DIACOM Marine 3.3.8 2023 Diagnostic Software
Type of Software: Diagnostic Software
Type of Machine: Marine Engine, Marine Equipment
Windows: Windows 7, Windows 10, Windows 11 x32, Windows 10 x64bit
Database update: 25-04-2023
High-Speed Link Download
This is software only
After downloading send to email "autorepairmanuals.ws@gmail.com, admin@autorepairmanuals.ws" to get the password
What's New in Version 3.38
Mercury / MerCruiser / Mercury Racing G3 2023 engine diagnostics: Version 3.38 supports G3 CAN based engine diagnostics through January 2023. Support added for the latest Mercury and Mercury Racing outboards as well as MerCruiser sterndrive and inboard engines. The latest engine support requires Diacom USB cable #94073 with a minimum cable software revision of 35. Note: G3 CAN based engine diagnostics require both adapters 94029 and 94032.
▪ Update For MEFI-7 Equipped Engines: Version 3.38 updates support for direct injected engines utilizing GM-Delphi's MEFI-7
control system. This release adds an injector balance test allowing the comparison of direct injector fuel flow performance. The injector balance test feature requires Diacom USB cable #94073 with a minimum cable software revision of 35.
▪ Update For Indmar Engines: Version 3.38 updates support for Indmar's direct injected 2.3L Ford EcoBoost engine
Example pictures for adapters
Diacom supports MerCruiser, Mercury Outboards, Volvo Penta, Indmar, Pleasurecraft Marine, Crusader, Ilmor, Marine Power, Kodiak, Flagship Marine, GM RamJet Engines and more. The Diacom PC based diagnostic system gives you the power and flexibility you need to troubleshoot today’s advanced marine EFI systems. Diacom Marine supports the broadest range of engines in the industry providing superior coverage in a single diagnostic tool. Harness the power of your Windows based notebook or netbook PC to diagnose EFI system problems quickly and accurately.
FEATURES:
Diacom CD, USB cable, and the following network adapters:
The Diacom® PC based marine diagnostic system gives you the power and flexibility you need to troubleshoot today’s advanced EFI systems. DIACOM® unlocks the computing power of your Windows-based notebook or netbook PC and provides state-of the-art features to pinpoint EFI system problems quickly and accurately. In addition to supporting sterndrive and inboard marine engines, DIACOM® now supports Mercury outboards.
ADAPTOR COMPATIBILITY:
Marine Power
FEATURES:
- View EFI system data to monitor engine performance
- Read and reset system fault codes
- Exercise outputs and run EFI system tests
- Record live EFI data to capture elusive intermittent events
- Print hardcopy reports and export data to other PC programs
- ECM reflash capability for factory authorized marine dealers
- Plus many other troubleshooting and productivity features
- Diacom CD
- USB cable
- 94005 MEFI network adapter
- 94006 PCM-555 network adapter
- 94029 CAN network adapter
Marine Power
- 1992 - Up GM EFI engines: 1992 - 2008 (GM MEFI-1 thru MEFI-4) Adapter #94005 2008-Up (GM MEFI-5, MEFI-6, MEFI-7) Adapter #94023 or #94029
- 1992 - Up EFI engines: 1992 thru 2000 (GM MEFI-1 thru MEFI-4) Adapter #94005 2001 - Up (PCM-555 / ECM-555) Adapter #94006 2008 - Up (PCM-09) (OBD-M diagnostics) Adapter #94023 or #94029 2008 - Up (PCM-09) (G3 factory diagnostics) Adapter #94029 + #94032
- 1996-up Carbureted engines with Thunderbolt V ignition: All models Adapter #94020
- 1997 - 2007 2.8L 4-cylinder, 4.2L 6-cylinder Adapter #94014
- 1997 - 2005 7.3L V8 Adapter #94021
- 1998 - Up EFI engines: 1998 - Up HP500 GM MEFI equipped Adapter #94005 2001-up PCM-555 equipped Adapter #94006 2010-up PCM-09 equipped Adapter #94029 + #94032
- 2006 - Up Verado I-6: All models: Adapter #94006
- 2018 - Up Verado V8: All models: Adapter #94029 + #94032
- 2002 - Up 4-stroke EFI: 25hp, 30hp (Tohatsu EFI) Adapter #94039 40hp, 50hp, 60hp, (ECM-555)
- 2002-05 Adapter #94028 40hp, 50hp, 60hp, (ECM-555) (2006-09) Adapter #94006 40hp, 50hp, 60hp, (ECM-70)
- 2010-Up Adapter #94029 + #94032 75hp, 90hp, 115hp (Yamaha EFI) Adapter #94038 75hp, 90hp, 115hp (ECM-555)
- 2007-13 Adapter #94006 75hp, 90hp, 115hp (ECM-70) (
- 2014-Up Adapter #94029 + #94032 150hp (non-Verado) (ECM-70) (2012-Up) Adapter #94029 + #94032 175-300hp V6 and V8 (PCM-112)
- 2018-Up Adapter #94029 + #94032
- 1998 - Up 4-stroke carbureted: 25hp, 30hp, 40hp, 50hp, 60hp Adapter #94011 + #940372001 - Up Optimax: 2001 thru approx 2006 Adapter #94028 2007 - Up Adapter #94006
- 1998 - 2000 DFI: All models Adapter #94028
- 1994 - Up 2-stroke EFI: 1994 - Up 150hp, 175hp, 200hp, 225hp Adapter #94028 1994 - 1999 225hp(3.0L) Adapter #94011 • 1994 - 1999 2-stroke carbureted: 225hp/(3.0L) Adapter #94011
- 1995-Up Racing 2-stroke EFI: 150hp, 200hp, 225hp, 2.5L, 280hp, 300hp, Contact Us Optimax XS series
- 1992 - Up Gasoline EFI engines: 1992 - 2005 (GM MEFI-1 thru MEFI-4) Adapter #94005 2006 - 2007 (EGC) Adapter #94024 2008 - Up (EGC) Adapter #94023 or 94029
- 1992 - Up EFI engines: 1992 - 2006 (GM MEFI equipped) Adapter #94005 2007 - 2009 (ECM-07 equipped) Adapter #94026 2008 - Up (ECM-08 equipped) Adapter #94023 or 94029
- 1992 - Up GM EFI engines: GM MEFI-1 thru MEFI-4 equipped Adapter #94005 GM MEFI-5, MEFI-6, MEFI-7 Adapter #94023 or #94029 Ilmor Marine Engines
- 2009 - Up V10 engines: MV-650, MV-725 Adapter #94023 or #94029
- 2010-Up V8 engines: All models Adapter #94023 or #94029
- 1992 - Up EFI engines: 1992 - 2006 (GM MEFI-1 thru MEFI-4) Adapter #94005 2007-Up All models Adapter #94023 or #94029 Kodiak Marine
- 1992 - Up GM EFI engines: 1992 - 2008 (GM MEFI-1 thru MEFI-4) Adapter #94005 2008-Up (GM MEFI-5, MEFI-6, MEFI-7) Adapter #94023 or #94029 Malibu
- 2018 - Up EFI engines: All models Adapter #94023 or #94029
- 2000 - Up GM EFI engines: Engines equipped with MEFI 1 thru 6 EFI systems GM MEFI-1 thru MEFI-4 equipped Adapter #94005 GM MEFI-5, MEFI-6, MEFI-7 Adapter #94023 or #94029
- 2012 - Up Outboard EFI engines: All models Adapter #94023 or #94029
- 2000 - Up EFI engines: RamJet 350, RamJet 502 Adapter #94005 TurnKey Engines
- 2001 - Up MEFI Engines Engines equipped with MEFI 1 thru 6 EFI systems GM MEFI-1 thru MEFI-4 equipped Adapter #94005 GM MEFI-5 Adapter #94023 or #94029
