Doosan Forklift B20SE B25SE B30SE Spare Parts Catalog SB1122Y
Brand: Doosan
Type of Machine: Forklift, Electric 2 Ton PNEUMATIC, Electric Powered Truck
Model: Doosan B20SE B25SE B30SE Forklift
Part Number: SB1122Y
Number of Pages: 644 Pages
Section 1
Chassis Componet
Mounting Gp-Steering Axle(B20/25SE)
Mounting Gp-Steering Axle(B30SE)
Steering Axle As(B20/25SE)
Steering Axle As(B30SE)
Steering Axle As(B20/25/30SE)
CYLINDER AS-STEER
MOUNTING GP-SERVICE BRAKE
MASTER CYLINDER AS
MOUNTING GP-PARKING
LEVER AS-PARKING
MOUNTING GP-FLOOR PLATE
MOUNTING GP-FLOOR PLATE-FCU
MOUNTING GP-ACCEL
TANK GP-HYDRAULIC
PANEL GP-CONTROL-CTS
PANEL GP-CONTROL-SME
WIRING GP-CTS
WIRING GP-SME
Fan As-Drive Motor
MOTOR GP-PUM-SME
MOTOR GP-PUMP-CTS
PUMP-MOTOR AS-CTS
PUMP-MOTOR AS-SME
MOTOR GP-DRIVE-CTS
MOTOR GP-DRIVE-SME
DRIVE-MOTOR AS-CTS
DRIVE-MOTOR AS-SME
MOUNTING GP-HYD.PUMP
PUMP AS-GEAR
LINES GP-MAST OPERATING
PRIORITY VALVE AS
LINES GP-POWER STEERING
STEERING UNIT AS
MOUNTING GP-COLUMN
COLUMN AS
INSTRUMENT GP-CTS
Instrument Gp-SME
MOUNTING GP-OVERHEAD GUARD
LOCKING GP-BATTERY
MIRROR GP
ALARM GP-BACK UP
CONNECTOR GP-BATTERY-CTS
CONNECTOR GP-BATTERY-SME
LIGHTING GP
MOUNTING GP-COWL
FCU GP(B20,25SE)
FCU GP(B30SE)
CONTROL GP-PARKING,FCU(B20,25/30SE)
STEERTING GP-FCU
Cover Gp-FCU
INSTRUMENT GP - F.C.U
Section 2
Capacity Module
COUNTER WEIGHT GP [B20SE]
COUNTER WEIGHT GP [B25SE]
COUNTER WEIGHT GP [B30SE]
Mounting Gp-D/A & T/M [B20/25SE]
DRIVE AXLE AS [B20/25SE]
WHEEL BRAKE ASS`Y-LH[B20/25SE]
WHEEL BRAKE ASS`Y-RH [B20/25SE]
Wheel Brake Ass’y-LH [B20/25SE]
Wheel Brake Ass’y-RH [B20/25SE]
TRANSMISSION AS
MOUNTING GP-D/A & T/M [B30SE]
Mounting Gp-D/A & T/M [B30SE]
DRIVE AXLE AS [B30SE]
WHEEL BRAKE ASS`Y-LH[B30SE]
WHEEL BRAKE ASS`Y-RH [B30SE]
DRIVE AXLE GP [B30SE] - X
DRIVE AXLE GP [B30SE] - L
WHEEL BRAKE AS-RH[B30SE]
Wheel Brake As-LH [B30SE]
GUARD GP-OVERHEAD[B20/25SE]
GUARD GP-OVERHEAD[B20/25SE]-FCU
GUARD GP-OVERHEAD[B30SE]
GUARD GP-OVERHEAD[B30SE]-FCU
Panel Gp-Outer [B20/25SE]
Panel Gp-Outer [B30SE]
Hood Gp [B20/25SE]
Hood Gp [B30SE]
FRAME AS [B20/25SE]-CTS
FRAME AS [B20/25SE]-SME
FRAME AS [B20/25SE]-CTS-FCU
Frame As [B20/25SE]-CTS-FCU
FRAME AS[B30SE]-SME
Frame As [B30SE]-CTS
FRAME AS[B30SE]-CTS
FRAME AS[B30SE]-CTS-FCU
Frame As [B30SE]-CTS-FCU
MOUNTING GP-COWL [B20/25SE]
MOUNTING GP-COWL [B30SE]
BATTERY AS-CTS
BATTERY AS-SME
BATTERY AS(NO LEAKAGE HOLE)-CTS
CHARGER AS[B20/25SE]
CHARGER AS[B30SE]
Location Chart
Location Chart-FCU
LINES GP-BRAKE[B20/25SE]
LINES GP-BRAKE[B20/25SE]-FCU
LINES GP-BRAKE[B30SE]
LINES GP-BRAKE[B30SE]-FCU
Section 3
Option For Complete Truck
TIRE AR-PNEUMATIC [B20/25SE]
TIRE AR-PNEUMATIC [B30SE]
TIRE AR-SOLID SOFTER [B20/25SE]
TIRE AR-SOLID SOFTER [B30SE]
TIRE AR-SOLID SOFTER(NON MARKING) [B20/25SE]
TIRE AR-SOLID SOFTER(NON MARKING) [B30SE]
Seat Gp-Static STD
SEAT GP-STATIC & ARMREST
Seat Gp-Static & Armrest
SEAT GP-SUSPENSION
SEAT GP-SUSPENSION & ARMREST
Seat Gp-Suspension & Armrest
SEAT GP-VINYL SUSPENSION(W/O HIP.RES.,W/O ARM.)
SEAT GP-VINYL SUSPENSION(W/O HIP.RES.,W/ARM.)
SEAT BELT GP W/O SWITCH
VALVE AR-2SEC., 2LEV
VALVE AS-2SEC. 2LEV.
VALVE AR-3SEC. 3LEV
VALVE AS-3SEC. 3LEV.
VALVE AR-4SEC., 4LEV
VALVE AS-4SEC. 4LEV.
VALVE AS-2SEC.
VALVE AS-3SEC.
VALVE AS-4SEC.
VALVE-DISTRIBUTARY
VALVE-LIFT
VALVE-TILT
VALVE-REVOLVE
HOUSING-RELIEF VALVE
TOOL GP
Section 4
Options for General
STROBE GP-UNDER
STROBE GP-UPPER
REAR LAMP GP
Charger Gp-380V-3P-50~60Hz-B20/25SE
Charger Gp-380V-3P-50~60Hz-B30CE
Changeover Ar
Wring Gp-Modular Cabin
Cabin Modular AS-C
Cabin Modular AS-B
Cabin Modular AS-A
Cabin Modular AS-A(2.0/2.5Ton)
Cabin Modular AS-B(2.0/2.5Ton)
Cabin Modular AS-C(2.0/2.5Ton)
Battery As,FE-LI
Battery Gp;48V/400AH(2.0/2.5Ton)
Battery Gp;48V/480AH(2.0/2.5Ton)
Battery Gp;48V/400AH(3.0Ton)
Battery,FE-LI;48V/400AH(2.0/2.5Ton)
Battery,FE-LI;48V/480AH(2.0/2.5Ton)
Battery,FE-LI;48V/400AH(3.0Ton)
Steering Axle As
Fan Gp
FE-LI Battery(B20/25SE)
FE-LI Battery(B30SE)
Charger Gp
Section 5
Mast Hydraulic
LIFT CYLINDER GP-STD
LIFT CYLINDER GP-PRIMARY-FFL
LIFT CYLINDER GP-PRIMARY-FFT
LIFT CYLINDER GP-SECONDARY-FFL
LIFT CYLINDER GP-SECONDARY-FFT
TILT CYLINDER ASS`Y-LH
TILT CYLINDER ASS`Y-RH
TILT CYLINDER ASS`Y-LH-W
TILT CYLINDER ASS`Y-RH-W
Tilt Cylinder Ass’y-LH-W
Tilt Cylinder Ass’y-RH-W
Tilt Cylinder Gp
S/S LINES GP(STD) [B20/25/30SE]
S/S LINES GP(FFL,FFT) [B20/25/30SE]
ATT LINES GP-SEC(3WAY)-RH(FFL,FFT)[B20/25/30SE]
ATT LINES GP-SEC(4WAY)-STD [B20/25/30SE]
ATT LINES GP-SEC(3WAY)-LH(FFL,FFT)[B20/25/30SE]
ATT LINES GP-SEC(4WAY)-FFL,FFT [B20/25/30SE]
LINES GP-ATT-SECONDARY(3WAY-LH) [B20/25/30SE]
Section 6
Mast Implements
Mast Gp-BSC(STD)
MAST GP-BSC(FFL)
MAST GP-BSC(FFT)
MAST-STD
MAST-FFL
MAST-FFT
MOUNTING GP-LIFT & TILT(STD)
MOUNTING GP-LIFT & TILT(FFL)
MOUNTING GP-LIFT & TILT(FFT)
RELAY GP-STD
LIFT RELAY GP-FFL
LIFT RELAY GP-FFT
ATT LINES GP-PRI-3WAY(STD)
ATT LINES GP-PRI-3WAY(FFL)
ATT LINES GP-PRI-3WAY(FFT)
ATT LINES GP-PRI-4WAY(STD)
Att Lines Gp-Pri-4Way(FFL)
ATT LINES GP-PRI-4WAY(FFT)
Att Lines Gp-Pri-3Way(QUAD)
SIDE SHIFTER GP [B20/25SE]
SIDE SHIFTER CYLINDER ASS`Y[B20/25SE]
SIDE SHIFTER GP [B30SE]
ATT LINES GP-SEC(3WAY)-LH(STD)
ATT LINES GP-SEC(3WAY)-RH(STD)
CARRIAGE ASS`Y
CARRIAGE AR.-INTEGRAL SIDE SHIFTER
BACKREST ASS`Y [B20/25/30SE]
Carriage Ass’y-STD/FFL/FFT
Carriage Arrangement;Int S/S-FFT-2.0/2.5Ton
Carriage Arrangement;Int S/S-FFT-3.0Ton
CARRIGE MOUNTING
Fork Gp
Brand: Doosan
Section 1
Chassis Componet
CYLINDER AS-STEER
MASTER CYLINDER AS
MOUNTING GP-PARKING
LEVER AS-PARKING
MOUNTING GP-ACCEL
TANK GP-HYDRAULIC
WIRING GP-CTS
WIRING GP-SME
Fan As-Drive Motor
MOTOR GP-PUM-SME
MOTOR GP-PUMP-CTS
PUMP-MOTOR AS-CTS
PUMP-MOTOR AS-SME
MOTOR GP-DRIVE-CTS
MOTOR GP-DRIVE-SME
DRIVE-MOTOR AS-CTS
DRIVE-MOTOR AS-SME
PUMP AS-GEAR
PRIORITY VALVE AS
STEERING UNIT AS
MOUNTING GP-COLUMN
COLUMN AS
INSTRUMENT GP-CTS
Instrument Gp-SME
LOCKING GP-BATTERY
MIRROR GP
ALARM GP-BACK UP
LIGHTING GP
MOUNTING GP-COWL
FCU GP(B20,25SE)
FCU GP(B30SE)
STEERTING GP-FCU
Cover Gp-FCU
Section 2
Capacity Module
TRANSMISSION AS
Hood Gp [B20/25SE]
Hood Gp [B30SE]
FRAME AS[B30SE]-SME
FRAME AS[B30SE]-CTS
BATTERY AS-CTS
BATTERY AS-SME
CHARGER AS[B30SE]
Location Chart
Location Chart-FCU
Section 3
Seat Gp-Static STD
SEAT GP-SUSPENSION
VALVE AR-3SEC. 3LEV
VALVE AS-2SEC.
VALVE AS-3SEC.
VALVE AS-4SEC.
VALVE-DISTRIBUTARY
VALVE-LIFT
VALVE-TILT
VALVE-REVOLVE
TOOL GP
Section 4
Options for General
STROBE GP-UNDER
STROBE GP-UPPER
REAR LAMP GP
Changeover Ar
Cabin Modular AS-C
Cabin Modular AS-B
Cabin Modular AS-A
Battery As,FE-LI
Steering Axle As
Fan Gp
Charger Gp
Section 5
Mast Hydraulic
Tilt Cylinder Gp
Section 6
Mast Implements
Mast Gp-BSC(STD)
MAST GP-BSC(FFL)
MAST GP-BSC(FFT)
MAST-STD
MAST-FFL
MAST-FFT
RELAY GP-STD
LIFT RELAY GP-FFL
LIFT RELAY GP-FFT
CARRIAGE ASS`Y
CARRIGE MOUNTING
Fork Gp
- DOOSAN Lift Trucks Model D20S-3, D25S-3, D30S-3, D32S-3, D33S-3 Parts Book
- DOOSAN Lift Trucks Model G20S-2, G25S-2, G30S-2 Parts Book
- DOOSAN Lift Trucks Model G35S-2, G40S-2, G45S-2, G50C-2, G40SC-2, G45SC-2, G50SC-2 Parts Book
- DOOSAN Lift Trucks Model D35S-2, D40S-2, D45S-2, D50C-2, D40SC-2, D45SC-2, D50SC-2 Parts Book
- Daewoo Lift Trucks Electric System Schematic
- Daewoo Lift Trucks G430 LP Engine Service Manual
- Doosan Forklift Service Manual G420FE LP/Dual Fuel Engine G420F LP/Gasoline Dual Fuel Engine
- Daewoo Lift Trucks Hydraulic System Schematic
- Daewoo Lift Trucks Diesel Engine 3.3 Liter (DB33A) Service Manual
- Doosan Forklift Service Manual G424FE LP/Dual Fuel Engine G424F LP Engine
- Daewoo Lift Trucks Power Train Disassembly & Assembly
- Daewoo Doosan Forklift G20S-3 G25S-3 G30S-3 Service Manual
- Doosan LIFT TRUCKS Operation & Maintenance Manual
- Daewoo Lift Trucks Vehicle Systems Specifications Systems Operation Testing & Adjusting
- Deawoo Doosan Forklift B20S-2 Operation Testing & Adjusting
