Hyundai
86
176,834
Dongfeng Light Commercial Truck DFA1101GZ5AD6J-907 Service Manual
Brand: Dongfeng
Type of Machine: Light Commercial Truck
Model: Dongfeng DFA1101GZ5AD6J-907 Light Commercial Truck
Publication Date: 2006
Number of Pages: 175 Pages
INDEX
General Principles
Operational Instruction​
Standard Terms​
Standard Tightening Torque​
Maintenance Rule​
Recommended Fuel and Lubricant​
Protective Measures while Repairing​
Cleaning​
General Inspection​
Clutch
Main Parameter​
Clutch Mechanical System​
Adjustment of Clutch Pedal​
Clutch Cover and Flywheel​
Usage and Maintenance​
Propeller Shaft
Technical Parameter​
Maintenance Standard​
Tightening Torque​
Trouble Analysis​
Propeller Shaft​
Intermediate Propeller and Center Bearing​
Propeller Shaft Maintenance​
Maintain​
Disassembly and Assembly​
Check​
Steering Wheel and Steering Column​
Power Steering Hydraulic Pressure System​
Steering Gear​
Front Axle
Structure​
Disassembly of the Front Brake​
Maintenance
First maintain​
Periodical maintain​
Periodical Maintain Schedule​
Assembly and Adjustment​
Appendix 1 Lubricating Parts and Lubricant​
Appendix 2 Tightening Torque of the Bolts and Nuts​
Appendix 3 Main Adjusting Data and Maintaining Standard​
Rear Axle
Tightening Torque of Important Bolts and Nuts​
Suspension System
Suspension
Disassembly​
Assembly​
Trouble Analysis of Wheel Brake​
Front Brake​
Rear Brake​
Frame Brake Pipeline​
Cab Brake Pipeline​
Hand Control Valve Control System​
Precautions​
Clip and Fastener​
Cab Front Panel​
Door​
Instrument Panel​
Cab Internal Trims and External Trims​
Seat​
Cab Mounting​
Cab​
Chassis Frame
Chassis Frame​
Air-conditioner and Heater
Exhaust the refrigerant of the air-conditioner​
Note:​
Remove and Install the Air-conditioner​
The Maintenance of the Compressor​
Construction of the Heater​
Air Flowing Direction​
Check the Leakage of the Refrigerant​
Air-conditioning System​
Schematic Circuit of Air-condition System​
Electric and Instrument
EL​
Specification​
Bulb Type​
General Instruction​
Battery​
Alternator​
Starting Division​
Electromagnetic Main Power Switch
Exhaust Brake System
Hazard Warning System​
Accessories​
Horn​
Fog Lamps
Instruments​
Speedometer​
Tachometer
Water Temperature Meter and Fuel Meter​
