Cushman Utility Vehicle Turf-Truckster 898627 to 898695 Parts Maintenance Manual 4120402
Brand: Cushman
Type of Manual: Parts Manual, Maintenance Manual, Wiring Diagram
Model: Cushman Turf-Truckster Utility Vehicle
Suzuki K6a Liquid Cooled Gasoline Engine Mt
Model: 898627
Suzuki K6a Liquid Cooled Gasoline Engine At
Model: 898628
Suzuki 970 Liquid Cooled Gasoline Engine
Model: 898671
Perkins Liquid Cooled Diesel Engine
Model: 898673
EC Model: 898695
Part Number: 4120402
Number of Pages: 189 Pages
SERVICE and MAINTENANCE INDEX
A
Accelerator Pedal
Accessories, list of
Accessory Power Plug
Access Panels
Air Cleaner
Air Cleaner Element
B
Battery
Brake Lever, Parking
Brake Pedal, Service
Brake Fluid Indicator Light
Brake Fluid Level & Bleeding
Bulbs and Bulb Replacement
C
Choke knob (970 Suzuki only)
Clutch Interlock Switch
Clutch Pedal
Controls
D
Dash Panel Dipswitch Settings
Differential, 11.16:1 & 14.21:1
Differential, 2-Speed (operation)
E
Engine:
Access
Break-in
Cooling
Identification Numbers
Oil Level
Pre-starting Check
Starting:
Automatic Transmission
Manual Transmission
Manual Transmission (diesel)
F
Fuel Gauge
Fuel Specifications
Front Cowl Access
Release Lever
Fuses
G
Gasoline Containing Alcohol
Gauges
Gear Selector:
Manual Transmission
General Information (Inside Front Cover)
Governor Oil Level
Governor & Throttle Hand Control
H
Headlight Replacement
Horn Button
Hour Meter
Hydraulic Lift System
Hydraulic P.T.O.
I
Ignition Switch
Interlock Switch, Clutch
J
Jacks, Jacking Locations And Using A Hoist
Jump Starting
L
Light Switch
Lubrication Chart
Lubrication Recommendations
M
Maintenance Guide
Master Cylinder Reservoir (brake fluid)
Mechanical P.T.O.
O
Oil Warning Light
Oil Level (engine)
P
Park Brake Lever and Adjustment
Parts Illustrations
Power Steering Reservoir
Pre-Starting Check List
P.T.O. Operation
Purge Fuel System (Diesel)
R
Remote Hydraulics
Reservoir, Hydraulic
S
Safety Instructions (Inside Front Cover)
Specifications
Starting the engine:
With Automatic Transmission
With Manual Transmission
Diesel (with manual transmission)
T
Tachometer
Taillight Replacement
Tire Air Pressure
Tire Removal and Replacement:
Front
Rear
Towing a Trailer
Towing The Vehicle:
Manual Transmission
Transmission:
Manual
Automatic
V
Vehicle Identification Number
Voltmeter
W
Water Temp. Gauge & Overheat Buzzer
PARTS INDEX
A
Accelerator pedal
Accessory power plug (12 volt)
Air cleaner, Bracket and Filter:
Suzuki K6A
Suzuki 970 & Perkins diesel
Alternator, Engine belts, Pulleys & Brackets:
Suzuki K6A
Suzuki 970
Perkins diesel
Automatic transmission (Suzuki K6A)
Axle, rear
B
Belts, engine
Body, Hood, Headlights
Brake band (automatic transmission)
Brake lever (parking)
Brake pedal (service)
Brake lines
Brake cylinder (master)
Brake fluid reservoir and bracket
Brakes, front & rear
C
Cables:
Choke (Suzuki 970 only)
Clutch
Shifter
Two-speed differential control
Cam Chain (Suzuki K6A)
Camshaft & components (Suzuki K6A)
Camshaft & components (Suzuki 970)
Carburetor (Suzuki K6A)
Carburetor (Suzuki 970)
Catalytic convertor (Suzuki K6A)
Coil, ignition (Suzuki K6A)
Coil, ignition (Suzuki 970)
Console panel
Clutch assembly (automatic transmission)
Clutch:
Suzuki K6A
Perkins diesel & Suzuki 970
Clutch pedal cable (gasoline)
Clutch linkage (diesel)
Cover, engine
Cowl, front
Crankshaft (Suzuki K6A)
Crankshaft (Suzuki 970)
Cylinder, hydraulic lift
Cylinder block, engine:
Suzuki K6A
Suzuki 970
Cylinder head, engine:
Suzuki K6A
Suzuki 970
D
Delivery pipe (Suzuki K6A)
Differential (two-speed)
Dipstick, oil:
Suzuki K6A
Suzuki 970
Dipstick, transmission (Suzuki K6A auto.)
Distributor (Suzuki K6A)
Distributor (Suzuki 970)
Drawbar
Driveshaft:
Suzuki K6A
E
Electrical components
Emissions control:
Suzuki K6A
Suzuki 970
Engine mounts:
Suzuki K6A & 970
Perkins diesel
Exhaust system:
Suzuki K6A
Suzuki K6A (Catalytic Converter)
F
Fan, radiator cooling
Fenders (rear)
Filter, air cleaner:
Suzuki K6A
Suzuki 970 & diesel
Filter, oil:
Suzuki K6A
Suzuki 970
Flywheel (Suzuki K6A)
Flywheel (Suzuki 970)
Foot throttle, Cable and Linkage
Fuel controller (automatic transmission)
Fuel injector assembly (Suzuki K6A)
Fuel system:
Suzuki K6A & 970
Filter
Pump
Tank
Perkins diesel
Filter
Pump
Tank
Frame
Front Cowl
G
Gaskets, engine:
Perkins
Suzuki K6A
Suzuki 970
Gear shift fork (manual) (Suzuki K6A)
Gear shift fork (Suzuki 970 & Perkins diesel)
Generator (Suzuki K6A)
Governor:
Suzuki K6A & 970
Governor hand control:
Perkins diesel
Suzuki K6A & 970
Governor & throttle linkage (Suzuki K6A & 970)
H
Hand controls (gasoline)
Hand controls (diesel)
Headlights
Horn
Horn button
Hood release latch
Housing, transmission:
Automatic (Suzuki K6A)
Manual (Suzuki K6A)
Suzuki 970 & diesel
Hubs, wheel:
Front
