118
6,911
Cushman Sprayer SprayTek DS-175 84055 Parts Maintenance Manual 4140629-A 2009
Brand: Cushman
Type of Machine: Sprayer
Type of Manual: Parts Manual, Maintenance Manual, Wiring Diagram
Model: Cushman SprayTek DS-175 With Four Post Roll Over Protective Structure Sprayer
84055 – Suzuki K6 Gas Engine, 5 Speed Manual Transmission
Part Number: 4140629-A
Publication Date: 2009
Number of Pages: 132 Pages
1 Safety
1.1 Operating Safety
1.2 Important Safety Notes
1.3 Chemical Handling, Use and Storage
1.4 Recommended Safety Equipment
1.5 Work Area Safety Recommendations
2 Vehicle Identification Numbers
2.1 Vehicle Identification Number
2.2 Engine Identification Numbers
2.3 SDI Sprayer Tank Identification Numbers
3 Specifications
3.1 Product Identification
3.2 Engine
3.3 vehicle
3.4 Gear Ratios
3.5 Weights and Dimensions
3.6 Accessories & Support Literature
4 Adjustments
4.1 General
4.2 Engine Access
4.3 Front Cowl Access
4.4 Access Panels
4.5 Gas Engine Power Steering-Alternator Belt . 13
4.6 Gas Engine Governor Pump Belt
4.7 Sprayer Pump Belt
4.8 Parking Brake Cable
4.9 Torque Specification
5 Maintenance
5.1 General
5.2 Engine
5.3 Engine Oil
5.4 Power Steering Reservoir
5.5 Muffler and Exhaust
5.6 Engine Overheat Procedure
5.7 Cooling System
5.8 Air Filter
5.9 Jump Starting
5.10 Battery
5.11 Charging Battery
5.12 Fuel
5.13 Fuel System
5.14 Tire Pressure
5.15 Tire Removal and Installation
5.16 Raising the vehicle
5.17 Towing the Vehicle
5.18 Governor Oil Level
5.19 Hydraulic Brakes
5.20 Differential Fluid
5.21 Manual Transmission
5.22 Electrical System
5.23 Dash Panel
5.24 Headlight Replacement
5.25 Tail Light Replacement
5.26 EFI Diagnostic Check
5.27 Care and Cleaning
5.28 Sprayer Cleaning
5.29 Storage
6 SDI Sprayer Maintenance
6.1 Spray System Components
6.2 Control Valves
6.3 System Dynamics
6.4 Sprayer System Check
6.5 Control Pressure Adjustment
6.6 Boom Spray Tip Overlap Check
6.7 Sprayer Tank additives
6.8 cALIBRATION
6.9 Measuring Ground Speed
6.10 Nozzle Tip Size
6.11 Determining Amount of Chemicals Required 41
6.12 Adding water to tank.
6.13 Mixing Chemicals
7 Troubleshooting
7.1 General
8 Maintenance & Lubrication Charts
8.1 General
8.2 Lubrication Chart
8.3 Maintenance Charts
8.4 Common Replacement Parts
9 Parts Catalog
9.1 How To Use The Parts Catalog
9.2 To Order Parts
