Doosan Forklift B16X7 B18X7 B20X7 Spare Parts Catalog SB1189
Brand: Doosan
Type of Machine: Forklift, Electric 1 Ton Low Floor Type, Electric Powered Truck
Model: Doosan B16X7, B18X7, B20X7 48V AC MOTOR Forklift
Part Number: SB1189
Number of Pages: 2673 Pages
[CHASSIS] Chassis
CYLINDER,STEERING
WEIGHT GROUP,COUNTER
GENERAL AR.
COVER ASSY,SIDE
PANEL
BRACKET ASSY
HOOD GROUP
HOOD MODULE
CONTROL GROUP,BRAKE
MOUNT GROUP
PLATE ASSY,FLOOR
LINE GROUP
VALVE ASSY
VALVE,PRIORITY
TANK,HYDRAULIC
TANK MODULE,HYDRAULIC
MODULE,BASIC
PUMP,GEAR
PUMP ASSY,MODULE
AXLE ASSY,STEER
AXLE GROUP,STEER
PANEL,CONTROL
CONTROLLER ASSY
CABLE GROUP
WIRE GROUP
BRAKE ASSY
CYLINDER,MASTER
MOUNTING GP.
STRAP
CYLINDER GROUP,TILT
TOOL GP
TELEMATICS SYSTEM
GUARD AS.-OVERHEAD,2120MM
OVHG GP.
PANEL GP.-CONTROL
WIRING GP
SPARE PARTS
UL SAFETY
SEAT GROUP
CH/OV AR-BATT.SIDE ROLL IN OUT
CH/OV AR
CH/OV AR.
[CHASSIS] Driving Module
TIRE GROUP
[CHASSIS] Electric Power
BATTERY GP
BATTERY,48V/585AH(DRY)
BATTERY ASSY
CHANGEOVER AR
CHARGER GP-BATTERY
CHARGER,440V,3P-60HZ/540AH
CHARGER,380V,3P-50HZ/500~585AH
CHARGER,220V,3P,50HZ,500~585AH
CHARGER,380V,3P,50HZ,500~585AH
CHARGER,440V,3P,50HZ,500~585AH
CHARGER,220V,1P,50HZ,500~585AH
CHARGER GP; BATTERY
CHARGER,220V,3P-60HZ/540AH
CHARGER,380V,3P-60HZ/540AH
CONNECTOR GP
CONNECTOR GROUP;BATTERY
BATTERY ACCESSARY
ARRANGEMENT,CHANGEOVER
MOTOR ASSY,DRIVE
MOTOR ASSY,PUMP
BATTERY,LOCAL,48V,585AH
PUMP ASSY,WATER
[CHASSIS] Operating Module
ALARM GROUP
CABIN,D
VALVE ARRANGEMENT
VALVE SUB ASSY
VALVE ASSY,RELIEF
VALVE,CONTROL
BRACKET ASSY,VALVE
SWITCH ASSY
BRACKET,VALVE MOUNTING
EMERGENCY POWER DISCONNECT GP.
FRONT COCKPIT UNIT,BASIC
STEERING UNIT
INSTRUMENT GROUP
RESERVOIR
WHEEL GROUP
COVER GROUP
EXTINGUISHER ASSY,FIRE
EXTINGUISHER,FIRE
KNOB-STEERING WHEEL
LAMP ASSY,COMBINATION
LAMP ASSY
LAMP ASSY,HEAD
HARNESS GP
LAMP GROUP
LAMP AS-COMBI
LAMP
STROBE ASSY
CHANGEOVER AR.
MIRROR GP
OVERHEAD GUARD,2010MM
BAR
GRIP
SEAT BELT INTERLOCK GP
INTERLOCK GP
SEAT ASSY
SEAT,SUSPENSION
SEAT GROUP-GRAMMER
SEAT,OPERATOR
SEAT GP-GRAMMER
SEAT GROUP-AMA
SEAT
CONNECTOR
CH/OV AUTOTILT LEVELING
GSS GROUP
AUX. POWER PACKAGE GP.
CH/OV GSS
CH/OV GSS WO/AUTL
WEIGHT SACLE
CH/OV COLD STORAGE
STEERING GROUP
VALVE GROUP,CONTROL VALVE
WIRING GROUP
VALVE
REST,ARM
CABIN GROUP
CABIN ASSY,MODULAR
COVER ASSY,REAR
DOOR ASSY,SIDE
WIPER ASSY
CH/OV BLUE SPOT LIGHT
[FRONT END] Mast
ACCUMULATOR
ACCUMULATOR GROUP
PIPE GROUP
LINE GROUP,SIDE SHIFT
LINE GROUP,ATTACHMENT
HOSE GROUP,HYDRAULIC
PIPE ASSY
MAST ARRANGEMENT
MAST GROUP
HOSE,HYDRAULIC
LIFT GROUP,PRIMARY
LIFT GROUP
RELAY
MOUNTING GROUP
CYLINDER GROUP,LIFT
CYLINDER,PRIMARY
MOUNT GROUP,LIFT
PIN ASSY
RELAY ASSY
CYLINDER,LIFT
CYLINDER ASSY
LIFT GROUP,STANDARD
CYLINDER ASSY,TILT
MOUNT ASSY
LIFTER GROUP
[FRONT END] Fork
FORK EXTENSION GROUP
FORK CAP
FORK, ATTACHMENT
FORK
[FRONT END] Carriage
REST ASSY,BACK
BACKREST GP
LOAD BACKREST
BACKREST GP '1
CARRIAGE ARRANGEMENT
BEARING
CARRIAGE ARRANGEMENT,STANDARD
S/S & F/M, ATTACHMENT
FORK MOVER, ATTACHMENT
POSITIONER GROUP,FORK
FORK POSITIONER GROUP
CYLINDER,GAS
COUPLING GROUP
COUPLING,QUICK
SHIFT GROUP,SIDE
CARRIAGE GROUP
FORK,POSITIONAL
MOUNT
Brand: Doosan
Part Number: SB1189
[CHASSIS] Chassis
CYLINDER,STEERING
GENERAL AR.
COVER ASSY,SIDE
PANEL
BRACKET ASSY
HOOD GROUP
HOOD MODULE
CONTROL GROUP,BRAKE
MOUNT GROUP
PLATE ASSY,FLOOR
LINE GROUP
VALVE ASSY
VALVE,PRIORITY
TANK,HYDRAULIC
MODULE,BASIC
PUMP,GEAR
PUMP ASSY,MODULE
AXLE ASSY,STEER
AXLE GROUP,STEER
PANEL,CONTROL
CONTROLLER ASSY
CABLE GROUP
WIRE GROUP
BRAKE ASSY
CYLINDER,MASTER
MOUNTING GP.
STRAP
CYLINDER GROUP,TILT
TOOL GP
TELEMATICS SYSTEM
OVHG GP.
PANEL GP.-CONTROL
WIRING GP
SPARE PARTS
UL SAFETY
SEAT GROUP
CH/OV AR
CH/OV AR.
TIRE GROUP
BATTERY GP
BATTERY ASSY
CHANGEOVER AR
CHARGER GP-BATTERY
CHARGER GP; BATTERY
CONNECTOR GP
BATTERY ACCESSARY
MOTOR ASSY,DRIVE
MOTOR ASSY,PUMP
PUMP ASSY,WATER
ALARM GROUP
CABIN,D
VALVE ARRANGEMENT
VALVE SUB ASSY
VALVE ASSY,RELIEF
VALVE,CONTROL
BRACKET ASSY,VALVE
SWITCH ASSY
STEERING UNIT
INSTRUMENT GROUP
RESERVOIR
WHEEL GROUP
COVER GROUP
EXTINGUISHER,FIRE
KNOB-STEERING WHEEL
LAMP ASSY
LAMP ASSY,HEAD
HARNESS GP
LAMP GROUP
LAMP AS-COMBI
LAMP
STROBE ASSY
CHANGEOVER AR.
MIRROR GP
BAR
GRIP
INTERLOCK GP
SEAT ASSY
SEAT,SUSPENSION
SEAT GROUP-GRAMMER
SEAT,OPERATOR
SEAT GP-GRAMMER
SEAT GROUP-AMA
SEAT
CONNECTOR
GSS GROUP
CH/OV GSS
CH/OV GSS WO/AUTL
WEIGHT SACLE
CH/OV COLD STORAGE
STEERING GROUP
WIRING GROUP
VALVE
REST,ARM
CABIN GROUP
CABIN ASSY,MODULAR
COVER ASSY,REAR
DOOR ASSY,SIDE
WIPER ASSY
[FRONT END] Mast
ACCUMULATOR
ACCUMULATOR GROUP
PIPE GROUP
PIPE ASSY
MAST ARRANGEMENT
MAST GROUP
HOSE,HYDRAULIC
LIFT GROUP,PRIMARY
LIFT GROUP
RELAY
MOUNTING GROUP
CYLINDER GROUP,LIFT
CYLINDER,PRIMARY
MOUNT GROUP,LIFT
PIN ASSY
RELAY ASSY
CYLINDER,LIFT
CYLINDER ASSY
LIFT GROUP,STANDARD
CYLINDER ASSY,TILT
MOUNT ASSY
LIFTER GROUP
[FRONT END] Fork
FORK CAP
FORK, ATTACHMENT
FORK
REST ASSY,BACK
BACKREST GP
LOAD BACKREST
BACKREST GP '1
BEARING
CYLINDER,GAS
COUPLING GROUP
COUPLING,QUICK
SHIFT GROUP,SIDE
CARRIAGE GROUP
FORK,POSITIONAL
MOUNT
- DOOSAN Lift Trucks Model D20S-3, D25S-3, D30S-3, D32S-3, D33S-3 Parts Book
- DOOSAN Lift Trucks Model G20S-2, G25S-2, G30S-2 Parts Book
- DOOSAN Lift Trucks Model G35S-2, G40S-2, G45S-2, G50C-2, G40SC-2, G45SC-2, G50SC-2 Parts Book
- DOOSAN Lift Trucks Model D35S-2, D40S-2, D45S-2, D50C-2, D40SC-2, D45SC-2, D50SC-2 Parts Book
- Daewoo Lift Trucks Electric System Schematic
- Daewoo Lift Trucks G430 LP Engine Service Manual
- Doosan Forklift Service Manual G420FE LP/Dual Fuel Engine G420F LP/Gasoline Dual Fuel Engine
- Daewoo Lift Trucks Hydraulic System Schematic
- Daewoo Lift Trucks Diesel Engine 3.3 Liter (DB33A) Service Manual
- Doosan Forklift Service Manual G424FE LP/Dual Fuel Engine G424F LP Engine
- Daewoo Lift Trucks Power Train Disassembly & Assembly
- Daewoo Doosan Forklift G20S-3 G25S-3 G30S-3 Service Manual
- Doosan LIFT TRUCKS Operation & Maintenance Manual
- Daewoo Lift Trucks Vehicle Systems Specifications Systems Operation Testing & Adjusting
- Deawoo Doosan Forklift B20S-2 Operation Testing & Adjusting
