Detroit Diesel Engine MBE 4000 Service Manual 68E412
Brand: Detroit Diesel
Model: Detroit Diesel MBE 4000 Engine
Part Number: 68E412
Publication Date: 2004
Number of Pages: 587 Pages
Scope And Use Of This Manual
General Description
Electronic Engine Control System
Engine Braking Power
General Specifications And Engine Views
Engine Model And Serial Number
Exhaust Gas Recirculation (Egr) System
Safety Instructions And Precautions
English To Metric Conversion
Decimal And Metric Equivalents
Torque Specifications
1 Engine
1.1 Cylinder Head Cover
1.2 Cylinder Head
1.3 Cylinder Block
1.4 Egr Cylinder Head And Block
1.5 Egr Front And Rear Lifter Brackets
1.6 Engine Brake
1.7 Front Radial Seal
1.8 Rear Radial Seal
1.9 Crankshaft Assembly
1.10 Front Cover Housing
1.11 Crankshaft Vibration Damper
1.12 Flywheel
1.13 Ring Gear
1.14 Pilot Bearing
1.15 Engine Cranking Tool
1.16 Flywheel Housing
1.17 Piston, Piston Ring, And Connecting Rod
1.18 Egr Piston, Piston Ring, And Connecting Rod
1.19 Valves
1.20 Egr Valves
1.21 Rocker Arm
1.22 Camshaft And Camshaft Sensor
1.23 Egr Camshaft
1.A Additional Information
2 Fuel System
2.1 Injector Unit Pump
2.2 Egr Injector Unit Pump
2.3 Fuel Injector Line
2.4 Fuel Injector Nozzle
2.5 Egr Fuel Injector Nozzle
2.6 Protective Sleeve
2.7 Ddec Electronic Control Unit
2.8 Fuel Heat Exchanger
2.9 Fuel Filter
2.10 Egr Fuel Filter
2.11 Fuel Pump
2.12 Fuel System Inspection
2.A Additional Information
3 Lubrication System
3.1 Oil Pan
3.2 Oil Spray Nozzle
3.3 Egr Camshaft Lubrication Sprayer
3.4 Oil Pump
3.5 Egr Oil Pump And Pick Up Tube
3.6 Oil Filter
3.7 Oil Heat Exchanger And Filter Housing
3.8 Oil Pressure And Temperature Sensor
3.A Additional Information
4 Cooling System
4.1 Cooling System
4.2 Coolant Pump
4.3 Egr Coolant Pump
4.4 Front Idler And Tensioner Support
4.5 Thermostat
4.6 Egr Thermostat Housing
4.7 Coolant Temperature Sensor
4.A Additional Information
5 Fuel, Lubricating Oil, And Coolant
5.1 Fuel
5.2 Lubricating Oil
5.3 Coolant
5.A Additional Information
6 Air Intake System
6.1 Intake Manifold
6.2 Charge Pressure/Temperature Sensor
6.3 Turbocharger
6.A Additional Information
7 Exhaust System
7.1 Exhaust Manifold
7.2 Exhaust Brake Assembly
7.3 Egr Exhaust Manifold
7.4 Egr Cooler And Cooler Support Bracket
7.5 Egr Control Valve, Gas Outlet Pipe, And Gas Mixer
7.6 Epv (Electronic Proportional Valve) And Wabco® Air
Solenoid Valve
7.7 Hengst® Breather Filter
7.A Additional Information
8 Electrical Equipment
8.1 Drive Belts
8.A Additional Information
9 Power Take-Off
9.1 Power Take-Off
10 Special Equipment
10.1 Air Compressor
10.A Additional Information
11 Operation And Verification
11.1 Preparation For A First Time Start
11.2 Starting The Engine
11.3 Running The Engine
11.4 Stopping The Engine
12 Engine Tune-Up
12.1 Valve Lash Checking
12.2 Adjusting Valve Lash
13 Preventive Maintenance
13.1 Scheduled Intervals
14 Engine Storage
14.1 Preparing Engine For Storage
15 Mechanical Troubleshooting
15.1 Troubleshooting The Electronic Engine Control
System
15.2 General Troubleshooting
Index
Part Number: 68E412
General Description
1 Engine
1.2 Cylinder Head
1.3 Cylinder Block
1.6 Engine Brake
1.12 Flywheel
1.13 Ring Gear
1.14 Pilot Bearing
1.19 Valves
1.20 Egr Valves
1.21 Rocker Arm
1.23 Egr Camshaft
2 Fuel System
2.9 Fuel Filter
2.11 Fuel Pump
3.1 Oil Pan
3.4 Oil Pump
3.6 Oil Filter
4 Cooling System
4.1 Cooling System
4.2 Coolant Pump
4.5 Thermostat
5.1 Fuel
5.2 Lubricating Oil
5.3 Coolant
6 Air Intake System
6.1 Intake Manifold
6.3 Turbocharger
7 Exhaust System
Solenoid Valve
8.1 Drive Belts
9 Power Take-Off
9.1 Power Take-Off
10.1 Air Compressor
12 Engine Tune-Up
14 Engine Storage
System
Index
- Detroit Diesel DD15 Engine Workshop Manual
- Detroit Diesel 92 Series Service Manual
- Detroit Diesel - DDEC VI SERIES 60 MCM EGR Engine Harness Schematic
- Detroit Diesel - Series 60 DDEC IV Wiring Diagram
- Detroit DD13, DD15, DD16 Exhaust, EGR, Aftertreatment Service Manual
- Detroit Diesel - DDEC VI - CPC Vehicle Interface Harness Schematic
- Detroit Diesel - EPA07 SERIES 60 WORKSHOP MANUAL DDEC VI (DDC-SVC-MAN-0005)
- Detroit Diesel - DDEC III - IV Single ECM Troubleshooting Guide
- Detroit Diesel Reprogramming System / Keygenerator and DDDL
- Detroit Diesel Electronic Wiring Schematics
- Detroit Diesel Calibration Tool 2005
- Detroit Diesel Engines Series 60 Service Manual
- Engine Detroit S60 (11.1L; 12.7L) Part Catalog
- Detroit Diesel - Unit Fuel Injectors And Unit Pump - Technicians Guide
- MBE Reprogramming System
