Cushman Utility Vehicle Turf-Truckster 84043 to 84052 Parts Maintenance Manual 4140039
Brand: Cushman
Type of Manual: Parts Manual, Maintenance Manual, Wiring Diagram
Model: Cushman Turf-Truckster Utility Vehicle
84043 – Perkins 403 Diesel Engine, Manual Transmission
84044 – Perkins 403 Diesel Engine, Manual Transmission, EC
898627 – Suzuki K6 Gas Engine, Manual Transmission
898628 – Suzuki K6 Gas Engine, Automatic Transmission
84052 – Suzuki K6 Gas Engine, 5 Speed Manual Transmission
Part Number: 4140039
Publication Date: 2005
Number of Pages: 150 Pages
Safety
1.1 Operating Safety
1.2 Important Safety Notes
Standards and Publications
2.1 Standards and Publications
Vehicle Identification Numbers
3.1 Vehicle Identification Number
3.2 Engine Identification Numbers
Specifications
4.1 Product Identification
4.2 Engine
4.3 vehicle
4.4 Gear Ratios
4.5 Weights and Dimensions
4.6 Accessories & Support Literature
Adjustments
5.1 General
5.2 Engine Access
5.3 Front Cowl Access
5.4 Access Panels
5.5 Diesel Engine Alternator Belt
5.6 Diesel Engine Hydraulic Pump Belt
5.7 Gas Engine Power Steering-Alternator Belt
5.8 Gas Engine Hydraulic Pump Belt
5.9 Parking Brake Cable
5.10 Torque Specification
Maintenance
6.1 General
6.2 Engine
6.3 Engine Oil
6.4 Power Steering Reservoir
6.5 Muffler and Exhaust
6.6 Engine Overheat Procedure
6.7 Cooling System
6.8 Air Filter
6.9 Jump Starting
6.10 Battery
6.11 Charging Battery
6.12 Hydraulic Hoses
6.13 Hydraulic Reservoir and Filter
6.14 Fuel
6.15 Fuel System
6.16 Tire Pressure
6.17 Tire Removal and Installation
6.18 Raising the vehicle
6.19 Towing the Vehicle
6.20 Governor Oil Level
6.21 Hydraulic Brakes
6.22 Differential Fluid
6.23 Diesel Engine Manual Transmission
6.24 Gas Engine Manual Transmission
6.25 Gas Engine Automatic Transmission
6.26 Electrical System
6.27 Dash Panel
6.28 Headlight Replacement
6.29 Tail Light Replacement
6.30 EFI Diagnostic Check
6.31 Care and Cleaning
6.32 Storage
Troubleshooting
7.1 General
Maintenance & Lubrication Charts
8.1 General
8.2 Lubrication Chart
8.3 Maintenance Charts
Notes
Parts Catalog
10.1 Table Of Contents
Turf Truckster
1.1 Front Body
Turf Truckster
2.1 Engine Cover
Turf Truckster
3.1 Upper ROPS
Turf Truckster
4.1 Throttle Control
Turf Truckster
5.1 Control Console
Turf Truckster
6.1 Parking Brake and High-Low Speed Control
Turf Truckster
7.1 Brake Pedal
Turf Truckster
8.1 Clutch Pedal Linkage
Turf Truckster
9.1 Manual Transmission Shifter Linkage
Spraytek DS 300
10.1 Automatic Transmission Shifter
11.1 Automatic Transmission Oil Cooler
Turf Truckster
12.1 Frame Attachments
Turf Truckster
13.1 Frame, Lower ROPS and Platform
Turf Truckster
14.1 Rear Axle
Turf Truckster
15.1 Front Control Arms
Turf Truckster
16.1 Steering Linkage
Turf Truckster
17.1 Front Brakes
Turf Truckster
18.1 Steering Column
Turf Truckster
19.1 Diesel Radiator
Turf Truckster
20.1 Gas Radiator
Turf Truckster
21.1 Diesel Engine and Transmission Mounting
Turf Truckster
22.1 Gas Engine and MT Mounting
Turf Truckster
23.1 Gas Engine and AT Mounting
Turf Truckster
24.1 Diesel Engine and Clutch
Turf Truckster
25.1 Suzuki Gas Engine
Turf Truckster
26.1 Engine Speed Control
27.1 Exhaust
Turf Truckster
28.1 Governor Linkage
Turf Truckster
29.1 Governor
Turf Truckster
30.1 Gas Engine Remote Oil Fill
31.1 Gas Engine Exhaust
Turf Truckster
32.1 Diesel Fuel System
Turf Truckster
33.1 Gas Fuel System
Turf Truckster
34.1 Hydraulic Tank and Filter
Turf Truckster
35.1 Hydraulic Pump and Filter
Turf Truckster
36.1 Lift Cylinder Circuit
Turf Truckster
37.1 Diesel Electrical Components
Turf Truckster
38.1 Gas Electrical Components
Turf Truckster
39.1 Differential Assembly
Turf Truckster
40.1 Differential Housing
Turf Truckster
41.1 Axle Tubes and Shafts
Turf Truckster
42.1 Front and Shifter Cover
Turf Truckster
43.1 Input, Main and Jack Shafts
Turf Truckster
44.1 Transmission Clutch Release-Shift Selector
Turf Truckster
45.1 Transmission Case
Turf Truckster
46.1 Input and Main Shaft
Turf Truckster
47.1 Gear Shift Fork Linkage
Turf Truckster
48.1 Diesel Engine Electrical Schematic
Turf Truckster
49.1 Diesel Engine Main Harness
Turf Truckster
50.1 Diesel Engine and Fan Harness
Turf Truckster
51.1 Gas Engine Electrical Schematic
52.1 Gas Engine Schematic
Turf Truckster
53.1 Gas Main Harness
53.1 Gas Main Harness (Continued)
