Doosan Forklift B10R5 B13R5 B15R5 B16R5 Spare Parts Catalog SB1088
Brand: Doosan
Type of Machine: Forklift, Electric 1 Ton Family, Electric Powered Truck
Model: Doosan B10R5, B13R5, B15R5, B16R5 Forklift
Part Number: SB1088
Number of Pages: 503 Pages
Section 1
Chassis Component
Frame Gp - BSC
Battery Roll Out Gp
Lines Gp-P/S
Control Gp-Brake - (P)
MTG Gp-Tilt
MTG Gp-Tank
Tank Gp
Priority Valve Gp
MTG Gp-Motor
Pump Motor - AC
MTG Gp-Pump
Pump-Hydraulic
Lines Gp-Tank
Lines Gp-Tilt
Lines Gp-Tilt (ISO 3691 C/V)
Control Gp-Brake - (Service)
Lines Gp-Brake
FCU - Basic
Steering Gp - FCU
Control Gp-Parking
Cover Gp
RCU MTG - BSC
MTG Gp-Drive Axle
Front Axle - LH
Front Axle - RH
Control Gp-Accel
Floor Plate Gp
Panel Gp-Control
Controller Ass’y
Wiring Gp
Drive Gp - B10/13R-5
Drive Gp - B15/16R-5
Drive Axle
Transfar Assy
Motor Gp-Drive - (B)
Motor Gp-Drive
Section 2
Capacity Module
Counterweight Gp
Panel Gp - Outer
Panel Gp-Top
OHG - Basic
Location Chart - Part 1 of 2
Location Chart - Part 2 of 2
Section 3
Option For Complete Truck
Wheel & Tire Gp - Solid-1.0/1.3/1.5/1.6 Ton
Wheel & Tire Gp - Pneumatic-1.0/1.3/1.5 Ton
Lamp Gp-Head - (STD)
Seat Gp-Suspension - Non NACD
Seat Gp-Suspension Arm Rest
Seat Gp-Suspension - NACD
Seat Gp-Suspension
Static Seat Gp - Without Hip Restraint(Vinyl)
Seat As-Static - STD(Vinyl)
Static Seat Ass’y
Static Seat Gp - With Hip Restraint(Cloth)
Static Seat Gp - With Hip Restraint(Vinyl)
Seat Ass’y-Static - Hip Rest Type(Cloth/Non Logo)
Seat Ass’y-Static - Hip Rest Type(Vinyl)
Valve Ar.-2 Section, 2 Lever
Valve Ass’y-2 Section, 2 Lever
Valve Ar.-2 Section, 2 Lever(ISO3691)
Valve Ass’y-2 Section, 2 Lever(ISO3691)
Valve Ar.-3 Section, 3 Lever
Valve Ass’y-3 Sec, 3 Lever
Valve Ar.-3 Section, 3 Lever(ISO3691)
Valve Ass’y-3 Section, 3 Lever(ISO3691)
Valve Ar.-4 Section, 4 Lever
Valve Ass’y-4 Sec, 4 Lever
Valve Ass‘y - 4Section, 4Lever
Valve Ar.-4 Section, 4 Lever(ISO3691)
Valve Ass’y-4 Section, 4 Lever(ISO3691)
Switch Gp
Bracket Ass’y-2 Lever
Bracket Ass’y-3 Lever
Bracket Ass’y-4 Lever
Valve Gp-Control(2 Spool)
Valve Gp-Control(3 Spool)
Valve Gp-Control(4 Spool)
Section Gp-Valve
Block Ass‘y-Lift
Block Ass‘y-Tilt
Block Ass‘y-Inlet
Bolck Ass’y;AUX
Connector Gp-Battery - (SB TYPE-350, RED)
Connector Gp-Battery, Emergency - (SBE TYPE-320, RED)
Connector Gp-Battery, Emergency - (SBE TYPE-350, RED)
Valve Gp-Control(2 Spool)ISO3691
Valve Gp-Control(3 Spool)ISO3691
Valve Gp-Control(4 Spool)ISO3691
Block Ass‘y-Inlet(ISO3691)
Main Relief Valve(ISO3691)
Block Ass‘y-Lift(ISO3691)
Section 4
Option For General
Tray Gp
Mirror Gp
Lighting Gp
Lamp Ass’y-Comb - RH
Lamp Ass’y-Head & Turn Signal - (Halogen)-LH
Lamp Ass’y-Head - LH
Lamp Ass’y-Head - RH
Stand Gp
Tool Gp
Changeover Ar.-3 Section 3 Lever To 4 Section 4 Lever
Mono Ped-Switch
Rear Grap Bar - With Horn
Changeover Ar-Battery Roll In Out
Valve Ar.-Fingertip
Lines Gp-3 Way-Fingertip
Valve Gp-Fingertip-3 Way
INLET SECTION GP
Lift Section Gp
Tilt Section Gp
AUX Section Ass’y
Lines Gp-4 Way-Fingertip
Valve Gp-Fingertip-4 Way
Hood Gp-Fingertip
Mount Gp-Armrest-3 Way
Mount Gp-Armrest-4 Way
Armrest Ass’y-3 Way
Armrest Ass’y-4 Way
Wiring Gp - Fingertip
Changeover AR.-Cooling Fan Kit
Section 5
Mast Hydrulic
MTG Gp-Mast - FFL
MTG Gp-Mast - STD, FFT
Mounting Gp-Lift - STD
Mounting Gp-Lift - FFT
Mounting Gp-Lift - FFL
Lines Gp-ATT-Primary-3 Way - STD
Lines Gp-ATT-Primary-4 Way
Lines Gp-ATT-Primary-3 Way - FFL
Lines Gp-ATT-Primary-3 Way - FFT
Lines Gp-ATT-Secondary-3 Way - STD-RH
Lines Gp-ATT-Secondary-3 Way - STD-LH
Lines Gp-ATT-Secondary-4 Way - STD
Lines Gp-ATT-Secondary-3 Way - FFT-RH
Lines Gp-ATT-Secondary-3 Way - FFT-LH
Lines Gp-ATT-Secondary-4 Way - FFT
Lines Gp-ATT-Secondary-3 Way - FFL-RH
Lines Gp-ATT-Secondary-3 Way - FFL-LH
Lines Gp-ATT-Secondary-4 Way - FFL
Lines Gp-ATT-Sideshift - STD
Lines Gp-ATT-Sideshift - FFL & FFT
Cylinder Gp-Tilt - (Basic)
Section 6
Mast-Implements
Mast Gp - Basic-STD, FFL
Mast Gp - Basic-FFT
Mast Ass’y - STD
Mast Ass’y - FFT
Mast Ass’y - FFL
Relay Gp-Lift - STD
Relay Gp-Lift - FFT
Relay Gp-Lift - FFL
Lift Gp-Secondary Cylinder - STD
Lift Gp-Secondary Cylinder - FFT
Lift Gp-Secondary Cylinder - FFL
Lift Gp-Primary Cylinder - FFT
Lift Gp-Primary Cylinder - FFL
Carriage Gp - STD, FFT, FFL
Mounting Gp-Carriage
Side Shifter Gp
Cylinder Ass’y - Side Shifter
Load Backrest
Integral Shifting-Fork Positioner - Part 2 of 2
Integral Side Shifter - Part 1 of 2
Carriage Gp - FFL
Carriage Gp - FFT
Carriage Gp - STD
Side Shifter Cylinder
Lines Gp - STD
Lines Gp - FFL, FFT
Mounting Gp-Fork Positioner
Cylinder Ass’y
Lines Gp-Carriage - STD
Lines Gp-Carriage - FFL
Lines Gp-Carriage - FFT
Backrest Gp-Fork Positioner
Fork Group
Brand: Doosan
Part Number: SB1088
Section 1
Chassis Component
Frame Gp - BSC
Battery Roll Out Gp
Lines Gp-P/S
MTG Gp-Tilt
MTG Gp-Tank
Tank Gp
Priority Valve Gp
MTG Gp-Motor
Pump Motor - AC
MTG Gp-Pump
Pump-Hydraulic
Lines Gp-Tank
Lines Gp-Tilt
Lines Gp-Brake
FCU - Basic
Steering Gp - FCU
Control Gp-Parking
Cover Gp
RCU MTG - BSC
MTG Gp-Drive Axle
Front Axle - LH
Front Axle - RH
Control Gp-Accel
Floor Plate Gp
Panel Gp-Control
Controller Ass’y
Wiring Gp
Drive Axle
Transfar Assy
Motor Gp-Drive
Section 2
Capacity Module
Counterweight Gp
Panel Gp - Outer
Panel Gp-Top
OHG - Basic
Section 3
Seat Gp-Suspension
Static Seat Ass’y
Switch Gp
Section Gp-Valve
Block Ass‘y-Lift
Block Ass‘y-Tilt
Block Ass‘y-Inlet
Bolck Ass’y;AUX
Section 4
Option For General
Tray Gp
Mirror Gp
Lighting Gp
Stand Gp
Tool Gp
Mono Ped-Switch
Valve Ar.-Fingertip
INLET SECTION GP
Lift Section Gp
Tilt Section Gp
AUX Section Ass’y
Hood Gp-Fingertip
Armrest Ass’y-3 Way
Armrest Ass’y-4 Way
Section 5
Mast Hydrulic
MTG Gp-Mast - FFL
Section 6
Mast-Implements
Mast Gp - Basic-FFT
Mast Ass’y - STD
Mast Ass’y - FFT
Mast Ass’y - FFL
Relay Gp-Lift - STD
Relay Gp-Lift - FFT
Relay Gp-Lift - FFL
Side Shifter Gp
Load Backrest
Carriage Gp - FFL
Carriage Gp - FFT
Carriage Gp - STD
Lines Gp - STD
Lines Gp - FFL, FFT
Cylinder Ass’y
Fork Group
- DOOSAN Lift Trucks Model D20S-3, D25S-3, D30S-3, D32S-3, D33S-3 Parts Book
- DOOSAN Lift Trucks Model G20S-2, G25S-2, G30S-2 Parts Book
- DOOSAN Lift Trucks Model G35S-2, G40S-2, G45S-2, G50C-2, G40SC-2, G45SC-2, G50SC-2 Parts Book
- DOOSAN Lift Trucks Model D35S-2, D40S-2, D45S-2, D50C-2, D40SC-2, D45SC-2, D50SC-2 Parts Book
- Daewoo Lift Trucks Electric System Schematic
- Daewoo Lift Trucks G430 LP Engine Service Manual
- Doosan Forklift Service Manual G420FE LP/Dual Fuel Engine G420F LP/Gasoline Dual Fuel Engine
- Daewoo Lift Trucks Hydraulic System Schematic
- Daewoo Lift Trucks Diesel Engine 3.3 Liter (DB33A) Service Manual
- Doosan Forklift Service Manual G424FE LP/Dual Fuel Engine G424F LP Engine
- Daewoo Lift Trucks Power Train Disassembly & Assembly
- Daewoo Doosan Forklift G20S-3 G25S-3 G30S-3 Service Manual
- Doosan LIFT TRUCKS Operation & Maintenance Manual
- Daewoo Lift Trucks Vehicle Systems Specifications Systems Operation Testing & Adjusting
- Deawoo Doosan Forklift B20S-2 Operation Testing & Adjusting
