Hyundai
86
176,834
Dana Axle 112 Service Manual ASM-0004E
Brand: Dana
Type of Machine: Axle
Model: Dana 112 Axle
Part Number: ASM-0004E
Publication Date: 2022
Number of Pages: 240 Pages
Introduction
Version tracking​
Manual applicability and supported models​
Specifications
Definition of viewpoints​
Data plate​
Conversion tables​
Torque specifications​
Maintenance
Maintenance points​
Oil draining mandatory procedure​
End-stop plier setting​
Maintenance intervals​
Lubricant & sealant specifications​
Safety precautions
Checking wear and replacing the braking discs
Exploded view​
Disassembly​
Assembly​
Special tools​
Planetary reduction and axle shaft
Exploded view​
Disassembly​
Assembly​
Special tools​
Bevel pinion
Exploded view​
Disassembly​
Assembly​
Special tools​
Differential unit
Exploded view​
Disassembly​
Assembly​
Special tools​
Manual emergency release
Exploded view​
Release​
Adjustment​
Mechanical parking brake
Exploded view​
Viewpoint definition​
Disassembly​
Assembly​
External hydraulic negative brake
Exploded view​
Disassembly​
Assembly​
External hydraulic negative brake with quick release
Exploded view​
Disassembly​
Assembly​
Incoming drum brake
Exploded view​
Disassembly​
Assembly​
Special tools​
Bevel pinion support
Exploded view​
Disassembly​
Assembly​
Special tools​
4" incoming brake (2 and 3 function versions)
Exploded view​
Disassembly​
Assembly​
Special tools​
7" combined brake
Exploded view​
Disassembly​
Assembly​
Release​
Special tools​
Normal differential unit
Exploded view​
Disassembly​
Assembly​
Special tools​
Limited slip differential unit (25% and 45%)
Exploded view​
Disassembly​
Assembly​
Special tools​
Hydraulic differential lock 100% by selector fork / piston
Exploded view​
Disassembly​
Assembly​
Special tools​
Hydraulic negative brake
Exploded view​
Disassembly​
Assembly​
Planetary reduction 6:9
Exploded view​
Disassembly​
Assembly​
Special tools​
Flanged pinion to gearbox with floating flange
Exploded view​
Disassembly​
Assembly​
Special tools​
Hydraulic differential lock 100% by anular piston
Exploded view​
Disassembly​
Assembly​
Incorporated reduction gear and pinion 602 and 603
Exploded view​
Disassembly​
Assembly​
Special tools​
Counter revolution sensor (drop-in type)
Exploded view​
Disassembly​
Assembly​
