Momed80
151
35,046
Deutz Engine 1015 Operation Manual 03120807
Brand: Deutz
Model: Deutz 1015 BF6M1015, BF8M1015 Engine
Order No.: 03120807
Number of Pages: 84 Pages
1. General
2. Description of Engine
2.1 Model Designation
2.1.1 Rating Plate
2.1.2 Location of Rating Plate
2.1.3 Engine Serial Number
2.1.4 Numbering of Cylinders
2.2 Engine Illustrations
2.2.1 Cyl. Bank A BF6 M 1015
2.2.2 Cyl. Bank B BF6 M 1015
2.2.3 Cyl. Bank A BF8 M 1015
2.2.4 Cyl. Bank B BF8 M 1015
2.3 Lube Oil Circuit
2.3.1 Lube Oil Circuit Schematic 1015
3. Operation
3.1 Commissioning
3.1.1 Filling in Engine Oil
3.1.2 Filling Oil Bath Air Cleaner with
Engine Oil
3.1.3 Filling the Fuel Tank
3.1.4 Filling/Bleeding the Cooling System
1015
3.1.5 Other Preparations
3.2 Starting
3.2.1 Electric Starting
3.3 Monitoring Systems
3.3.1 Engine Oil Pressure
3.3.2 Coolant Temperature
3.3.3 Coolant Level
3.3.4 Lube Oil Level
3.4 Stopping
3.4.1 Mechanical Shutdown
3.4.2 Electric Shutdown
3.5 Operating Conditions
3.5.1 Winter Operation
3.5.2 High Ambient Temperature, High
Altitude
4. Operating Media
4.1 Lube Oil
4.1.1 Quality Grade
4.1.2 Viscosity
4.2 Fuel
4.2.1 Quality Grade
4.2.2 Winter Grade Fuel
4.3 Coolant
4.3.1 Water Quality for Coolant
Preparation
4.3.2 Coolant Preparation
4.3.3 Cooling System Protective Agents
5. Routine Maintenance
5.1 Maintenance Schedule
5.2 Maintenance Chart
5.3 Completed Maintenance Jobs
6. Service and Maintenance
6.1 Lubrication System
6.1.1 Oil Change Intervals
6.1.2 Changing Engine Oil, Checking Oil
Level
6.1.3 Renewing Oil Filter
6.2 Fuel System
6.2.1 Renewing Fuel Filter
6.2.2 Change Fuel Leakage Line
6.2.3 Fuel Pre-filter Element
Clean/Replace if necessary
6.3 Cooling System
6.3.1 Cleaning Intervals
6.3.2 Draining Cooling System
6.3.3 Filling/Bleeding Cooling System
6.3.4 Cleaning engine
6.4 Combustion Air Cleaner
6.4.1 Cleaning Intervals
6.4.2 Dry-Type Air Cleaner
6.4.3 Removing Cyclone-Type
Precleaner
6.4.4 Cleaning Oil Bath Air Cleaner
6.5 Belt Drives
6.5.1 Checking Alternator V-Belt
6.5.2 Retensioning/Renewing Alternator
V-Belt
6.6 Adjustments
6.6.1 Checking/Adjusting Valve
Clearances
6.6.1.1 Valve Clearance
Adjustment Schematic
6.7 Accessories
6.7.1 Battery
6.7.2 Three-Phase Alternator
6.7.3 Lifting Tackle
7. Troubleshooting
7.1 Diagnosis Chart
8. Engine Preservation
8.1 Preservation
9. Specification Data
9.1 Engine Specifications and Settings
9.2 Torque Wrench Settings
9.3 Tools
10. Service
