Hyundai
86
176,834
Dana Axle 211 Service Manual ASM-0024E
Brand: Dana
Type of Machine: Axle
Model: Dana 211 Axle
Part Number: ASM-0024E
Publication Date: 2022
Number of Pages: 400 Pages
Introduction
Version tracking​
Manual applicability and supported models​
Specifications
Definition of viewpoints​
Data plate​
Conversion tables​
Torque specifications​
Maintenance
Maintenance points​
Oil plugs tightening torques​
Oil draining mandatory procedure​
End-stop plier setting​
Input seal greasing​
Maintenance intervals​
Lubricant & sealant specifications​
Safety precautions
Planetary reduction (4 studs version) 1:6 and steering knuckle
Exploded view​
Disassembly​
Assembly​
Special tools​
Double u-joint (ball bearing-bushing version)
Exploded view​
Disassembly​
Assembly​
Special tools​
Planetary reduction (8 studs version) 1:6 and steering knuckle
Exploded view​
Disassembly​
Assembly​
Special tools​
Steering cylinder
Exploded view​
Disassembly​
Assembly​
Special tools​
Brake: service brake, negative brake, 45% locked and 100% locked
Exploded view​
Brake working conditions​
Disassembly​
Assembly​
Brake piston gap check​
Special tools​
Emergency release of negative brake instructions
Reset of fails safe brake function​
Brake: negative brake 4 cup springs version
Exploded view​
Disassembly​
Assembly​
Normal preloaded differential unit (old version)
Exploded view​
Disassembly​
Assembly​
Normal preloaded differential unit (intermediate version)
Exploded view​
Disassembly​
Assembly​
Normal preloaded differential unit (last version)
Exploded view​
Disassembly​
Assembly​
Flanged reduction gear 603 type: integral 603 input gear
Exploded view​
Disassembly​
Assembly​
Special tools​
Bevel pinion: normal flange and nut revolution counter version
Exploded view​
Disassembly​
Assembly​
Special tools​
Ring and pinion adjusting: step for preloaded differential
Exploded view​
Bevel gear pair backlash​
Install and adjust​
Special tools​
Swinging support
Exploded view​
Disassembly​
Assembly​
Planetary reduction: 1:4,23
Exploded view​
Disassembly​
Assembly​
Planetary reduction 1:4,23 (ball bearing-bushing version)
Exploded view​
Disassembly​
Assembly​
Service and sahr incoming disc brake
Exploded view​
Disassembly​
Assembly​
Checking wear and replacing the braking pads​
Caliper assembly and setting​
Service and mechanical parking brake
Exploded view​
Disassembly​
Assembly​
Parking brake and differential hydraulic lock 100%
Exploded view​
Disassembly​
Assembly​
Differential with block to spheres 100% old version
Exploded view​
Disassembly​
Assembly​
Differential with block to spheres 100% (last version)
Exploded view​
Disassembly​
Assembly​
Normal differential (old version)
Exploded view​
Disassembly​
Assembly​
Normal differential (last version)
Exploded view​
Disassembly​
Assembly​
Limited slip differential unit 45% (old version)
Exploded view​
Disassembly​
Assembly​
Limited slip differential unit 45% (last version)
Exploded view​
Disassembly​
Assembly​
Preloaded limited slip differential unit 45% unit (old version)
Exploded view​
Disassembly​
Assembly​
Preloaded limited slip differential unit 45% (intermediate version)
Exploded view​
Disassembly​
Assembly​
Preloaded limited slip differential unit 45% (last version)
Exploded view​
Disassembly​
Assembly​
Bevel pinion: flanged to reduction gear 603
Exploded view​
Disassembly​
Assembly​
Special tools​
Ring and pinion adjusting: version pinion cover and single arm
Exploded view​
Install and adjust​
Special tools​
Ring and pinion adjusting: version pinion integral and double arm
Exploded view​
Install and adjust​
Special tools​
Separate pinion cover for flanged gearbox
Exploded view​
Disassembly​
Assembly​
Special tools​
United pinion cover for flanged gearbox
Exploded view​
Disassembly​
Assembly​
Special tools​
Steering knuckle king pin preloaded by belleville washers
Exploded view​
Disassembly​
Assembly​
Special tools​
Service brake, negative brake, 100% differential lock (new version - optional)
Exploded view​
Disassembly​
Assembly​
Special tools​
Service brake, 100% differential lock (new version - optional)
Exploded view​
Braking discs wear check​
Disassembly​
Assembly​
Special tools​
Brake discs wear check (not present on all models)
Emergency release instructions
Counter revolution sensor (drop-in type)
Exploded view​
Disassembly​
Assembly​
