Doosan Forklift B40X5 B45X5 B50X5 Spare Parts Catalog SB1085
Brand: Doosan
Type of Machine: Forklift, Electric 4 Ton Low Floor Type, Electric Powered Truck
Model: Doosan B40X5 B45X5 B50X5 Forklift
Part Number: SB1085
Number of Pages: 542 Pages
Section 1
Basic Module
Axle Gp-Steer
Steer Axle Gp
Axle Assy - Steer
Cylinder
Mounting Gp-Steer
Control Gp-Service Brake
Control Gp-Parking-FCU
Floor Plate Gp
Air Bleeder Gp
Lines Gp-Brake & Breeder
Tilt Cylinder Mounting Gp
Control Gp-Accel
Tank Gp-Hydraulic
Wiring Gp
Panel Gp-Control
Controller Ass’y
Motor Gp-Hydraulic
Pump Motor Ass’y
Axle Gp-Drive
Drive Motor Ass’y
Drive Axle Ass’y-LH
Drive Axle Ass’y-RH
Pump Gp-Gear
Gear Pump Ass’y
Lines Gp-Mast Operating Part 1 of 2
Lines Gp-Mast Operating Part 2 of 2
Lines Gp-Power Steering
Mounting Gp-Front Cockpit Unit
Front Cockpit Unit(Basic)
Steerting Gp
Cover Gp-F.C.U
Instrument Gp-F.C.U
Section 2
Capacity Module
Counterweight Gp
Outer Panel Gp
Panel Gp-Top
Overhead Guard
Location Chart Part Part 1 of 2
Location Chart Part Part 2 of 2
Section 3
Option For Complete Truck
Tire Gp-Solid Soft
Tire Ar;Non Marking Solid Softer
Tire Ar;Solid,Duble,ODB
Lamp Gp-Head(STD)
Seat Gp-Suspension-Non NACD
Seat Gp-Suspension Arm Rest-Non NACD
Seat Gp-Suspension-NACD
Seat Gp-Satic-Retractable-Non NACD & NACD
Seat Gp-Non NACD
Seat Gp-Satic-Parking Alarm-NACD
Seat Ass’y - (NACD)
Seat Gp-Satic-Cloth-NACD
Seat Gp-Cloth
Seat As - BSC(NACD)
Seat Belt Indicator Gp-Non NACD & NACD
Valve Ar-2 Section, 2 Lever
Bracket Ass’y-2Lever
Switch Gp
Valve Ar-3 Section, 3 Lever
Bracket Ass’y-V/V - 3SP
Valve Ar-4 Section, 4 Lever
Bracket Ass’y-V/V - 4SP
Valve Gp-2 Section
Valve Gp-3 Section
Valve Gp-Section
Valve Gp-Section, Tilt
Valve Gp-Section, Aux 1
Valve Gp-Section, Aux 2
Valve Gp-4 Section
Connector Gp-Battery-SBE Type
Connector Gp-Battery-Emergency Switch-SBE Type
Hood Module
Section 4
Option For General
Mirror Gp
Lighting Gp
Lamp Ass’y-Comb
Install Gp-Front Cockpit Unit
Tool Gp
Switch Ass’y-Mono Ped
Control Valve Gp-Fingertip-3 Way
Control Valve Gp-Fingertip-4 Way
Lines Gp-Fingertip-3 Way
Control Valve Gp-3 Section
Inlet Section
Lift Section Gp
Tilt Section Gp
AUX Section Ass’y
Lines Gp-Fingertip-4 Way
Control Valve Gp-4 Section
Mount Gp-Armrest-3 Way
Mount Gp-Armrest-4 Way
Armrest Ass’y-3 Way
Armrest Ass’y-4 Way
Steering Gp-Fingertip
Hood Gp
Modular Cabin-A Type
Modular Cabin-B Type
Modular Cabin-C Type
Cover Ass’y-Rear
Wiper Gp-Front Window
Auto Tilt Leveling Gp(Without Fingertip)
Auto Tilt Leveling Gp(With Fingetip)
Mounting Gp-Fire Extinguisher
Changeover Ar.-UL Type To ES
Changeover Ar. Battery Roll In/Out
Hood Ass‘y
Section 5
Mast Hydraulic
Mounting Gp-Lift-STD
Mounting Gp-Lift-FFT
Mounting Gp-Lift-FFL
Lines Gp-ATT-Primary-STD-3 Way
Lines Gp-ATT-Primary-STD-4 Way
Lines Gp-ATT-Primary-FFT-3 Way
Lines Gp-ATT-Primary-FFT-4 Way
Lines Gp-ATT-Primary-FFL-3 Way
Lines Gp-ATT-Primary-FFL-4 Way
Lines Gp-ATT-Secondary-STD-3 Way-RH-4.0/4.5 Ton
Lines Gp-ATT-Secondary-STD-3 Way-RH-5.0 Ton
Lines Gp-ATT-Secondary-STD-3 Way-LH-4.0/4.5 Ton
Lines Gp-ATT-Secondary-STD-3 Way-LH-5.0 Ton
Lines Gp-ATT-Secondary-STD-4 Way-4.0/4.5 Ton
Lines Gp-ATT-Secondary-STD-4 Way-5.0 Ton
Lines Gp-ATT-Secondary-FFT, FFL-3 Way-RH-4.0/4.5 Ton
Lines Gp-ATT-Secondary-FFT, FFL-3 Way-RH-5.0 Ton
Lines Gp-ATT-Secondary-FFT, FFL-3 Way-LH-4.0/4.5 Ton
Lines Gp-ATT-Secondary-FFT, FFL-3 Way-LH-5.0 Ton
Lines Gp-ATT-Secondary-FFT, FFL-4 Way-4.0/4.5 Ton
Lines Gp-ATT-Secondary-FFT, FFL-4 Way-5.0 Ton
Lines Gp-Side Shifter-STD-4.0/4.5 Ton
Lines Gp-Side Shifter-STD-5.0 Ton
Lines Gp-Side Shifter-FFT, FFL-4.0/4.5 Ton
Lines Gp-Side Shifter-FFT, FFL-5.0 Ton
Mast Mounting Gp
Cylinder Gp-Tilt-STD
Tilt Gp-2 Required-Option
Section 6
Mast-Implements
Mast Gp-Basic-STD, FFL
Mast Gp-Basic-FFT
Mast-Upright Ass’y-STD-Inner
Mast-Upright Ass’y-STD-Stat
Mast-Upright Ass’y-FFT-Inner
Mast-Upright Ass’y-FFT-Inter
Mast-Upright Ass’y-FFT-Stat
Mast-Upright Ass’y-FFL-Inner
Mast-Upright Ass’y-FFL-Stat
Relay Gp-Lift-STD-4.0/4.5 Ton
Relay Gp-Lift-STD-5.0 Ton
Relay Gp-Lift-FFT-4.0/4.5 Ton
Relay Gp-Lift-FFT-5.0 Ton
Relay Gp-Lift-FFL-4.0/4.5 Ton
Relay Gp-Lift-FFL-5.0 Ton
Lift Gp-Secondary-STD
Lift Gp-Secondary-FFT
Lift Gp-Secondary-FFL-LH
Lift Gp-Secondary-FFL-RH
Lift Gp-Primary-FFT
Lift Gp-Primary-FFL
Carriage Gp-STD, FFT, FFL
Mounting Gp-Carriage
Side Shifter Gp-4.0/4.5 Ton
Side Shifter Gp-5.0 Ton
Cylinder Gp
Load Backrest-4.0/4.5 Ton
Load Backrest-5.0 Ton
Fork Group
Integral Shifting
Mounting Group-Fork Positioner
Cylinder Ass"y
Mounting Group-Carriage
Brand: Doosan
Part Number: SB1085
Section 1
Basic Module
Axle Gp-Steer
Steer Axle Gp
Axle Assy - Steer
Cylinder
Mounting Gp-Steer
Floor Plate Gp
Air Bleeder Gp
Control Gp-Accel
Tank Gp-Hydraulic
Wiring Gp
Panel Gp-Control
Controller Ass’y
Motor Gp-Hydraulic
Pump Motor Ass’y
Axle Gp-Drive
Drive Motor Ass’y
Drive Axle Ass’y-LH
Drive Axle Ass’y-RH
Pump Gp-Gear
Gear Pump Ass’y
Steerting Gp
Cover Gp-F.C.U
Instrument Gp-F.C.U
Section 2
Capacity Module
Counterweight Gp
Outer Panel Gp
Panel Gp-Top
Overhead Guard
Section 3
Tire Gp-Solid Soft
Lamp Gp-Head(STD)
Seat Gp-Non NACD
Seat Ass’y - (NACD)
Seat Gp-Cloth
Seat As - BSC(NACD)
Switch Gp
Valve Gp-2 Section
Valve Gp-3 Section
Valve Gp-Section
Valve Gp-4 Section
Hood Module
Section 4
Option For General
Mirror Gp
Lighting Gp
Lamp Ass’y-Comb
Tool Gp
Inlet Section
Lift Section Gp
Tilt Section Gp
AUX Section Ass’y
Armrest Ass’y-3 Way
Armrest Ass’y-4 Way
Hood Gp
Cover Ass’y-Rear
Hood Ass‘y
Section 5
Mast Hydraulic
Mast Mounting Gp
Section 6
Mast-Implements
Mast Gp-Basic-FFT
Lift Gp-Primary-FFT
Lift Gp-Primary-FFL
Cylinder Gp
Fork Group
Integral Shifting
Cylinder Ass"y
- DOOSAN Lift Trucks Model D20S-3, D25S-3, D30S-3, D32S-3, D33S-3 Parts Book
- DOOSAN Lift Trucks Model G20S-2, G25S-2, G30S-2 Parts Book
- DOOSAN Lift Trucks Model G35S-2, G40S-2, G45S-2, G50C-2, G40SC-2, G45SC-2, G50SC-2 Parts Book
- DOOSAN Lift Trucks Model D35S-2, D40S-2, D45S-2, D50C-2, D40SC-2, D45SC-2, D50SC-2 Parts Book
- Daewoo Lift Trucks Electric System Schematic
- Daewoo Lift Trucks G430 LP Engine Service Manual
- Doosan Forklift Service Manual G420FE LP/Dual Fuel Engine G420F LP/Gasoline Dual Fuel Engine
- Daewoo Lift Trucks Hydraulic System Schematic
- Daewoo Lift Trucks Diesel Engine 3.3 Liter (DB33A) Service Manual
- Doosan Forklift Service Manual G424FE LP/Dual Fuel Engine G424F LP Engine
- Daewoo Lift Trucks Power Train Disassembly & Assembly
- Daewoo Doosan Forklift G20S-3 G25S-3 G30S-3 Service Manual
- Doosan LIFT TRUCKS Operation & Maintenance Manual
- Daewoo Lift Trucks Vehicle Systems Specifications Systems Operation Testing & Adjusting
- Deawoo Doosan Forklift B20S-2 Operation Testing & Adjusting
