7,392
Cushman Front Line Mower 898805 Parts Manual 827823 1985
Brand: Cushman
Type of Machine: Front Line Mower
Type of Manual: Parts Manual, Wiring Diagram
Model: Cushman Power Unit 898805 Front Line Mower With
Part Number: 827823
Publication Date: 1985
Number of Pages: 139 Pages
ACCESSORIES
Anti-Scalp Roller Set, Part No. 885969
Cab Set, Part No. 887020
Drive Conversion Set, Part No. 886982
Grass Caddy Set, Part No. 886768
Leaf Mulcher Set, Part No. 886195
Leaf Mulcher Set, Part No. 886198
Leaf Mulcher Set, Part No. 886314
Light Set, Part No. 885831
Mower Set, 60", Rear, Part No. 888094
Mower Set, 60", Side, Part No. 885095
Mower Set, 72", Rear, Part No. 888096
Mower Set, 72", Side, Part No. 888097
Parts Ordering Procedure For Drop Shipped Accessories
Push Arm Set, Part No. 887875
Push Arm and Drive Shaft Set, Part No. 885619
Push Arm and Yoke Set, Part No. 887876
Roll Over Protection Structure (R.O.P.S.), Part No. 885537
Snow Blade Set, Part No. 887759
Spare Tire, 16-6.50 x 8.00, Part No. 819091
Spare Tire, 23-8.50 x 12.00, 4 Ply/Softtrac, Part No. 886209
Spare Tire, 23-10.50 x 12.00, 4 Ply/Ultratrac, Part No. 886808
Spark Arrestor, Part No. 888381
Wheel Weight Set, Part No. 886694
Yoke Set, Part No. 887877
Accessory Lift Controls
Adapter, Drive Shaft/Flywheel
Adapter, Hydrostat
Air Box
Air Cleaner
Air Intake Filter
Axle, Front
Axle, Rear
Battery Hold Down
Belts, Drive
Body Assembly
Brake Linkage, Shaft Ass’y, Wheel and Parking
Brake, Wheel
Bushings, Plastic
Camshaft
Chain, Lift
Clamps, Clips, Cover, Grommets, Hanger, Ties
Clutch
8310 and Prior
8410 and Later
Controls
Parts
Coil
Connecting Rods
Coupling
Cover, Battery Terminal
Cylinder, Hydraulic Lift
Dipstick, Engine Oil
Direction-Speed Control Linkage
Drive Shaft
Electrical Components
Engine Support, Rear
Fan
Filter
Air Intake, 8210 and Prior
Air Intake, 8220 and Later
Oil
Fuel
Oil, Hydraulic
Flywheel
Fork (Wheel Yoke)
Frame Brace Set
Fuel System
Hoses
Pump, Electric
Supply
Tank
Gaskets, Oil Rings, Seals, Shims
Gearcase
Glow Plug
Governor
Hold-down, Seat Base
Hour Meter
Hubs
Front
Rear
Hydraulic Oil Cooler
8210 and Prior
8220 and Later
8220 and Prior
8310 and Later
Hydrostat
Coupling
Hub
Pulley
Idler, Drive Belt
Injector Tube Shield
Intake and Exhaust System
Mats
Modifications
Muffler
Noise Suppression
Nozzle, Fuel and Holder
Oil Supply Parts
Panels, Body
Pistons
Power Take Off Shaft
8310 and Prior
8410 and Later
Pulley, Drive Shaft
Pulley, Idler Drive Belts
Pump, Injection
Push Rods
Rear Cover
8200 and Prior
8220 and Later
Regulator, Voltage
Reservoir, Coolant
Rocker Arms
Screen Cover
Screens, Air
Seat and Base (Deck)
8410 and Prior
8510 and Later
Hold Open
Latch, Locking
Shock, Seat
Solenoid, Shut Off
Starter Motor w/Solenoid
Steering
Cables, Chains and Pulleys
Gear
Pedal, Bracket
Stop, Lift Chain
Switches
Heat Sensor
Ignition
Micro
Oil Pressure
P.T.O. and Neutral
Solenoid Shut Off
Tank, Fuel
Tank, Hydraulic Oil
Throttle Control, Hand
Throttle, Hand
Timer Unit, Control
Tires
Traction Assist Pedal Linkage
Valves
Exhaust and Intake
Oil Pressure Relief
Hydraulic Lift Control
Water Separator
Weight Count
Wiring Diagram, Vehicle
8410 and Prior
8510 and Later
