Hyundai
86
176,834
Deutz-Fahr Tractor 5650 H COM 3 to 5695 HTS COM 3 Workshop Manual 2015
Brand: Deutz-Fahr
Type of Manual: Workshop Manual, Electric and Hydraulic Diagrams
Model: Deutz-Fahr
5650 H COM 3 ->13500
5660 H COM 3 ->13500
5660 HTS COM 3 ->13500
5665 HTS COM 3 ->13500
5690 H COM 3 ->13500
5690 HTS COM 3 ->13500
5695 HTS COM 3 ->13500
Publication Date: 2015
Number of Pages: 1110 Pages
0 - Introduction
0.1 - General Safety Instructions​
0.2 - Safety Instructions - Maintenance And Repair​
10 - General Information
10.1 - Conversion Tables​
10.2 - Tightening Values, Screwing Classes​
10.3 - Lubricants​
10.4 - Seal Materials​
10.5 - One-Component Adhesive​
10.6 - Maintenance And Inspection Schedule​
10.7 - Oil Quantity And Quality​
10.8 - Approved List Of Lubricating Oil Quality Class - Deutz​
10.9 - Components Working Speed​
10.10 - Securing Bush Support Tightening Values​
10.11 - Check The Tension Of The Belts And Chains On The Lh Side​
10.12 - Check The Tension Of The Belts And Chains On The Rh Side​
10.13 - Maintenance And Repair​
10.14 - Care And Maintenance​
10.15 - Special Tools​
20 - Engine
20.1 - Tools For Engine Disassembly And Reassembly​
20.2 - Workshop Tools For Engine Disassembly And Reassembly (Lv.3)​
20.3 - Test And Adjustment Data (L3)​
20.4 - Tightening Torque (L3)​
20.5 - Check The Compression Value (L3)​
20.6 - Assembly And Disassembly Of The Engine On The Assembly Stand (L3)​
20.7 - Valve Clearance Adjustment (L3)​
20.8 - Disassembly And Assembly Of The Rocker And Support (L3)​
20.9 - Removing And Refitting The Rocker And Mount, Checking (L3)​
20.10 - Grinding The Cylinder Head Seal Surface (L3)​
20.11 - Disassembly And Assembly Of The Cylinder Head (L3)​
20.12 - Measuring Piston Protrusion (L3)​
20.13 - Valve Assembly And Disassembly (L3)​
20.14 - Valve Check (L3)​
20.15 - Check The Valve Guide (L3)​
20.16 - Replacing The Valve Guide (Oversized - Press-Fit) (L3)​
20.17 - Check The Valve Residual (L3)​
20.18 - Replacing The Lined Valve Seat (Oversized) (L3)​
20.19 - Check The Endfloat Of The Crankshaft (Crankshaft Removed) (L3)​
20.20 - Check The Endfloat Of The Crankshaft (Crankshaft Installed) (L3)​
20.21 - Crankshaft Check (L3)​
20.22 - Replace The Crankshaft O-Ring (Flywheel End) (L3)​
20.23 - Replace The Crankshaft O-Ring (Opposite End To Flywheel) (L3)​
20.24 - Connecting Rod Drum Check (L3)​
20.25 - Fitting And Removing Piston Pin Bush (L3)​
20.26 - Assembly And Disassembly Of The Crankshaft (L3)​
20.27 - Disassembly And Assembly Of The Piston And Connecting Rod Drum (L3)​
20.28 - Check The Piston (L3)​
20.29 - Check The Piston Rings And Piston Grooves (L3)​
20.30 - Fitting And Removing Piston Cooling Nozzle (L3)​
20.31 - Removing And Fitting Crankcase Breather (Oil Separator) (L3)​
20.32 - Checking The Cylinder Sleeve (L3)​
20.33 - Fitting And Removing The Cylinder Sleeve (L3)​
20.34 - Checking Cylinder Sleeve Protrusion (L3)​
20.35 - Removing And Fitting Ancillary Mount (L3)​
20.36 - Removing And Fitting Ancillary Mount (L3)​
20.37 - Removing And Refitting Rear Cover (L3)​
20.38 - Disassembly And Assembly Of The Connector Box (L3)​
20.39 - Correcting Contact Points Of Cylinder Sleeve (L3)​
20.40 - Fitting And Removing The Camshaft Bearings, Checking (L3)​
20.41 - Fitting And Removing Tappets, Checking Tappet Holes (L3)​
20.42 - Disassembly And Assembly Of The Gear Case Cover (L3)​
20.43 - Disassembly And Assembly Of The Gear Case Cover (L3)​
20.44 - Assembly And Disassembly Of The Camshaft (L3)​
20.45 - Check The Camshaft (L3)​
20.46 - Fitting And Removing The Injection Pump Camshaft (L3)​
20.47 - Replace The Crankshaft O-Ring (Flywheel End)​
20.48 - Fitting And Removing Seal Seat​
20.49 - Removal And Refitting Of The Oil Sump Pan.​
20.50 - Disassembly And Assembly Of The Lubricant Oil Sump (L3)​
20.51 - Disassembly And Assembly Of The Lubricant Oil Sump (L3)​
20.52 - Assembly And Disassembly Of The Flywheel (L3)​
30 - Engine Accessories
30.1 - Fitting And Removing The Rotation Tool (L3)​
30.2 - Removing And Fitting The Exhaust Manifold (L3)​
30.3 - Removing And Fitting The Exhaust Manifold​
30.4 - Removing And Fitting The Exhaust Manifold (Bank B) (L3)​
30.5 - Disassembly And Assembly Of The Turbocharging Air Duct (L3)​
30.6 - Disassembly And Assembly Of The Connecting Line (L3)​
30.7 - Disassembly And Assembly Of The Connecting Line (L3)​
30.8 - Disassembly And Assembly Of The Turbocharger (L3)​
30.9 - Removing And Fitting The Turbocharger (Bank A) (L3)​
30.10 - Removing And Fitting The Turbocharger (Bank B) (L3)​
30.11 - Removing And Fitting The Air Intake Pipe​
30.12 - Removing And Fitting The Air Intake Pipe​
30.13 - Replacing The Injection Pipes (Bench A) (L3)​
30.14 - Replacing The Injection Pipes (Bench A) (L3)​
30.15 - Fitting And Removing Injection Valves (L3)​
30.16 - Removing And Refitting The Injection Valve (L3)​
30.17 - Checking And Adjusting The Injection Valves (L3)​
30.18 - Removing And Fitting Fuel Delivery Pump (L3)​
30.19 - Assembly And Disassembly Of The Fuel Pressure Regulating Valve (L3)​
30.20 - Assembly And Disassembly Of The Fuel Pressure Regulating Valve (L3)​
30.21 - Assembly And Disassembly Of The Oil Intake Pipe (L3)​
30.22 - Assembly And Disassembly Of The Oil Intake Pipe (L3)​
30.23 - Disassembly And Assembly Of The Oil Radiator (L3)​
30.24 - Fitting And Removing Transition Pipe​
30.25 - Line​
30.26 - Fitting And Removing The Oil Pressure Transducer (L3)​
30.27 - Fitting And Removing The Regulator Valve (L3)​
30.28 - Closing Components​
30.29 - Topping Up With Oil​
30.30 - Removing And Fitting The Coolant Pump (L3)​
30.31 - Check The Thermostat (After Removal) (L3)​
30.32 - Removal And Refitting Of The Flywheel (Fixing Elements)​
30.33 - Removal And Refitting Of The Cylinder Head Cover​
30.34 - Fitting And Removing The Thermostats (L3)​
30.35 - Removing And Fitting The Thermostat Housing (L3)​
30.36 - Support​
30.37 - Intermediate Gear​
30.38 - Disassembly And Assembly Of The Torsional Vibration Damper (L3)​
30.39 - Lubricating Oil Filter Console​
30.40 - Replacing The Starter Ring Gear On The Flywheel (L3)​
30.41 - Removing And Fitting The Hydraulic Pump Drive (L3)​
30.42 - Disassembly And Assembly Of The Connector Box​
30.43 - Disassembly And Assembly Of The Connector Box​
30.44 - Disassembly And Assembly Of The Connector Box​
30.45 - Disassembly And Assembly Of The Connector Box​
30.46 - Removal And Refitting Of The Crankshaft Speed Sensor (L3)​
30.47 - Removal And Refitting Of The Camshaft Speed Sensor (L3)​
30.48 - Removing And Fitting The Exhaust Pipe​
30.49 - Removing And Fitting The Exhaust Pipe​
30.50 - Removing And Fitting The Exhaust Pipe​
30.51 - Removing And Fitting The Exhaust Pipe (Bank B) (L3)​
30.52 - Assembly And Disassembly Of The Spark Plug (L3)​
30.53 - Assembly And Disassembly Of The Spark Plug (L3)​
30.54 - Disassembly And Assembly Of The Fuel Cutoff Valve (Spark Plugs) (L3)​
30.55 - Disassembly And Assembly Of The Fuel Cutoff Valve (Spark Plugs) (L3)​
30.56 - Disassembly And Assembly Of The Fuel Pipes (Spark Plugs) (L3)​
30.57 - Disassembly And Assembly Of The Fuel Pipes (Spark Plugs) (L3)​
30.58 - Assembly And Disassembly Of The Temperature Sender (L3)​
30.59 - Disassembly And Assembly Of The Fuel Pipes (L3)​
30.60 - Disassembly And Assembly Of The Fuel Pipes (L3)​
30.61 - Assembly And Disassembly Of The Temperature Sender (L3)​
30.62 - Disassembly And Assembly Of The Cable Bundle (L3)​
30.63 - Removing And Fitting The Alternator (Driven By Toothed Belt) (L3)​
30.64 - Disassembly And Assembly Of The Starter (L3)​
30.65 - Removal And Refitting Of The Supply Air Pressure/Temperature Sender (L3)​
30.66 - Fitting And Removing The Injection Pumps (Cylinder A1) (L3)​
30.67 - Fitting And Removing The Injection Pumps (Cylinder A2-B3) (L3)​
30.68 - Checking And Adjusting Maximum Injection Pump Aperture Stroke (L3)​
30.69 - Removal And Refitting Of The Oil Cooler​
30.70 - Disassembly And Assembly Of The Connector Box​
40 - Pivot Points
40.1 - Safety Instructions For Tyres And Wheel Studs​
40.2 - Brakes, Brake Fluid Safety Instructions​
40.3 - Axles Maintenance Tables​
40.4 - Transmission Oil Check And Oil Change​
40.5 - Check And Change Final Drive Oil​
40.6 - Check And Change Final Drive Oil - Balance​
40.7 - Braking System​
40.8 - Tyres And Wheel Rims​
40.9 - Front Axle​
40.10 - Front Axle - Balance Version​
40.11 - Transmission Znk 25 - 1604 0895/20​
40.12 - Transmission Fork Adjustment - Transmission Znk25 - 1604 0895/20​
40.13 - Transmission Control Linkage​
40.14 - Final Drive​
40.15 - Steering Axle​
50 - Belts And Chains
50.1 - Electrical Drive Of Belt Clutches, Overview​
50.2 - Powershift Control Unit (Ccp2)​
50.3 - Straw Chopper Clutch​
50.4 - Grain Tank Discharge Clutch​
50.5 - Threshing Section Clutch​
50.6 - Feed Passage Clutch​
50.7 - Diagram Of Lubrication Control Valve Lines​
50.8 - Diagram Of Centralised Lubrication System Lines​
60 - Hydraulic System
60.1 - Hydraulic System - Safety Warnings​
60.2 - Hydraulic Circuit - Hydraulic Connection Diagram​
60.3 - Hydraulic Circuit Connection Diagram For Balance​
60.4 - Hydraulic Circuit Pipes Diagram For Balance​
60.5 - Control Valves Block​
60.6 - Control Valves Block Connection Plate​
60.7 - Single-Acting Control Valve​
60.8 - Double-Acting Control Valve​
60.9 - Engagement Valve For The Hydraulic Accumulator, With Pressure Sensor​
60.10 - Emr-D Control Valve​
60.11 - Self-Levelling Balancing Control Hydraulic Connection Diagram​
60.12 - Pilot Equipment​
60.13 - Control Valves Block With Integral Check Valve​
60.14 - Tilt Cylinder​
60.15 - Cutter Bar Self-Levelling System​
60.16 - Hydraulic Cutting Angle Control​
60.17 - Lifting Cylinder - Cutting Table (Feed Passage)​
60.18 - Hydraulic Cylinder - Steering Axle​
60.19 - Hydraulic Cylinder - Repair​
60.20 - Hydraulic Steering System​
60.21 - Danfoss Lenkorbitrol Type Ospc 160 On​
60.22 - Steering System Check​
60.23 - Hydraulic Circuit - Troubleshooting​
60.24 - General Warnings​
60.25 - Basic Structure​
60.26 - Bowex Clutch Between Hydrostatic Pump And Engine​
60.27 - Gear Control​
60.28 - Hydrostatic Transmission - Hydrostatic Pump Hpv 105/135​
60.29 - Hydrostatic Transmission - Hydrostatic Pump Hpv 105/135​
60.30 - Hmf Type Hydrostatic Motor​
60.31 - Troubleshooting​
70 - Feed Passage
70.1 - Feed Passage​
70.2 - Feed Passage - Slipping Clutch​
70.3 - Feed Passage - Stabiliser Shaft For Feed Chain​
70.4 - Engagement Of The Feed Passage​
70.5 - Protection Against Clogging Of Feed Passage​
70.6 - Protection Against Clogging Between Feed Channel Chain Sprockets​
70.7 - Feed Passage Reversal Device​
70.8 - Feed Passage Oscillating Frame, Orientable Adapter​
80 - Cab
80.1 - Operator Station Control Console​
80.2 - Commander Control 2000, Emr-D Control Unit​
80.3 - Operator Station, Commander Stick, Control Consoles​
80.4 - Operator Station - Steering Wheel​
80.5 - Cab - Control Pedals, Parking Brake​
80.6 - Cab, Controls​
80.7 - Cab, Control Devices, Seats​
80.8 - Cab - Controls​
80.9 - Cab, Control Elements, Emergency Exit​
80.10 - Cab, Rear-View Mirror Control Devices​
80.11 - On-Board Computer (Optional)​
80.12 - Cab Suspension​
80.13 - Safe Maintenance And Repair Of The Air Conditioning System​
80.14 - Overview Of Functional Components In The Cab Roof​
80.15 - Electrical Diagram For Electric Heater And Air Conditioner In Cab Roof​
80.16 - Operating Description Of The Air Conditioning System​
80.17 - Refrigerant Fluid And Oil​
80.18 - Air Conditioning System Components​
80.19 - Compressor​
80.20 - Electromagnetic Clutch​
80.21 - Compressor Lubrication​
80.22 - Liquid Tank With Dryer​
80.23 - Thermostatic Expansion Valve (Tev)​
90 - Electrical Equipment
90.1 - Electrical System - Safety Warnings​
90.2 - Serdia​
90.3 - Serdia 2000 Level Iii” Software​
90.4 - Table Of Abbreviations​
90.5 - Cable Colours And Connector Colours Identification.​
90.6 - View Of Control Console​
90.7 - Control Devices In Cab Roof​
90.8 - Control Console, Switches And Lights​
90.9 - Commander Control 2000 Operating Controls​
90.10 - Plug Distributor / Engine Frame Plug Connector​
90.11 - Actuator Connector Pins Assignment​
90.12 - Diagram Of Commander Control 2000 Can-Bus With Central Display​
90.13 - Straw Chopper Straw Guide Plate Adjustment Diagram​
90.14 - Can-Bus System Of Commander Control With Central Display Installation Procedure​
90.15 - Type Of Function And Programming Of Can Modules​
90.16 - Central Display​
90.17 - Central Display And Commander Control 2000, Control And Command Functions Overview​
90.18 - Checking Functions By Means Of Commander Control 2000​
90.19 - Switches And Sensors For Commander Control 2000 Control​
5695hts)
90.20 - Description Of Inductive Sensor Functions​
90.21 - Sensors, Overview​
90.22 - Multifunction Lever, Rack Device / Sensor Adjustment​
90.23 - Eec Control Unit, Accelerator Adjustment Module​
90.24 - Cutting Table Electronic Control​
90.25 - Assignment Of Connectors Emr-D​
90.26 - Balance System​
90.27 - Hourly Production Monitoring System / Job Calculator​
90.28 - Wiring Looms And Components Index​
90.29 - Worklights​
90.30 - Windscreen Wiper​
90.31 - Balance​
90.32 - Solenoid Valves​
90.33 - Electric Motors​
90.34 - Grain Tank Sensors​
90.35 - Attachment​
90.36 - Feed Passage Sensors​
90.37 - Lights​
90.38 - Air Conditioner​
90.39 - Front Wiring Loom - 0.015.5469.4/20​
90.40 - Battery Positive Lead - 16002049​
90.41 - Battery Negative Lead - 16002046​
90.42 - Cab Console Wiring - Ts8799/1, Ts8799/3​
90.43 - Engine Interface Wiring - 0.015.5475.4/10​
90.44 - Engine Wiring Loom - 0.015.5471.4/20​
90.45 - Fuse Box Wiring - 0.015.5312.4/20​
90.46 - Grain Tank Wiring Loom - 0.015.5473.4/10​
90.47 - Charge Circuit Wiring Loom - 0.015.5464.4/10​
90.48 - Attachment Electrical Socket Wiring Loom - 0.015.5466.4/10​
90.49 - Rear Number Plate Light Wiring Loom - 16056728/10​
90.50 - Coolant Temperature Sensor Wiring Loom - 16062294​
90.51 - Balance Wiring - 0.015.5467.4/10​
90.52 - Electric Motor Wiring Loom - 0.015.5472.4/10​
90.53 - Returns Elevator Emergency Switch - 16050268​
90.54 - Roof Lining Electrics Wiring Loom - 980157​
90.55 - Balance Wiring Loom - 16052333​
90.56 - Cab Roof Worklights Wiring Loom - 980060​
90.57 - Air Conditioner Wiring Loom - 540465​
90.58 - Air Conditioning System Filter-Dryer Wiring Loom - 16050276​
90.59 - Rear Wiring - 0.015.5470.4/20​
90.60 - Rear Lateral Light Wiring Loom - 16013845​
90.61 - Sieve Lighting Wiring Loom - 16050274​
90.62 - Side Lights Wiring Loom - 16056753​
90.63 - Side Lights Wiring Loom - 16056731/10​
90.64 - Feed Passage Reversing Device Wiring Loom - 16062550​
90.65 - Feed Passage Sensors Wiring Loom - 0.015.5465.4 /10​
90.66 - Chassis Wiring Loom - 0.015.5474.4/10​
90.67 - Grain Tank Worklight Wiring Loom - 16062565/10​
90.68 - Solenoid Valves Assembly Wiring Loom - 0.015.5468.4/10​
90.69 - Cutting Table Cutting Angle Sensor Wiring Loom - 16062568/10​
90.70 - Multifunction Lever Wiring Loom - Ts8799/2​
90.71 - Steering Column Switch Wiring Loom - 980062201​
90.72 - Straw Chopper Wiring Loom - 16050256​
100 - Threshing Unit
100.1 - Threshing Section Clutch​
100.2 - Assembling The Threshing Drum​
100.3 - Concave Electrical Adjustment​
100.4 - Concave Suspension, De-Awner Covers​
100.5 - Assembling The Reversing Drum​
100.6 - Threshing Drum Speed Variator​
100.7 - Installing The Variator Pulley​
100.8 - Variator Adjustment​
100.9 - Changing The Variator Belt​
100.10 - Dust Plate And Gaskets On Threshing Section​
100.11 - Threshing Drum Speed Reduction​
100.12 - Turbo Separator​
100.13 - Installing The Maize Concave​
100.14 - Threshing Drum - Maize Harvesting, Welding Of Threshing Drum Beater Bars​
110 - Cleaning Unit
110.1 - Straw Walkers Drive​
110.2 - Straw Walker Transmission Adjustment​
110.3 - Straw Walker Supports Assembly​
110.4 - Assembling Straw Walker Shafts And Straw Walker​
110.5 - Installation Of Straw Walker Rakes​
110.6 - Sieve Crankshaft​
110.7 - Stepped Gain Pan With Removable Segments​
110.8 - Stepped Grain Pan And Sieve Box With Transmission​
110.9 - Fan Speed Variator​
110.10 - Fan - Shroud​
110.11 - Tailings Elevator (Returns Elevator)​
110.12 - Electric Sieve Adjustment​
120 - Grain Tank - Elevator
120.1 - Grain Elevator With Elevator Head​
120.2 - Elevator Head, Speed Control​
120.3 - Elevator Head For Grain Tank Extension​
120.4 - Grain Tank Clutch​
120.5 - Emptying The Grain Tank​
120.6 - Grain Discharge System​
120.7 - Bevel Gear In Elbow Pipe​
120.8 - Support For Grain Tank Pipe, Block​
120.9 - Grain Tank Level Sensors​
130 - Cutting Table
130.1 - Controls Diagram, Speed​
130.2 - Cutting Table Drive, Reel Variator​
130.3 - Slipping Clutch For Intake Auger And Reel​
130.4 - Intake Auger​
130.5 - Intake Auger Settings​
130.6 - Blade Mechanism - 80 Mm Stroke​
130.7 - Blade Mechanism - 85 Mm Stroke​
130.8 - Blade Control Transmission Check; Changing The Blade​
130.9 - Assembly Of Potentiometer For Cutting Table Adjustment​
130.10 - Connectors Assignment, 13 Pin Socket​
130.11 - Diagram Of Pipelines And Connection Diagram For Hydraulic System On Rape Header​
130.12 - Rape Header Drive​
140 - Attachments And Accessories
140.1 - Straw Guide Plate Adjustment​
140.2 - Straw Chopper V-Belt Clutch​
140.3 - Speed Monitoring​
140.4 - Conversion Of Straw Chopper For Threshing Maize And Sunflowers​
140.5 - Lining For Straw Hood​
140.6 - Electrically Driven Movement From Straw Guide Plate To Straw Chopper​
