118
7,392
CUSHMAN Sand Trap Rake Groom Master II Operators Parts Service Manual 841242 1997
Brand: CUSHMAN
Type of Machine: Sand Trap Rake
Type of Manual: Operators Manual, Parts Manual, Service Manual, Wiring Diagram
Model: CUSHMAN Groom Master II Operators Sand Trap Rake
898921A – 3 WHEEL DRIVE, DIESEL
898922A – 3 WHEEL DRIVE, GASOLINE
898924A – 2 WHEEL DRIVE, GASOLINE
Part Number: 841242
Publication Date: 1997
Number of Pages: 78 Pages
Air Cleaner
Ammeter
Battery and Specifications
Bleeding the Fuel System
Brake
Cleaning Radiator
Controls & Gauges
Direction - Speed Control Pedal
Engine Access
Engine Break-In
Engine Cooling System
Engine Overheat Alarm
Engine Serial Numbers
Fuel Gauge
Fuel Recommendations
Hour Meter
Hydraulic Control Levers
Hydraulic Flow Chart
Hydraulic Pump Lever
Ignition Switch
Jump Starting
Maintenance Guide
Maintenance, Daily
Model Number
Oil Level
Operation
Owner Registration
Parts Section
Cultivator
Drag Mat
Fan Rake
Rear Rake
Scarifier
Spiker Adapter - Spiker
Axle, Front (2 Wheel Drive)
Clutch Cover (Gas and Diesel)
Control Group
Engine Group
Frame and Body Panels
Fuel System (Gas and Diesel)
Gauges and Electrical Components
Hydraulic Motor Drive
Rake Lift
Seat, Hubs and Wheels
Steering and Front Fork
Wiring Diagram
Pre-Heat Switch and Glow Plug Indicator
Pre-Starting Check
Seat Adjusting Lever
Serial Number
Service and Maintenance
Set-up
Specifications
Starting the Engine
Storage
Symbol Identification
Throttle
Throttle Control Linkage Adjustment
Tire Pressure
Towing the Unit
Using the Unit
Warranty
Warranty Service
Water Temperature Gauge
