Doosan Forklift B22X7 B25X7 B25XL7 B30X7 B35X7 Spare Parts Catalog SB1240
Brand: Doosan
Type of Machine: Forklift, Electric 2 Ton Low Floor Type, Electric Powered Truck
Model: Doosan B22X7, B25X7, B25XL7, B30X7, B35X7 Forklift
Part Number: SB1240
Number of Pages: 4181 Pages
[CHASSIS] Chassis
CYLINDER,STEERING
WEIGHT GROUP,COUNTER
PANEL GP.-CONTROL
PUMP,GEAR
WIRING GP
ARRANGEMENT,GENERAL
AXLE GROUP,STEER
PLATE ASSY,FLOOR
PANEL
PANEL,CONTROL
CONTROLLER ASSY
WIRE GROUP
LINE GROUP
TANK,HYDRAULIC
MOUNT GROUP
HOOD GROUP
HOOD MODULE
MODULE,BASIC
CONTROL GROUP,BRAKE
BRAKE ASSY
MODULE,CAPACITY
MODULE,PERFORMANCE
STRAP
CYLINDER GROUP,TILT
CYLINDER ASSY,TILT
TOOL GROUP
CH/OV AUTOTILT LEVELING
CH/OV COLD STORAGE
CH/OV AR.
CH/OV AR-BATT.SIDE ROLL IN OUT
CH/OV AR-BATT.SIDE LIFT IN OUT
UL SAFETY
SEAT GROUP
[CHASSIS] Driving Module
TIRE GROUP
[CHASSIS] Electric Power
CONNECTOR GROUP;BATTERY
BATTERY,EEC,80V,500AH
BATTERY,EEC,80V,600AH
BATTERY,LOCAL,80V,600AH
CHARGER,220V,3P,50HZ,450~550AH
CHARGER,440V,3P,50HZ,400~487AH
CHARGER,220V,3P,60HZ,450~550AH
CHARGER,220V,3P,60HZ,570~680AH
CHARGER,380V,3P,50HZ,450~550AH
CHARGER,380V,3P,50HZ,570~680AH
CHARGER,380V,3P,60HZ450~550AH
CHARGER,380V,3P,60HZ,570~680AH
CHARGER,440V,3P,50HZ,450~550AH
CHARGER,440V,3P,50HZ,570~680AH
CHARGER,440V,3P,60HZ,450~550AH
CHARGER,440V,3P,60HZ,570~680AH
ARRANGEMENT,CHANGEOVER
MOTOR ASSY,DRIVE
MOTOR ASSY,PUMP
[CHASSIS] Operating Module
ALARM GROUP
MOUNTING GROUP
HOOD ASSY
VALVE ARRANGEMENT
VALVE ASSY
BRACKET ASSY
VALVE SUB ASSY
SWITCH ASSY
BRACKET ASSY,VALVE
BRACKET,VALVE MOUNTING
LAMP GROUP
LAMP ASSY,COMBINATION
LAMP AS-COMBI
LAMP ASSY
HARNESS GP
EMERGENCY POWER DISCONNECT GP.
FRONT COCKPIT UNIT,BASIC
COVER GROUP
STEERING GROUP
INSTRUMENT GROUP
RESERVOIR
WHEEL GROUP
EXTINGUISHER ASSY,FIRE
KNOB-STEERING WHEEL
LAMP ASSY,HEAD
LAMP
SWITCH,LAMP
STROBE ASSY
MIRROR GP
CHANGEOVER AR.
OVERHEAD GUARD,2185MM
OVERHEAD GUARD,2210MM
BAR
INTERLOCK GP
SEAT ASSY
SEAT,SUSPENSION
SEAT GROUP-GRAMMER
SEAT,OPERATOR
SEAT GP-GRAMMER
AUX. POWER PACKAGE GP.
CH/OV BLUE SPOT LIGHT
MOUNTING GP.
VALVE,BRAKE
CH/OV GSS
GSS OPTION FOR FRONTEND
VALVE GROUP,CONTROL VALVE
REST,ARM
WIRING GROUP
VALVE
[FRONT END] Mast
LINES GP
PIPE ASSY
HOSE,HYDRAULIC
LINES GP SEC. 3WAY-RH
LINE GROUP,ATTACHMENT
PIPE,LINE
HOSE GROUP,HYDRAULIC
MERCHANDIZING
LINES GP SEC. 3WAY-LH
LINES GP SEC. 4WAY
ARRANGEMENT,MERCHANDISING
LINE GROUP,FUEL
MAST ARRANGEMENT
MAST GROUP
RELAY ASSY
CYLINDER ASSY,LIFT
CYLINDER,SECONDARY
MOUNT GROUP,LIFT
CYLINDER ASSY
SHEAVE GROUP
CYLINDER GROUP,LIFT
MAST
CYLINDER,PRIMARY
BEARING
MOUNT
RELAY
LIFT GROUP,STANDARD
LIFT ASSY
LIFT,CYLINDER
LIFTER GROUP
LIFT GROUP
MAST ASSY
UPRIGHT ASSY,INNER
MAST ASSY,INTER
CYLINDER GROUP
UPRIGHT ASSY,STATIONARY
UPRIGHT ASSY,INTER
[FRONT END] Fork
FORK EXTENSION GROUP
FORK CAP
FORK
POSITIONER,FORK
FORK ASSY
FORK, ATTACHMENT
FORK CAP GP
ATTACHMENT, L/S
ATTACHMENT, B/C
BALE CLAMP ARR.
ATTACHMENT, H/F
ATTACHMENT, H/B
ATTACHMENT, F/C
ATTACHMENT, R/F/C
ATTACHMENT, R/F
ATTACHMENT, R/R/C
ATTACHMENT, P/P
ATTACHMENT, T/C
ATTACHMENT, P/H
ATTACHMENT, M/C
ATTACHMENT, C/C
ATTACHMENT, D/C
DRUM HANDLER ARR.
ATTACHMENT, R/P/C
ATTACHMENT, I/C
[FRONT END] Carriage
LOAD BACKREST
REST ASSY,BACK
REST,BACK
CARRIAGE ARRANGEMENT
CARRIAGE ASSY
CARRIAGE ARR
MOUNT ASSY
POSITIONER GROUP,FORK
CYLINDER,GAS
COUPLING GROUP
COUPLING,QUICK
HOOK ON SIDE SHIFTER GP.
SIDE SHIFTER ASSY
SHIFT GROUP,SIDE
SHIFTER,INTEGRAL SIDE CARRIAGE
LIFT,MOVEABLE HYDRAULIC
SIDE SHIFTER
CARRIAGE GROUP
