Doosan Forklift B15S5 B18S5 Spare Parts Catalog SB1086
Brand: Doosan
Type of Machine: Forklift, Electric 1 Ton PNEUMATIC, Electric Powered Truck
Model: Doosan B15S5, B18S5 Forklift
Part Number: SB1086
Number of Pages: 1372 Pages
[CHASSIS] Chassis
CYLINDER,STEERING
MOTOR ASSY,PUMP
PUMP,GEAR
PUMP ASSY,WATER
MOUNT GROUP
PUMP ASSY,HYDRAULIC
WEIGHT GROUP,COUNTER
WIRE GROUP
GENERAL AR.(48V)
TANK,HYDRAULIC
CONTROL GROUP,BRAKE
BRAKE ASSY
AXLE ASSY,STEER
AXLE GROUP,STEER
PANEL,CONTROL
PANEL ASSY,CONTROL
BRAKE GROUP,PARKING
LINE GROUP
VALVE ASSY
ARRANGEMENT,GENERAL
CONTROL GROUP
HOOD GROUP
PANEL
WIRING GROUP
CYLINDER,TILT
CYLINDER GROUP,TILT
TOOL GROUP
SPARE PARTS
FCU MTG.GP
TOOL GP
CONTROLLER ASSY
[CHASSIS] Driving Module
TIRE ASSY
ARRANGEMENT
TRANSFER ASSY
AXLE,DRIVE
BOX,GEAR
MOTOR ASSY,DRIVE
[CHASSIS] Electric Power
BATTERY ASSY
CELL ASSY
CHARGER ASSY,BATTERY
BATTERY AS
BATTERY GROUP
ARRANGEMENT,CHANGEOVER
MOTOR GROUP,DRIVE
BATTERY,NON EEC,48V,500AH
BATTERY,NON EEC,48V,450AH
BATTERY,NON EEC,48V,580AH
BATTERY GP
CONNECTOR GROUP;BATTERY
SWITCH,ELECTRIC
CONNECTER GROUP,BATTERY
MOTOR ASSY
MOTOR GROUP
CHARGER GP-BATTERY
CHARGER,380V,3P-50HZ/440~450AH
CHARGER,380V,3P-50HZ/500~585AH
CHARGER,220V,3P,50HZ,500~585AH
CHARGER,380V,3P,50HZ,400~460AH
CHARGER,380V,3P,50HZ,500~585AH
CHARGER,440V,3P,50HZ,400~460AH
CHARGER,440V,3P,50HZ,420~460AH
CHARGER,440V,3P,50HZ,500~585AH
CHARGER,220V,1P,50HZ,500~585AH
CHARGER,220V,3P,50HZ,400~460AH
CHARGER GP; BATTERY
CHARGER,220V,3P-60HZ
CHARGER,380V,3P-60HZ
CHARGER,440V,3P-60HZ
CHARGER,220V,3P-60HZ/540AH
CHARGER,380V,3P-60HZ/540AH
CHARGER,440V,3P-60HZ/540AH
[CHASSIS] Operating Module
TRAYGP
VALVE ARRANGEMENT
SWITCH ASSY
VALVE ASSY,RELIEF
VALVE,CONTROL
BRACKET ASSY,VALVE
BRACKET ASSY
VALVE SUB ASSY
BRACKET,VALVE MOUNTING
COVER GROUP
INSTRUMENT GROUP
FRONT COCKPIT UNIT
LAMP GROUP
LAMP ASSY
LAMP ASSY,HEAD
MIRROR GP
SEAT ASSY
SEAT
SEAT GROUP
REAR DETECTION GP.
CHANGEOVER AR.-3S/3L TO 4S/4L
COCKPIT UNIT,FRONT
STEERING GROUP
INSTALLATION
DOOR ASSY,REAR
CAMERA, REAR VIEW
SEAT GROUP-AMA
DISPLAY
STRAP
GUARD
FCU-BASIC
ALARM GROUP
EXTINGUISHER,FIRE
EXTINGUISHER ASSY,FIRE
KNOB-WHEEL
LAMP ASSY,COMBINATION
LAMP
STROBE ASSY
SEAT BELT INTERLOCK GP
CONNECTOR
[FRONT END] Mast
ACCUMULATOR GROUP
ACCUMULATOR
PIPE GROUP
LINE GROUP,SIDE SHIFT
LINE GROUP,ATTACHMENT
PIPE ASSY
HOSE GROUP,HYDRAULIC
MAST GROUP
RELAY
RELAY ASSY
MOUNT GROUP,LIFT
LIFTER GROUP
MOUNT ASSY
MAST ASSY
CYLINDER ASSY
LIFT GROUP,SECONDARY
CYLINDER,LIFT
CYLINDER,PRIMARY
MAST ARRANGEMENT
HOSE,HYDRAULIC
LIFT GROUP,PRIMARY
LIFT GROUP
MOUNTING GROUP
CYLINDER GROUP,LIFT
LIFT GROUP,STANDARD
[FRONT END] Fork
FORK, ATTACHMENT
FORK
FORK EXTENSION GROUP
FORK CAP
[FRONT END] Carriage
BEARING
REST ASSY,BACK
CYLINDER,GAS
SHIFT GROUP,SIDE
CARRIAGE GROUP
MOUNT
FORK,POSITIONAL
BACKREST;GROUP;;LOAD;
BACKREST GP
LOAD BACKREST
BACKREST GP '1
CARRIAGE ARRANGEMENT
CARRIAGE ARRANGEMENT,STANDARD
S/S & F/M, ATTACHMENT
FORK MOVER, ATTACHMENT
POSITIONER GROUP,FORK
FORK POSITIONER GROUP
LIFT,MOVEABLE HYDRAULIC
[MISCELLANEOUS] Location Chart
CHART,LOCATION
