Admin
Cleaner
45
674,085
Cummins Calterm v5.8.0.027 2022 Install + Active
Cummins Calterm v 5.8.0.027 2022 Install + Active
1. Download DVD Setup
2. If need license: Install and give me HWID file
3. If need do install + active full contact us
4. Contact us for detail:
Contact us:
admin@autorepairmanuals.ws
gallons@autorepairmanuals.ws
autorepairmanuals.ws@gmail.com
Description
Calterm is an engineering development tool used to monitor Electronic Control Modules for Cummins engine systems and to alter the calibration data contained therein. Calterm is designed to modify fueling calibration parameters and feature settings in an engineering development and test environment.
Purpose
The development process for electronic engines requires PC support tools which interface to the electronic subsystem, and its various feature sets. Calterm is used to increase the productivity of the engineers developing electronic engine features by providing diagnostics, simulation, and value manipulation capabilities for Electronic Control Modules (ECMs).
As is the case with most support tools, Calterm attempts to work with all of the features in the ECM. However, this superset of functionality is not always feasible given the rapid growth and change being experienced in Cummins’ electronic systems. As a way to try to give the most support to every electronic engine program, this tool will provide a base set of capabilities which will work on any ECM following the CORE Tools Interface standards. Customized or unique capabilities will then be added, as they are needed.
