Detroit Diesel Engine EPA07 MBE 4000 Workshop Manual DDC-SVC-MAN-0026
Brand: Detroit Diesel
Type of Manual: Workshop Manual
Model: Detroit Diesel EPA07 MBE 4000 Engine
Part Number: DDC-SVC-MAN-0026
Publication Date: 2011
Number of Pages: 593 Pages
Scope And Use Of This Manual
General Description
Aftertreatment System
Electronic Engine Control System
Environmental Conditions
Safety Instructions And Precautions
Cpc Vehicle Interface Harness
Engine Braking Power
1 Engine
1.1 Engine Trim Covers And Frames
1.2 Cylinder Head Cover
1.3 Cylinder Head
1.4 Cylinder Block
1.5 Front And Rear Engine Lifting Brackets
1.6 Engine Brake
1.7 Front Radial Seal
1.8 Rear Radial Seal
1.9 Crankshaft Wear Sleeve
1.10 Crankshaft Assembly
1.11 Front Cover Housing
1.12 Crankshaft Position Sensor
1.13 Crankshaft Vibration Damper And Pulley
1.14 Flywheel
1.15 Ring Gear
1.16 Pilot Bearing
1.17 Engine Barring Tool
1.18 Flywheel Housing
1.19 Piston, Piston Ring, And Connecting Rod
1.20 Valves
1.21 Rocker Arm
1.22 Camshaft And Gear Assembly
1.A Additional Information
2 Fuel System
2.1 Electronic Unit Pump
2.2 Fuel Return And Nozzle Spill Line
2.3 Fuel Overflow Valve
2.4 High Pressure Fuel Line And Transfer Tube
2.5 Fuel Injector Harness Adaptor Frame
2.6 Fuel Injector
2.7 Protective Sleeve
2.8 Motor Control Module
2.9 Fuel Filter
2.10 Fuel Filter Housing
2.11 Fuel Filter Bracket
2.12 Fuel Hand Primer Pump
2.13 Fuel Pump
2.14 Fuel Pump Drive
2.15 Fuel Doser Valve (Fdv)
2.16 Doser Block Assembly
2.17 Fuel Doser Valve Coolant Lines
2.A Additional Information
3 Lubrication System
3.1 Lubrication System Description
3.2 Oil Pan
3.3 Piston Oil Spray Nozzle
3.4 Camshaft Lubrication Nozzle
3.5 Oil Pump And Suction Pipe
3.6 Oil Filter
3.7 Oil Cooler/Filter Housing
3.8 Engine Oil Pressure/Temperature Sensor
3.9 Oil Fill-Tube And Oil Dipstick
3.A Additional Information
4 Cooling System
4.1 Cooling System
4.2 Coolant Pump
4.3 Front Idler And Tensioner Support
4.4 Thermostat
4.5 Engine Coolant Temperature Sensor
4.6 Cylinder Head Coolant Vent Line
4.A Additional Information
5 Fuel, Lubricating Oil, And Coolant
5.1 Fuel
5.2 Lubricating Oil
5.3 Coolant
5.A Additional Information
6 Air Intake System
6.1 Air Intake Elbow And Grid Heater
6.2 Intake Throttle Valve And Adaptor
6.3 Gas Mixer Housing
6.4 Air Intake Manifold
6.5 Electrostatic Oil Separator, Crankcase Separator, And
Oil Separator Drain Line
6.6 Intake Air Temperature/Pressure Sensor
6.7 Turbocharger
6.8 Wastegate Actuator
6.A Additional Information
7 Exhaust System
7.1 Exhaust Manifold Assembly
7.2 Brake Gate
7.3 Electronic Proportional Valve
7.A Additional Information
8 Exhaust Gas Recirculation Components
8.1 Egr Gas Inlet Pipe
8.2 Egr Cooler Gas Outlet Pipe
8.3 Egr Cooler And Support Bracket
8.4 Egr Cooler Heat Shield And Mounting Bracket
8.5 Egr Cooler Coolant Inlet Tube
8.6 Egr Cooler Coolant Return Tube
8.7 Egr Control Valve
8.A Additional Information
9 Electrical Equipment
9.1 Drive Belts
9.2 Alternator/Air Conditioning Compressor Bracket
9.A Additional Information
10 Power Take-Off
10.1 Front Power Take-Off
10.2 Rear Engine Power Take-Off
11 Special Equipment
11.1 Air Compressor Flange
11.2 Air Compressor
11.A Additional Information
12 Operation And Verification
12.1 Preparation For A First Time Start
12.2 Starting The Engine
12.3 Running The Engine
12.4 Stopping The Engine
12.A Additional Information
13 Engine Tune-Up
13.1 Checking The Valve Lash
13.2 Adjusting The Valve Lash
13.A Additional Information
14 Preventive Maintenance
14.1 Scheduled Intervals
15 Engine Storage
15.1 Preparing Engine For Storage
Index
