master2000
3,750
#41
Good Morning.
I bought this document but cannot download it, they deducted the 15,000 gallons but I can no longer access the download page. You can support me to download it. Greetings.
Tim Nahler
1
50
#45
This does not work. Flashing functionality does not work. It won’t load an INCAL. It uses INSITE.dll not the original dll from original creator. This is a cracked version of the original crack.
Johnmy
8,589
#49
CUMMINS INSITE 8.7.086 FLEET COUNT AND ZAPIT'S Diagnostic Software Unlocked
Size: 1.65 GB (Winrar Files)
Type of software: Diagnostic Software
Database + Interface Language: Only English
Make: Cummins
Amount of Disks: 1 DVD
OS: Windows 7 32 bit, Windows 7 64 bit, Windows 8/8.1 32 bit, Windows 8/8.1 64 bit, Windows 10 32 bit, Windows 10 64 bit (Tested on window 10 pro 1607 64bit)
Version: 8.7.086
New Features: " CLICK HERE "
Cummins INSITE v8.7.0 is a PC-based software application that provides quick and easy access to your engine's electronic performance information, which enables faster service turnaround times. INSITE helps to ensure accurate procedures and diagnosis and limit downtime while increasing productivity and profits.
The current version is v8.7 with professional-level access.
Cummins INSITE software supplies engine information quickly, getting the inside details you need. No matter what kind of equipment you run, INSITE is the one support product to have in your virtual toolbox to fit every Cummins electronic engine.
INSITE performs engine diagnostics and displays electronic engine information on your PC.
With step-by-step diagnostics, built-in engine drawings and schematic diagrams, working with INSITE is easy.
Using this software application will reduce troubleshooting time, errors and incorrect procedures and quickly get your vehicle back on the road again.
Features:
• Quick access to trip information
• Adjust parameters and review/clear fault information quickly and easily
• Easy-to-follow troubleshooting assistance
• Wiring and sensor location diagrams
• Store engine and trip information for future use, or as programming templates
Hi. I thought about it several times to buy this 8.7, and I liked it because it says in the description that it supports W7, and the first thing that comes up when I go to install is "This operating system is not supported by insite", and then? What do I do now? Because I have W7 64b because I never liked w10
Support
Cleaner
199
94,406,749
#50
Dear friend, dont worry, my team will check & support you! Check your mail & conversation!
