Doosan Forklift B13R-5 B16R-5 Spare Parts Catalog SB1088Y
Brand: Doosan
Type of Machine: Forklift, Electric 1 Ton Family, Electric Powered Truck
Model: Doosan B13R-5, B16R-5 Forklift
Part Number: SB1088Y
Number of Pages: 452 Pages
Section 1
Chassis Component
Frame Gp - BSC
Lines Gp - P/S
Control Gp - Brake(P)
MTG Gp - Tilt
MTG Gp - Tank
Tank Gp
Priority Valve Gp
MTG Gp - Motor
Pump Motor - AC
MTG Gp - Pump
Pump - Hydraulic
Lines Gp - Tank
Lines Gp - Tilt
Control Gp - Brake(Service)
Lines Gp - Brake
FCU - Basic
Steering Gp - FCU
Control Gp - Parking, FCU
Cover Gp - FCU
RCU MTG BSC
MTG Gp - Drive Axle
Front Axle Ass’y - LH/RH
Control Gp - Accel
Floor Plate Gp
Panel Gp - Control
Controller Ass’y
Wiring Gp-B13R-5/B16R-5
Drive Gp - B13/16R-5
Transfar Assy
Motor Gp - Drive
Section 2
Capacity Module
Counterweight Gp
Panel Gp - Outer
Panel Gp - Top
OHG - Basic
Location Chart Part 1 of 2
Section 3
Option For Complete Truck
Wheel & Tire Gp - Solid - 1.0/1.3/1.5/1.6 Ton
Wheel & Tire Gp - Pneumatic - 1.0/1.3/1.5 Ton
Lamp Gp - Head(STD)
Seat Gp - Suspension, Non NACD
Seat Gp - Suspension Arm Rest, Non NACD
Seat Gp - Suspension, NACD
Static Seat Gp - Without Hip Restraint(Vinyl)
Static Seat Ass’y - STD(Vinyl)
Static Seat Gp - With Hip Restraint(Vinyl/Cloth)
Static Seat Ass’y - Hip Rest Type(Vinyl/Cloth/Non Logo)
Valve Ar. - 2 Section, 2 Lever
Valve Ass’y - 2 Section, 2 Lever
Valve Ar.-2 Section, 2 Lever(ISO3691)
Valve Ass’y-2 Section, 2 Lever(ISO3691)
Valve Ar. - 3 Section, 3 Lever
Valve Ass’y - 3 Section, 3 Lever
Valve Ar.-3 Section, 3 Lever(ISO3691)
Valve Ass’y-3 Section, 3 Lever(ISO3691)
Valve Ar. - 4 Section, 4 Lever
Valve Ass’y - 4 Section, 4 Lever
Valve Ar.-4 Section, 4 Lever(ISO3691)
Valve Ass’y-4 Section, 4 Lever(ISO3691)
Switch Gp
Bracket Ass’y - 2 Lever
Bracket Ass’y - 3 Lever
Bracket Ass’y - 4 Lever
Valve Gp - Control(2 Spool)
Valve Gp - Control(3 Spool)
Valve Gp - Control(4 Spool)
Section Gp - Valve
Block Assy;Lift
Block Assy;Tilt
Block Assy;Inlet
Block Assy;Aux
Connector Gp - Battery(SB TYPE-350, RED)
Connector Gp - Battery(SBE TYPE-350, RED)
Connector Gp - Battery, Emergency(SBE TYPE-320RED/350 RED)
Section 4
Option For General
Tray Gp
Mirror Gp
Lighting Gp
Lamp Ass’y - Head & Turn Signal(Halogen) - LH/RH
Lamp Ass’y - Head - LH/RH
Stand Gp
Tool Gp
Changeover Ar. - 3 Section 3 Lever To 4 Section 4 Lever
Mono Ped - Switch
Rear Grap Bar-With Horn
Changeover Ar - Battery Roll In Out
Valve Ar. - Fingertip
Lines Gp - 3 Way - Fingertip
Valve Gp-Fingertip-3 Way
Inlet Section Gp
Lift Section Gp
Tilt Section Gp
AUX Section Ass’y
Lines Gp - 4 Way - Fingertip
Valve Gp-Fingertip-4 Way
Hood Gp - Fingertip
Mount Gp - Armrest - 3 Way/4 Way
Armrest Ass’y - 3 Way/4 Way
Wiring Gp-Fingertip
Changeover Ar. - Cooling Fan Kit
Wiring Gp - Cooling Fan
Charger GP-220V-3P-50~60Hz-B13R/B16R-5
Charger GP-380V-3P-50~60Hz-B13R/B16R-5
Charger GP-440V-3P-50~60Hz-B13R/B16R-5
Battery Gp-B13R/B16R-5
Section 5
Mast - Hydraulic
MTG Gp - Mast - STD, FFT/FFL
Mounting Gp - Lift - STD
Mounting Gp - Lift - FFT
Mounting Gp - Lift - FFL
Lines Gp - ATT - Primary - STD - 3 Way
Lines Gp - ATT - Primary - STD - 4 Way
Lines Gp - ATT - Primary - FFL - 3 Way
Lines Gp - ATT - Primary - FFL - 4 Way
Lines Gp - ATT - Primary - FFT - 3 Way
Lines Gp - ATT - Primary - FFT - 4 Way
Lines Gp - ATT - Secondary - STD - 3 Way - RH
Lines Gp - ATT - Secondary - STD - 3 Way - LH
Lines Gp - ATT - Secondary - STD - 4 Way
Lines Gp - ATT - Secondary - FFT - 3 Way - RH
Lines Gp - ATT - Secondary - FFT - 3 Way - LH
Lines Gp - ATT - Secondary - FFT - 4 Way
Lines Gp - ATT - Secondary - FFL - 3 Way - RH
Lines Gp - ATT - Secondary - FFL - 3 Way - LH
Lines Gp - ATT - Secondary - FFL - 4 Way
Lines Gp - ATT - Sideshift - STD
Lines Gp - ATT - Sideshift - FFL & FFT
Cylinder Gp - Tilt(Basic)
Section 6
Mast - Implements
Mast Gp - Basic - STD, FFL
Mast Gp - Basic - FFT
Mast Ass’y - STD
Mast Ass’y - FFT
Mast Ass’y - FFL
Relay Gp - Lift - STD
Relay Gp - Lift - FFT
Relay Gp - Lift - FFL
Lift Gp - Secondary Cylinder - STD
Lift Gp - Secondary Cylinder - FFT
Lift Gp - Secondary Cylinder - FFL
Lift Gp - Primary Cylinder - FFT
Lift Gp - Primary Cylinder - FFL
Carriage Gp - STD, FFT, FFL
Mounting Gp - Carriage
Side Shifter Gp
Cylinder Ass’y - Side Shifter
Load Backrest
Integral Shifting - Fork Positioner Part 2 of 2
Integral Side Shifter Part 1 of 2
Carriage Gp - STD/FFL/FFT
Side Shifter Cylinder
Lines Gp - STD
Lines Gp - FFL, FFT
Mounting Gp - Fork Positioner
Cylinder Ass’y
Lines Gp - Carriage - STD
Lines Gp - Carriage - FFL
Lines Gp - Carriage - FFT
Backrest Gp - Fork Positioner
Fork Group
Brand: Doosan
Section 1
Chassis Component
Frame Gp - BSC
Lines Gp - P/S
MTG Gp - Tilt
MTG Gp - Tank
Tank Gp
Priority Valve Gp
MTG Gp - Motor
Pump Motor - AC
MTG Gp - Pump
Pump - Hydraulic
Lines Gp - Tank
Lines Gp - Tilt
Lines Gp - Brake
FCU - Basic
Steering Gp - FCU
Cover Gp - FCU
RCU MTG BSC
MTG Gp - Drive Axle
Control Gp - Accel
Floor Plate Gp
Panel Gp - Control
Controller Ass’y
Transfar Assy
Motor Gp - Drive
Section 2
Capacity Module
Counterweight Gp
Panel Gp - Outer
Panel Gp - Top
OHG - Basic
Section 3
Lamp Gp - Head(STD)
Switch Gp
Section Gp - Valve
Block Assy;Lift
Block Assy;Tilt
Block Assy;Inlet
Block Assy;Aux
Section 4
Option For General
Tray Gp
Mirror Gp
Lighting Gp
Stand Gp
Tool Gp
Mono Ped - Switch
Inlet Section Gp
Lift Section Gp
Tilt Section Gp
AUX Section Ass’y
Hood Gp - Fingertip
Wiring Gp-Fingertip
Section 5
Mast - Hydraulic
Section 6
Mast - Implements
Mast Ass’y - STD
Mast Ass’y - FFT
Mast Ass’y - FFL
Side Shifter Gp
Load Backrest
Lines Gp - STD
Lines Gp - FFL, FFT
Cylinder Ass’y
Fork Group
- DOOSAN Lift Trucks Model D20S-3, D25S-3, D30S-3, D32S-3, D33S-3 Parts Book
- DOOSAN Lift Trucks Model G20S-2, G25S-2, G30S-2 Parts Book
- DOOSAN Lift Trucks Model G35S-2, G40S-2, G45S-2, G50C-2, G40SC-2, G45SC-2, G50SC-2 Parts Book
- DOOSAN Lift Trucks Model D35S-2, D40S-2, D45S-2, D50C-2, D40SC-2, D45SC-2, D50SC-2 Parts Book
- Daewoo Lift Trucks Electric System Schematic
- Daewoo Lift Trucks G430 LP Engine Service Manual
- Doosan Forklift Service Manual G420FE LP/Dual Fuel Engine G420F LP/Gasoline Dual Fuel Engine
- Daewoo Lift Trucks Hydraulic System Schematic
- Daewoo Lift Trucks Diesel Engine 3.3 Liter (DB33A) Service Manual
- Doosan Forklift Service Manual G424FE LP/Dual Fuel Engine G424F LP Engine
- Daewoo Lift Trucks Power Train Disassembly & Assembly
- Daewoo Doosan Forklift G20S-3 G25S-3 G30S-3 Service Manual
- Doosan LIFT TRUCKS Operation & Maintenance Manual
- Daewoo Lift Trucks Vehicle Systems Specifications Systems Operation Testing & Adjusting
- Deawoo Doosan Forklift B20S-2 Operation Testing & Adjusting
