Momed80
150
35,046
Deutz-Fahr Tractor Agrotron 160 175 200 Wiring Diagram
Brand: Deutz-Fahr
Model: Deutz-Fahr AGROTRON 160, AGROTRON 175, AGROTRON 200 Tractor
Chassis Numbers: 8029/0001, 8029/0002, 8030/0001,
8030/0002, 8031/0001, 8031/0002, 8031/0003,
8031/0004, 8031/0005, 8031/0006
Number of Pages: 161 Pages
1 Safety
2 General information
2.1 Abbreviations.
2.2 Connector position.
3 Survey fuses, relays and fuse board
3.1 Fuses
3.2 Relays
3.3 Cable set connectors fuse board
4 Survey cable sets
4.1 Cable set engine.
4.2 Cable set control console
4.3 Cable set transmission
4.5 Cable set roof
4.6 Cable set instrument panel
4.7 Cable set turn signal and position light left
4.8 Cable set turn signal and position light right
4.9 Cable set illumination left rear
4.10 Cable set illumination right rear
4.11 Cable set compressed air system body.
4.12 Cable set air conditioning system
4.13 Cable set illumination vehicle identification plate left/right
4.14 Cable set multi-purpose switch lever.
4.15 Cable set wiper front
4.16 Cable set suspended front axle
4.17 Cable set worklights rear
5 Wiring diagrams
Starter switch
Starter system
Preheating system
Side lights
Low beam/high beam, headlights at front grill.
Auxiliary top headlights, switches and fuses
Worklights front top
Worklights rear
Worklights TSPL front
Rotary flasher
Brake light
Turn signal/hazard warning light, hazard flashlight transmitter and fuses
Turn signal/hazard warning light, switch and flashlights
Internal light, radio system.
Console lighting.
ASM functions
Four-wheel drive/Differential lock
Screen washer and wiper system front
Screen wiper motor, front
Screen wiper motor, rear
Screen washer and wiper system rear
Radio
Driver's seat, socket (cigar lighter)
High current connector 25 A, P.T.O.-shaft (speed measurement)
Signal horn, time clock.
Suspended front axle
Fresh air blower and air-conditioning system
Engine with Deutz electronic rpm control
Engine with Deutz electronic rpm control and 25-pin connector
Electronic hand throttle with memory function (Deutz electronic engine rpm control)
EMR Deutz
Electronic hand throttle with memory function (Same electronic engine rpm control)
Engine with Same electronic rpm control.
Engine speed, engine temperature, engine oil pressure.
Air cleaner, radar sensor
Current supply INFOCENTER and POWERSHIFT
Compressed air display, POWERSHIFT display
P.T.O. rear/front.
Signal sockets
Automatic POWERSHIFT transmission
AGROTRONIC -hD...
Multi-purpose switch lever
Armrest
Hydraulic trailer brake (Italy) with pedal operated parking brake
6 Survey cable set connectors.
7 Survey indication functions and pin occupation INFOCENTER
8 Transmission, engine
8.1 Transmission error
8.2 Same electronic rpm control
8.3 Sensors used
9 Sensors
10 P.T.O. disconnection upon disengaging the lifting system
11 Glowing time controller
