118
6,911
Cushman Front Line Mower 898810 Operation Manual 836744 1991
Brand: Cushman
Type of Machine: Front Line Mower
Model: Cushman Power Uint 898810 Front Line Mower
2 Or 4 Wheel Hydraulic Drive Equipped With 21.5 H.P. Kubota Liquid Cooled Diesel Engine
Part Number: 836744
Publication Date: 1991
Number of Pages: 31 Pages
Accessories/Modifications
Accessory Lift
Air Cleaner
Warning Light
Battery
Maintenance
Specifications
Brake Pedal, Service
Capacities
Controls
Air Intake Screens
Anti-freeze, Mixing
Coolant-Level, Reservoir
Radiator Drain Plug
Radiator Fins, Cleaning
Direction – Speed Control Pedal
Driving the Vehicle
Access
Break-in
Fan Belt Tension
Heat Warning Lamp, Horn and Water
Temperature Gauge
Lubrication
Maintenance
Model Number
Oil Drain Plug
Oil Filter
Oil Warning Light
Operation
Pre-Start Check
Specifications
Starter Switch
Starting
Stopping
Temperature Warning System
Fuel and Oils
Fuel System
Filters
Fuel
Level
Gauge
Tank Filler
Water Separator
Glow Plug
Indicator
Preheating
Switch
Hour Meter
Hydraulic
Drive Control: 2–4 Wheel
Pump Lever
System
Instruments and Gauges
Jacks and Jacking Locations
Jump Starting
Loading or Unloading/Trailer or Trucks
Lubrication Chart
Maintenance, General
Maintenance Guide
Operation
Owner Registration
Parking Brake Lever
Parking the Vehicle
Power Take-Off Lever
Power Take-Off Shaft Tube
Product References
Purging Air from Fuel System
Safe Practices
Seat Adjustment Lever
Serial Number
Vehicle
Service and Maintenance
Service Publications
Specifications
Speeds, Maximum
Starting Switches
Steering Wheel Installation
Storage, Extended
Throttle, Hand
Tire
Air Pressure
Removal
Towing the Vehicle
Traction Assist Pedals
Vehicle Identification
Vehicle Model Number
Warranty, Front Line
Warranty, Service
