Dana Hercules Drive Axle 37R 43R Maintenance And Repair Manual
Brand: Dana
Type of Machine: Hercules Drive Axle
Type of Manual: Maintenance And Repair Manual
Model: Dana 37R 43R
Number of Pages: 81 Pages
L 580 - Hercules Axles 37R / 43R engl.
Technical Description
Foreword, Caution
Table of contents
Drawing with partlist
Lubricants
Bearing Heating and freezing
Tooth contact chart
Cleaning and Inspection
Pinion bearing mounting distance calculation
Pinion bearing rolling torque procedure
Brake Assembly air pressure test
Axle air pressure test
Planetary removal
Axle shaft removal
Hub and seal removal
Trumpet arm removal
Brake disassembly
Posi torque disassembly
Differential resassembly
Backlash checking procedure
Brake reassembly
Locatiing brake piston
Trumpet arm installation
Hub and seal installation
Planetary installation
Planetary disassembly
Planetary reassembly
Special tools
Brand: Dana
Model: Dana 37R 43R
Foreword, Caution
Table of contents
Lubricants
Tooth contact chart
Planetary removal
Axle shaft removal
Trumpet arm removal
Brake disassembly
Brake reassembly
Special tools
- Dana Spicer transmission model HR36000 4 and 6 speeds
- DANA SPICER T20000 TRANSMISSION SERVICE MANUAL
- DANA TRANSMISSION TE13/TE17 SERVICE MANUAL
- Dana Transmission Manual TE13 & TE17 Transmission operation and diagnostics
- Dana Service Manual TE13-17
- Dana Spicer Transmission T12000 Service Manual
- Dana Transmission Manual TE-10 TRANSMISSION
- Dana 32000 HR 3speeds Sort Drop Service manual
- Dana T20000 powershift service manual
- Dana Transmission Manual TE27 & TE32 Transmission operation and diagnostics
- Dana Transmission Manual Transmission Repair DANA SPICER
- Dana T1200 PowerShift Service manual
- Dana Spicer Axle Maintenance Manual Model 50
- Dana T27 & T32 4 SPEED SHORT DROP
- Dana Transmission Manual TE13 & TE17 Transmission Repair
