNT GROUP
WEIGHT GROUP,COUNTER
WIRING GROUP
PANEL ASSY
PANEL,CONTROL
CONTROL ASSY
PUMP,GEAR
PUMP ASSY,HYDRAULIC
ARRANGEMENT,GENERAL
MODULE,BASIC
CONTROL GROUP,BRAKE
LINE GROUP
VALVE ASSY
TANK,HYDRAULIC
BRAKE ASSY
BRAKE GROUP,PARKING
CONTROL GROUP
CYLINDER,TILT
TOOL GROUP
PUMP ASSY,WATER
STRAP
FRONT COCKPIT UNIT MOUNTING
HOOD GROUP
TOOL GP
CYLINDER GROUP,TILT
CYLINDER GROUP
ARRANGEMENT,CHANGEOVER
CONTROLLER ASSY
GUARD
TRAY GROUP
CHANGEOVER
[CHASSIS] Driving Module
AXLE,DRIVE
TRANSFER ASSY
BOX,GEAR
FENDER ASSY
FENDER
TIRE AR.-LUG TYPE,WIDE,NON MAR
WHEEL & TIRE GROUP
TIRE AR.-PL TYPE,WIDE
TIRE
[CHASSIS] Electric Power
MOTOR ASSY,DRIVE
MOTOR GROUP,DRIVE
MOTOR ASSY
MOTOR ASSY,PUMP
CHARGER,440V,3P,50HZ,500~585AH
CHARGER,220V,3P,60HZ,740~850AH
CHARGER,380V,3P,50HZ,500~585AH
CHARGER GP; BATTERY
CHARGER,440V,3P-60HZ/540AH
CHARGER,220V,3P-60HZ/540AH
CHARGER,380V,3P,50HZ,740~850AH
CHARGER,440V,3P,50HZ,740~850AH
CHARGER,380V,3P-60HZ/540AH
CHARGER,440V,3P,60HZ,740~850AH
CHARGER,220V,3P,50HZ,500~585AH
CHARGER,220V,1P,50HZ,500~585AH
CHARGER,380V,3P-50HZ/500~585AH
CHARGER,380V,3P,60HZ,740~850AH
CHARGER GP-BATTERY
CONNECTER GROUP,BATTERY
BATTERY ASSY
BATTERY,LOCAL,36V,740AH
BATTERY,NON EEC,48V,585AH
BATTERY,LOCAL,48V,585AH
BATTERY,NON EEC,36V,740AH
[CHASSIS] Operating Module
SWITCH ASSY
VALVE ASSY,RELIEF
VALVE,CONTROL
BRACKET ASSY
VALVE ARRANGEMENT
VALVE SUB ASSY
BRACKET,VALVE MOUNTING
REST,ARM
EXTINGUISHER ASSY,FIRE
LAMP GROUP
LAMP ASSY
LAMP ASSY,HEAD
MIRROR GP
SEAT ASSY
SEAT
SEAT GROUP
VALVE ASSY,SECTION
CHANGEOVER AR.-3S/3L TO 4S/4L
COCKPIT UNIT,FRONT
COVER GROUP
STEERING GROUP
FCU
INSTALLATION
ARRANGEMENT,VALVE
FRONT COCKPIT UNIT, BASIC
FRONT COCKPIT UNIT, FINGERTIP
INSTRUMENT GROUP
TRAYGP
STROBE ASSY
MONO-PED CONTROL-(FCU)
KNOB-WHEEL
LAMP ASSY,COMBINATION
ALARM GROUP
GUARD MODULE, OVERHEAD, BC18S-
GUARD MODULE, OVERHEAD, 83"
LAMP
MIRROR
CHANGEOVER AR.
BAR
SEAT BELT INTERLOCK GP
CONNECTOR
[FRONT END] Mast
ACCUMULATOR GROUP
ACCUMULATOR
PIPE GROUP
LINE GROUP,SIDE SHIFT
LINE GROUP,ATTACHMENT
PIPE ASSY
HOSE GROUP,HYDRAULIC
MAST GROUP
RELAY
RELAY ASSY
MOUNT GROUP,LIFT
LIFT GROUP
LIFT GROUP,PRIMARY
LIFTER GROUP
MOUNT ASSY
MAST ASSY
CYLINDER ASSY
LIFT GROUP,SECONDARY
CYLINDER,LIFT
CYLINDER,PRIMARY
MAST ARRANGEMENT
LIFT GROUP,STANDARD
CYLINDER GROUP,LIFT
HOSE,HYDRAULIC
MOUNTING GROUP
MAST AR-S.Q. FF 3.5M
MAST
[FRONT END] Fork
FORK EXTENSION GROUP
FORK CAP
FORK, ATTACHMENT
FORK
FORK CAP AR.
[FRONT END] Carriage
BEARING
SHIFT GROUP,SIDE
MOUNT
CARRIAGE ARRANGEMENT,STANDARD
CARRIAGE GROUP
CYLINDER,GAS
FORK,POSITIONAL
FORK POSITIONER GROUP
POSITIONER GROUP,FORK
INTEGRALSHIFTING-FORKPOSITIONE
BACKREST GP
REST ASSY,BACK
BACKREST;GROUP;;LOAD;
[MISCELLANEOUS] Location Chart
CHART,LOCATION
