Dana Axle 212 Service Manual ASM-0025E
Brand: Dana
Type of Machine: Axle
Model: Dana 212 Axle
Part Number: ASM-0025E
Publication Date: 2022
Number of Pages: 246 Pages
Introduction
Trunnion
Brand: Dana
Introduction
Version tracking
Manual applicability and supported models
SpecificationsDefinition of viewpoints
Data plate
Conversion tables
Torque specifications
MaintenanceMaintenance points
Maintenance points (heavy duty)
Oil draining mandatory procedure
End-stop plier setting
Maintenance intervals
Lubricant & sealant specifications
Safety precautionsTrunnion
Exploded view
Disassembly
Assembly
Checking wear and replacing the braking discsExploded view
Disassembly
Assembly
Special tools
Steering knuckle adjustmentExploded view
Disassembly
Assembly
(Heavy duty) Steering knuckle adjustmentExploded view
Disassembly
Assembly
Double u-jointExploded view
Disassembly
Assembly
Special tools
Planetary reduction gearExploded view
Disassembly
Assembly
Special tools
(Heavy duty) Planetary reduction gearExploded view
Disassembly
Assembly
Special tools
Steering cylinderWrench dimensions options
Exploded view
Optical sensor and magnetic sensor
Disassembly
Assembly
Special tools
(Heavy duty) Steering cylinderExploded view
Disassembly
Assembly
Special tools
Differential unitExploded view
Disassembly
Assembly
Special tools
Bevel pinionExploded view
Disassembly
Assembly
Special tools
Manual emergency releaseExploded view
Release
Adjustment
Mechanical parking brakeExploded view
Viewpoint definition
Disassembly
Assembly
External hydraulic negative brakeExploded view
Disassembly
Assembly
External hydraulic negative brake with quick releaseExploded view
Disassembly
Assembly
Incoming drum brakeExploded view
Disassembly
Assembly
Special tools
4" incoming brake (2 and 3 function versions)Exploded view
Disassembly
Assembly
Special tools
Normal differential unitExploded view
Disassembly
Assembly
Special tools
Limited slip differential unit (25% and 45%)Exploded view
Disassembly
Assembly
Special tools
Hydraulic differential lock 100% by selector fork / pistonExploded view
Disassembly
Assembly
Special tools
Hydraulic negative brakeExploded view
Disassembly
Assembly
Incorporated reduction gear and pinion 602 and 603Exploded view
Disassembly
Assembly
Special tools
Counter revolution sensor (drop-in type)Exploded view
Disassembly
Assembly
- Dana Spicer transmission model HR36000 4 and 6 speeds
- DANA SPICER T20000 TRANSMISSION SERVICE MANUAL
- DANA TRANSMISSION TE13/TE17 SERVICE MANUAL
- Dana Transmission Manual TE13 & TE17 Transmission operation and diagnostics
- Dana Service Manual TE13-17
- Dana Spicer Transmission T12000 Service Manual
- Dana Transmission Manual TE-10 TRANSMISSION
- Dana 32000 HR 3speeds Sort Drop Service manual
- Dana T20000 powershift service manual
- Dana Transmission Manual TE27 & TE32 Transmission operation and diagnostics
- Dana Transmission Manual Transmission Repair DANA SPICER
- Dana T1200 PowerShift Service manual
- Dana Spicer Axle Maintenance Manual Model 50
- Dana T27 & T32 4 SPEED SHORT DROP
- Dana Transmission Manual TE13 & TE17 Transmission Repair
