118
6,911
Cushman Utility Vehicle Turf-Truckster Operation Manual 837448
Brand: Cushman
Type of Machine: Turf-Truckster
Model: Cushman Turf-Truckster
Engine: 222 Air Cooled, 327 Liquid Cooled, D950 Diesel
Part Number: 837448
Publication Date: 1994
Number of Pages: 38 Pages
A
Accessories And Modifications
Air Cleaner And Servicing
Ammeter
B
Battery
Battery Specifications
Brake Pedal, Parking
Brake Pedal, Service
Bulbs, Flashers And Fuses
C
Capacities
Clutch Interlock Switch
Controls
D
Driving The Vehicle
E – Engine
Access
Break-in
Cooling
Identification (serial) Number
Lubrication
Maintenance
Oil Level
Pre-starting Check
Purging The Fuel System (Diesel only)
Specifications
Starting
F
Factory Installed Modifications And Accessories
Flatbed And Short Box
Fuel Gauge
Fuses
G
Gauges
Gear Ratios
Gear Selector
Glow Plug Indicator And Pre-heat Switch (Diesel only)
Governor Control Lever
Governor Oil Level
H
Heat Warning Lamp
Heater-defroster
Horn Button
Hour Meter
Hydraulic Lift System
I
Identification Numbers
Ignition Switch
Interlock Switch, Clutch
J
Jacks, Jacking Locations And Using A Hoist
Jump Starting
L
Light Switch
Lubrication Chart
Lubricated Pedal Bushings
M
Maintenance Guide
Model Number, Vehicle
O
Oil Warning Light
Operation, Vehicle
Owner Registration
P
Parking The Vehicle
Power Steering
Power Take Off (P.T.O.)
Product Registration
R
Refueling The Vehicle
R.O.P.S. (Roll Over Protection System)
S
Seat Belt
Serial Number, Engine
Serial Number, Vehicle
Service And Maintenance
Service Publications
Specifications
Speedometer/Odometer
Speeds, Maximum
Standards And Publications
Stopping The Vehicle
Storage, Extended
T
Tachometer
Tailgate Adjustment
Throttle, Foot
Throttle, Hand
Tire Air Pressure
Tire Removal
Tire Replacement
Towing A Trailer
Towing The Vehicle
Two-Speed Differential
V
Vehicle Identification Numbers
W
Warning Lights
Warranty, Cushman
Warranty, Service
Water Separator (Diesel only)
Water Temperature Gauge, Lamp And Buzzer
Wiper Motor Switch
Engine Data
Air Cooled, 222 Engine
Liquid Cooled, Diesel
Liquid Cooled, 327 Engine
