118
6,911
Cushman Sprayer SprayTek DS-300 Safety Operation Manual 4175884-A 2009
Brand: Cushman
Type of Machine: Sprayer
Type of Manual: Safety Manual, Operation Manual
Model: Cushman SprayTek DS-300 With Four Post Roll Over Protective Structure Sprayer
84062 – Kubota D1105-E3B Diesel Engine
84091 – Kubota D1105-E4B Diesel Engine
Part Number: 4175884-A
Publication Date: 2009
Number of Pages: 62 Pages
Safety
2.1 Operating Safety
2.2 Important Safety Notes
2.3 Chemical Handling, Use and Storage
2.4 Recommended Safety Equipment
2.5 Work Area Safety Recommendations
Vehicle Identification Numbers
3.1 Vehicle Identification Number
3.2 Engine Identification Numbers
3.3 SDI Sprayer Tank Identification Numbers
Specifications
4.1 Product Identification
4.2 Engine
4.3 Vehicle
4.4 Weights and Dimensions
4.5 Accessories & Support Literature
5.1 Decals
5.2 Information and Operation Decals
5.3 Speed Chart Decals
Controls
6.1 Icons
6.2 Control Descriptions
6.3 Sprayer Control Systems
Operation
7.1 Daily Inspection
7.2 Interlock System
7.3 Operating Procedures
7.4 Starting
7.5 Parking
7.6 To Drive Vehicle
7.7 Engine Overheat Procedure
7.8 Towing the Vehicle
7.9 Hillside Operation
7.10 Tire Pressure
7.11 Daily maintenance
Sprayer Operation
8.1 Spray System Components
8.2 Control Valves
8.3 System Dynamics
8.4 Sprayer System Check
8.5 Control Pressure Adjustment
8.6 Boom Spray Tip Overlap Check
8.7 Sprayer Tank additives
8.8 Calibration
8.9 Measuring Ground Speed
8.10 Nozzle Tip Size
8.11 Determining Amount of Chemicals Required
8.12 Adding water to tank.
8.13 Mixing Chemicals
8.14 Sprayer Cleaning
Maintenance & Lubrication Charts
9.1 General
9.2 Lubrication Chart
9.3 Maintenance Charts
9.4 Common Replacement Parts
9.5 Kubota Diesel Engine Service Parts
Maintenance
10.1 General
10.2 Engine
10.3 Engine Oil
10.4 Engine Oil Change
10.5 Power Steering Reservoir
10.6 Cooling System
10.7 Engine Overheat Procedure
10.8 Air Filter
10.9 Muffler and Exhaust
10.10 Battery
10.11 Jump Starting
10.12 Charging Battery
10.13 Fuel
10.14 Fuel System
10.15 Tire Pressure
10.16 Tire Removal and Installation
10.17 Raising the vehicle
10.18 Towing the Vehicle
10.19 Hydraulic Brakes
10.20 Differential Fluid
10.21 Transmission
10.22 Electrical System
10.23 Dash Panel
10.24 Headlight Replacement
10.25 Tail Light Replacement
10.26 Care and Cleaning
10.27 Storage
Adjustments
11.1 General
11.2 Engine Access
11.3 Front Cowl Access
11.4 Access Panels
11.5 Alternator Belt
11.6 Sprayer Pump Belt
11.7 Parking Brake Cable
11.8 Torque Specification
Problem Solving
12.1 General
