Hyundai
86
176,834
Dana Spicer Axle 12 Service Manual
Brand: Dana Spicer
Type of Machine: Axle
Model: Dana Spicer 12 Axle
List of Files:
112_Axle_Service_Manual_ASM-0004E_09-12_HRLR (154 Pages)
INTRODUCTION​
SPECIFICATIONS​
SAFETY PRECAUTIONS​
CHECKING WEAR AND REPLACING THE BRAKING DISCS​
PLANETARY REDUCTION AND AXLE SHAFT​
BEVEL PINION​
DIFFERENTIAL UNIT​
MANUAL EMERGENCY RELEASE​
MECHANICAL PARKING BRAKE​
EXTERNAL HYDRAULIC NEGATIVE BRAKE​
EXTERNAL HYDRAULIC NEGATIVE BRAKE WITH QUICK RELEASE​
INCOMING DRUM BRAKE​
BEVEL PINION SUPPORT​
4" INCOMING BRAKE (2 AND 3 FUNCTION VERSIONS)​
7" COMBINED BRAKE​
NORMAL DIFFERENTIAL UNIT​
LIMITED SLIP DIFFERENTIAL UNIT (25% AND 45%)​
HYDRAULIC DIFFERENTIAL LOCK​
212_Axle_Service_Manual_ASM-0025E_10-13_HR (176 Pages)
INTRODUCTION​
SPECIFICATIONS​
SAFETY PRECAUTIONS​
COMPLETE STEERING CASE​
DOUBLE U-JOINT​
PLANETARY REDUCTION GEAR​
STEERING CYLINDER​
DIFFERENTIAL UNIT​
BEVEL PINION​
MANUAL EMERGENCY RELASE​
INCORPORATED REDUCTION GEAR AND PINION 602​
