Doosan Forklift B30S B35S Spare Parts Catalog SB5146Y
Brand: Doosan
Type of Machine: Forklift, Electric 2 Ton PNEUMATIC, Electric Powered Truck
Model: Doosan B30S B35S Forklift
Part Number: SB5146Y
Number of Pages: 325 Pages
Section 1
Chassis Componet
Mounting Gp-Steering Axle
Steering Axle As
Cylinder As-Steer
Mounting Gp-Service Brake
Mounting Gp-Brake(Service)
Mounting Gp-Parking
Lever As-Parking
Mounting Gp-Floor Plate
Mounting Gp-Accel
Tank Gp-Hydraulic
Tank Module-Hydraulic
Panel Gp-Control-CTS
Wiring Gp-CTS
Motor Gp-Pump-CTS
Motor Gp-Drive-CTS
Mounting Gp-Hyd.Pump
Lines Gp-Mast OperaTing
Lines GP-Power Steering
Mounting Gp-Column
Column As
Instrument Gp-CTS
Mounting Gp-Overhead Guard
Mirror Gp
Alarm Gp-Back Up
Lighting Gp
Mounting Gp-Cowl
FCU Gp
Control Gp Parking
Steering Gp
Cover Gp
Section 2
Capacity Module
Counter Weight GP [B30S]
Counter Weight Gp [B35S]
Mounting Gp-D/A & T/M
Wheel Brake As-LH
Wheel Brake As-RH
Guard Gp-Overhead [B30SE]
Guard Gp-Overhead
Panel Gp-Outer
Hood Gp
Frame As
Lines Gp-Brake
TOOL GP
Section 3
Option For Complete Truck
Tire Ar-Pneumatic [B30S]
Tire Ar-Solid Softer [B35S]
Tire Ar-Solid Softer(Non Marking)
Tire Ar-Solid -ZHENGXIN
Seat Gp-Static STD
Seat Gp-Static & Armrest
Seat Gp-Suspension
Seat Gp-Suspension & Armrest
Seat Gp-Vinyl Suspension(W/O Hip.Res.,W/O Arm.)
Seat Gp-Vinyl Suspension(W/O Hip.Res.,W/ARM.)
Seat Belt Gp W/O Switch
Valve Ar-2SEC. 2LEV
Valve As-2SEC. 2LEV
Valve Ar-3SEC. 3LEV
Valve As-3SEC. 3LEV
Valve Ar-4SEC., 4LEV
Valve As-4SEC. 4LEV.
Valve-Distributary
Valve-Lift
Valve-Tilt
Valve-Revolve
Housing-Relief Valve
Tool Gp
Section 4
Options for General
Strobe Gp-Under
Strode Gp-Upper
Rear Lamp Gp
LED Lamp
Changeover Ar
Wring Gp-Modular Cabin
Cabin Modular AS-C
Cabin Modular AS-B
Cabin Modular AS-A
Rear Cover Assy
EM Switch Mtg.
FE-LI Battery OPTN;80V/300AH(3.0Ton)
FE-LI Battery OPTN;80V/300AH(3.5Ton)
FE-LI Battery OPTN;80V/420AH(3.5Ton)
Battery 80V/560AH
FE-LI Battery 80V/300AH ZERO Amperex-B30S
FE-LI Battery 80V/400AH ZERO Amperex-B30S
FE-LI Battery 80V/450AH ZERO Amperex-B30S
FE-LI Battery 80V/400AH ZERO Amperex-B35S
FE-LI Battery 80V/450AH ZERO Amperex-B35S
FE-LI Battery 80V/525AH ZERO Amperex-B35S
Charger Assy;100V/140A
Charger Assy;100V/180A
Blue Spot Light
Quick Coupling;3Way
Quick Coupling;4Way
Section 5
Mast Hydraulic
Lift Cylinder Gp-STD(B30S MFH 2500~3700mm)
Lift Cylinder Gp-STD(B30S MFH 4000~& B35S MFH 2500mm~)
Lift Cylinder Gp-Primary-FFL
Lift Cylinder Gp-Primary-FFT
Lift Cylinder Gp-Secondary-FFL
Lift Cylinder Gp-Secondary-FFT
Tilt Cylinder Ass’y-LH-W
Tilt Cylinder Ass’y-RH-W
Tilt Cylinder Gp
S/S Lines Gp(STD)
S/S Lines Gp(FFL,FFT)
Att Lines Gp-SEC-SEC(3Way)-RH(FFL,FFT)
Att Lines Gp-SEC-SEC(4Way)-STD
Att Lines Gp-SEC(3Way)-LH(FFL,FFT)
Att Lines Gp-SEC(4Way)-FFL,FFT
Lines Gp-Att-Secondary(3Way-LH)
Section 6
Mast Implements
Mast Gp-BSC(STD)
Mast Gp-BSC(FFL)
Mast Gp-BSC(FFT)
Mast-STD
Mast-FFL
Mast-FFT
Mounting Gp-Lift & Tilt(STD)(B30S MFH 2500~3700mm)
Mounting Gp-Lift & Tilt(STD)(B30S MFH 4000~& B35S MFH 2500mm~)
Mounting Gp-Lift & Tilt(FFL)
Mounting Gp-Lift & Tilt(FFT)
Relay Gp-STD
Lift Relay Gp-FFL
Lift Relay Gp-FFT
Att Lines Gp-Pri-3Way(STD)
Att Lines Gp-Pri-3Way(FFL)
Att Lines Gp-Pri-3Way(FFT)
Att Lines Gp-Pri-4Way(STD)
Att Lines Gp-Pri-4Way(FFL)
Att Lines Gp-Pri-4Way(FFT)
Side Shifter Cylinder Ass’y[B30SE]
Side Shifter Gp
Att Lines Gp-SEC(3WAY)-LH(STD)
Att Lines Gp-SEC(3WAY)-RH(STD)
Carriage Ar.-Integarl Side Shifter
Backrest Ass’y
Backrest Ass’y H=1500
Carriage Ass’y-STD/FFL/FFT
Carriage Mounting
Fork Gp
Brand: Doosan
Section 1
Chassis Componet
Steering Axle As
Cylinder As-Steer
Mounting Gp-Parking
Lever As-Parking
Mounting Gp-Accel
Tank Gp-Hydraulic
Wiring Gp-CTS
Motor Gp-Pump-CTS
Motor Gp-Drive-CTS
Mounting Gp-Column
Column As
Instrument Gp-CTS
Mirror Gp
Alarm Gp-Back Up
Lighting Gp
Mounting Gp-Cowl
FCU Gp
Control Gp Parking
Steering Gp
Cover Gp
Section 2
Capacity Module
Wheel Brake As-LH
Wheel Brake As-RH
Guard Gp-Overhead
Panel Gp-Outer
Hood Gp
Frame As
Lines Gp-Brake
TOOL GP
Section 3
Seat Gp-Static STD
Seat Gp-Suspension
Valve Ar-2SEC. 2LEV
Valve As-2SEC. 2LEV
Valve Ar-3SEC. 3LEV
Valve As-3SEC. 3LEV
Valve-Distributary
Valve-Lift
Valve-Tilt
Valve-Revolve
Tool Gp
Section 4
Options for General
Strobe Gp-Under
Strode Gp-Upper
Rear Lamp Gp
LED Lamp
Changeover Ar
Cabin Modular AS-C
Cabin Modular AS-B
Cabin Modular AS-A
Rear Cover Assy
EM Switch Mtg.
Battery 80V/560AH
Blue Spot Light
Quick Coupling;3Way
Quick Coupling;4Way
Section 5
Mast Hydraulic
Tilt Cylinder Gp
S/S Lines Gp(STD)
Section 6
Mast Implements
Mast Gp-BSC(STD)
Mast Gp-BSC(FFL)
Mast Gp-BSC(FFT)
Mast-STD
Mast-FFL
Mast-FFT
Relay Gp-STD
Lift Relay Gp-FFL
Lift Relay Gp-FFT
Side Shifter Gp
Backrest Ass’y
Carriage Mounting
Fork Gp
- DOOSAN Lift Trucks Model D20S-3, D25S-3, D30S-3, D32S-3, D33S-3 Parts Book
- DOOSAN Lift Trucks Model G20S-2, G25S-2, G30S-2 Parts Book
- DOOSAN Lift Trucks Model G35S-2, G40S-2, G45S-2, G50C-2, G40SC-2, G45SC-2, G50SC-2 Parts Book
- DOOSAN Lift Trucks Model D35S-2, D40S-2, D45S-2, D50C-2, D40SC-2, D45SC-2, D50SC-2 Parts Book
- Daewoo Lift Trucks Electric System Schematic
- Daewoo Lift Trucks G430 LP Engine Service Manual
- Doosan Forklift Service Manual G420FE LP/Dual Fuel Engine G420F LP/Gasoline Dual Fuel Engine
- Daewoo Lift Trucks Hydraulic System Schematic
- Daewoo Lift Trucks Diesel Engine 3.3 Liter (DB33A) Service Manual
- Doosan Forklift Service Manual G424FE LP/Dual Fuel Engine G424F LP Engine
- Daewoo Lift Trucks Power Train Disassembly & Assembly
- Daewoo Doosan Forklift G20S-3 G25S-3 G30S-3 Service Manual
- Doosan LIFT TRUCKS Operation & Maintenance Manual
- Daewoo Lift Trucks Vehicle Systems Specifications Systems Operation Testing & Adjusting
- Deawoo Doosan Forklift B20S-2 Operation Testing & Adjusting
