Martin Welker
104
231,017
Crown Forklift CGC15S-9 CGC18S-9 CGC20SC-9 Engine MMC 2.0L Parts Manual
Brand: Crown
Type of Machine: Forklift
Model: Crown CGC15S-9 CGC18S-9 CGC20SC-9 Forklift
Engine: MMC 2.0L
Number of Pages: 733 Pages
Chassis Parts
Gene1450 -Suppression Assy
Gene1450 -Control Group,Brake - Inching
Gene1450 -Frame Group - Gc15s/18s/20sc-9
Gene1450 -Frame Assy - Gc15s/18s/20sc-9
Gene1450 -Mount Group - Steer Wheel
Gene1450 -Mount Group - Tilt
Gene1450 -Mount Group - Control Valve
Gene1450 -Mount Group - Fcu
Gene1450 -Mount Group - Power Train
Gene1450 -Mount Group - Overhead Guard
Gene1450 -Mount Group - Lp Tank
Gene1450 -Axle Group,Steer - Sub Assy
Gene1450 -Muffler Group
Gene1450 -Plate Assy,Floor - Crown
Gene1450 -Battery Group
Gene1450 -Panel - Group Crown
Gene1450 -Horn - Group
Gene1450 -Wiring Group
Gene1450 -Filter,Hydraulic Oil - Group
Gene1450 -Cleaner Group,Air
Gene1450 -Cleaner Assy,Air - Gc15/18/20sc-9
Gene1450 -Line Group - Power Steering
Gene1450 -Line Group - Mast Operation
Gene1450 -Line Group - Coolant
Gene1450 -Tank Assy,Reserve
Gene1450 -Line Group - Fuel
Gene1450 -Radiator Group
Gene1450 -Radiator Ass - Gc15
Gene1450 -Mount Group - Steer Axle
Gene1450 -Cylinder,Steering - P/S
Gene1450 -Plate Assy - Lp Tank
Gene1450 -Filter Assy,Fuel - Lpg
Ocra1000 -Radiator Assy - Open Core
Tilt1090 -Cylinder Group,Tilt - Gc15s-5 - 10/5
Tilt1090 -Cylinder,Tilt - 10f/8b,Gc18s-5
Ctwt1020 -Counterweight Group - 1.5ton, Crown
Adco1080 -Radiator Assy - Cooling Module
Tool1000 -Tool Gp - Dm/Gm
Tilt1250 -Cylinder,Tilt - 8f/8b,Gc18s-5
Ctwt1020 -Counterweight Group - 1.8ton, Crown
Ctwt1020 -Counterweight Group - 2.0ton, Crown
Driving Module
Tire1310 -Tire And Wheel Group - Gc15,Plain,Black,Na
Tire1310 -Mounting Gp-Drive Wheel - 2 Required
Tire1370 -Tire And Wheel Group - Gc15,Plain,Nm,Narro
Tire1540 -Tire And Wheel Group - Gc15,Lug,Nm,Narrow
Tire1560 -Tire And Wheel Group - Gc15,Lug,Black,Narr
Tire1320 -Tire And Wheel Group - Gc15,Plain,Black,Wi
Tire1380 -Tire And Wheel Group - Gc15,Plain,Nm,Wide
Tire1550 -Tire And Wheel Group - Gc15,Lug,Nm,Wide
Tire1570 -Tire And Wheel Group - Gc15,Lug,Black,Wide
Gene1450 -Axle,Drive - Module,Gc15
Gene1450 -Axle Assy,Drive - Kd10a
Gene1450 -Housing Assy,Axle - Sub
Gene1450 -Adjuster Assy - Brake Piston
Gene1450 -Carrier Assy - Diff
Gene1450 -Differential Assy
Gene1450 -Valve Assy,Brake
Gene1450 -Hub Assy
Gene1450 -Carrier Assy - No.2
Gene1450 -Hub Assy - Sub
Gene1450 -Transmission Group - Sub Module,Gc15s-9
Gene1450 -Transmission Assy - Kt20a
Gene1450 -Case Assy - Tm
Gene1450 -Valve Assy,Control
Gene1450 -Housing Assy - T/C
Gene1450 -Gear Assy - Pto Driven,Main
Gene1450 -Gear Assy - Pto Driven,Charge
Gene1450 -Stator Assy - Hub
Gene1450 -Clutch Assy - Fwd
Gene1450 -Drum Assy - Fwd
Gene1450 -Clutch Assy - Rev
Gene1450 -Drum Assy - Rev
Gene1450 -Gear Assy - Main Output
Gene1450 -Pump,Gear
Engine
Gene1450 -Engine Arrangement - Mmc2.0l
Gene1450 -Engine Assy - Mmc2.0l_Gc15
Gene1450 -Balancer - Group
Gene1450 -Mixer,Fuel - Mmc2.4l_Group
Gene1450 -Bracket,Oil Pump - Mmc2.4l_Group
Gene1450 -Cover,Engine - Oil Pan Group
Gene1450 -Cover Assy,Rocker - Mmc2.4l_Group
Gene1450 -Tensioner,Belt - Mmc2.4l_Group_Hi-Fan
Gene1450 -Block,Cylinder - Group
Gene1450 -Camshaft Group - Valve Group
Gene1450 -Crankshaft Group - Piston Group
Gene1450 -Flywheel - Mmc2.4l_Group
Gene1450 -Head Group,Cylinder
Gene1450 -Housing Group,Flywheel - Mmc2.4l_Group
Gene1450 -Mount Group - Mmc2.4l_Ecu
Gene1450 -Drive Group,Fan - Mmc2.4l_Group
Gene1450 -Manifold Assy,Exhaust - Mmc2.4l_Group
Gene1450 -Manifold Assy,Intake - Mmc2.4l_Group
Gene1450 -Starter - Mmc2.4l_Group
Gene1450 -Coil,Ignition - Mmc2.4l_Group
Gene1450 -Electric Group
Gene1450 -Thermostat Kit - Group_Mmc2.4l
Gene1450 -Coolant Unit - Group - Regulator
Gene1450 -Filter,Oil - Group - Remote
Gene1450 -Gasket,Exhaust Manifold - Mmc2.4l_Group
Gene1450 -Gasket,Intake Manifold - Mmc2.4l_Group
Gene1450 -Pump,Oil - Mmc2.4l_Group
Gene1450 -Pump,Water - Mmc2.4l_Group
Gene1450 -Valve Assy,Fuel Lock - Mmc2.4l_Group
Gene1450 -Valve,Throttle - Mmc2.4l_Group
Gene1450 -Hose,Air - Mmc2.4l_Group_Pcv Fresh
Gene1450 -Hose,Air - Mmc2.4l_Group_Pcv Foul
Gene1450 -Pipe,Water Outlet - Mmc2.4l_Group
Gene1450 -Dipstick,Oil - Group
Operating Module
Adop1010 -Option-Cup Holder
Alar1000 -Option_Back Up Alarm-Outside
Alar1000 -Backup Alarm,Outside
Alar1010 -Option_Back Up Alarm-Inside
Aush1080 -Option_Autoshift
Crve1020 -Valve Group-Gc15,3sec/3lever
Crve1020 -Valve Assy,Control-3sec/3lever - Gp삭제
Crve1020 -Valve Assy-Mcv-3s, D15s
Crve1020 -Valve Assy,Relief
Crve1020 -Valve Assy-Outlet Section
Crve1020 -Valve Assy,Control-3sec, 3lever
Crve1030 -Valve Group-Gc15,4sec/4lever
Crve1030 -Valve Assy,Control-4sec/4lever-
Crve1030 -Valve Assy-Mcv-4 Section
Crve1030 -Valve Assy-Inlet Section
Crve1030 -Valve,Control-Section,Tilt
Crve1030 -Valve Assy-Aux
Crve1030 -Valve Assy,Control-4sec, 4lever
Fann1020 -Option-Fan
Fcuu1010 -Fcu Basic,Lp-Gc15/18s,20sc-9
Fcuu1010 -Cover Assy-Proto,Gc15
Fcuu1010 -Steering Group-Proto,Gc15
Fcuu1010 -Pedal Group-Proto,Gc15
Fcuu1010 -Pedal Assy-Inching & Brake
Fcuu1010 -Instrument Group-Gc15
Fcuu1010 -Wire Group-Proto,Gc15
Fcuu1010 -Switch Assy,Key-Ignition
Fcuu1010 -Reservoir-Group
Fcuu1010 -Wheel Group-D280mm
Fiex1010 -Extinguisher Assy,Fire
Inta1000 -Option-Precleaner
Knob1000 -Knob-Steering Wheel
Lcom1000 -Option-Combination Light-Halogen
Lcom1000 -Option-Combination Lamp-Inhouse Assy
Lcom1160 -Option-Combination Light-Led
Ldvc1010 -Option_Clamp Interlocking-Fft Mast
Lfrt1000 -Option_Working Light-Front/Halogen
Lfrt1300 -Option_Working Light-Front/Led
Lrea1000 -Option-Rear Lamp-Halogen
Lrea1240 -Option-Rear Lamp-Led
Lstb1030 -Strobe-Amber, Below
Lstb1050 -Strobe-Amber, Above (Kit)
Mirr1010 -Mirror Gp,Back,Large,No Glass
Mirr1010 -Mirror Assy
Ovhd1000 -Guard Group,Overhead-Gc15/18s/20sc-9
Ovhd1000 -Leg Gp,Std-Gc15/18s/20sc-9
Owir1020 -Option-Wire For Spot Light-W/Combi Lamp
Rgbr1000 -Grip-Group,Rear
Sbel1020 -Belt,Seat-Interlock
Seat1080 -Seat Group-W/ Hiprest,Gc15
Seat1080 -Seat-Sus/Pvc/Hip
Seat1090 -Seat Group-Grammer-W/O Armrest
Seat1090 -Seat Group-Fabric Sus, W/ Hip
Warn1080 -Option_Blue Safety Light-Rear/Always On
Warn1090 -Option_Blue Safety Light-Front&Rear/Alwa
Adrl1000 -Option-Room Light Lh
Adrl1010 -Option-Room Light Rh
Fcuu1070 -Front Cockpit Unit-Lp,Crown
Fcuu1070 -Wheel Group-D280mm, Crown
Ovhd1020 -Overhead Guard Group- Ovhd1020 -Leg Group-Rear,Crown,Gc15
Ovhd1120 -Overhead Guard Group-83inch
Ovhd1120 -Leg Group-Rear,83inch
Ovhd2160 -Overhead Guard Group-83inch,Crown
Ovhd2160 -Leg Group-Rear,83inch,Crown
Seat1060 -Seat Group-Sears-Vinyl Suspension
Seat1060 -Seat-Sus/Pvc
Seat1570 -Seat Gp-Sears-Vinyl Sus W/Arm,12v
Seat1570 -Seat-Sus/Pvc/Armrest/12v
Spco1030 -Option-Speed Limit With Asc-1ton, Fcu
Warn1120 -Option-Blue Safety Light-Rear By Gear
Warn1140 -Option-Blue Safety Light-F&R By Gear
Dico1060 -Ch/Ov Ar-Mono Pedal-Fcu
Dico1060 -Pedal Assy-Inching & Brake, Mono Pedal
Alar1020 -Option_Back Up Alarm-Outside,Audible
Dico1060 -Ch/Ov Ar-Mono Pedal-W/Neutral
Ldvc1020 -Option_Clamp Interlocking-Ff Mast
Wtsl1000 -Option-Weight Scale-Display Mount
Wtsl1000 -Option-Weight Scale-Sensor Mount
Warn1110 -Option_Blue Safety Light-Front/Always On
Crve2530 -Valve Group-Gc15,4sec/3lever
Crve2530 -Valve Assy,Control-4sec, 3lever
Crve2530 -Valve Assy,Control-4sec/3lever-
Seat1020 -Seat Group,W/ Hiprest
Seat1020 -Seat - Static/Pvc/Hiprest
Seat1070 -Seat Group-W/ Armrest,Gc15
Seat1070 -Seat-Sus/Pvc/Arm
Pmir1000 -Option-Panoramic Mirror
Adop1020 -Option-Clipboard
Lstb1020 -Strobe-Red, Above
Sbel1070 -Seat Belt Interlock Gp-Grammer
Owir1010 -Wiring Group,Option - Optional Light(Only
Fiex1050 -Extinguisher,Fire-Group,0.7kg,Abc
Seat1370 -Seat,Operator-Grammer,Std
Lstb1000 -Strobe-Red, Below
Fiex1020 -Extinguisher Assy,Fire
Fiex1030 -Extinguisher Assy,Fire
Lofi1000 -Low Lp Fuel Warning Kit
Adco1080 -Option_Heavy Duty Cooling
Homo1000 -Option_Homologation-Ce
Homo1050 -Option_Homologation-Ul-Lps
Ocra1000 -Option_Open Core Radiator
Rasc1000 -Option_Radiator Screen
Strp1000 -Option_Strap,Static Ground
Bepl1000 -Option_Under Protection
Lvsp1020 -Option_Vented Side Panel
Rasc1010 -Option-Radiator Screen-Heayy Duty
Warn1130 -Option-Blue Safety Light-Front By Gear
Mast
Atli1010 -Lines Group Att-Ffl,Pri-3way
Atli1010 -Line Group,Side Shift-Full Free Triple
Atli1020 -Lines Group Att-Fft,Pri-3way
Atli1050 -Fork;D580475-Hook On, 2.0ton, 45mm
Atli1050 -Line Group,Att,Sec-3way(Rh)
Atli1100 -Lines Group Att-Ffl,Pri-4way
Atli1100 -Lines Gp,Att,Secondary,Ffl,3 Way,Lh
Atli1110 -Lines Group Att-Fft,Pri-4way
Atli1110 -Hose Group,Hydraulic-Secondary,3way,Left
Atli1140 -Line Group,Attachment-Sec(3way-Lh)
Mastff3300 -Mast Group-Ffl3300
Mastff3300 -Mast Gp - Std
Mastff3300 -Lift Group,Primary-Full Free
Mastff3300 -Lift Group-Ffl-Sec.-3300mm
Mastft4500 -Mast Group-Fft4500
Mastft4500 -Cylinder,Primary-Eg 1ton (Mfh :4500)
Mastft4500 -Lift Group-Fftl-Sec.-4500mm
Mastft4750 -Mast Group-Fft4750
Mastft4750 -Lift -Cylinder, 1ton (Mfh :4750)
Mastft4750 -Cylinder,Lift-Fft-Secondary
Mastft5000 -Mast Group-Fft5000
Mastft5000 -Lift Group-Fftl-Sec.-5000mm
Mastft5500 -Mast Group-Fft5500
Mastft5500 -Cylinder,Primary-Eg 1ton (Mfh :5500)
Mastft5500 -Lift Group-Fftl-Sec.-5500mm
Atli1000 -Lines Group Att-Std,Pri-3way
Atli1090 -Lines Group Att-Std,Pri-4way
Mastff3000 -Mount Assy-Lift,Ffl
Mastff3000 -Mount Group-Mast
Mastff3000 -Mast Group-Ffl3000
Mastff3000 -Lift Group,Primary-Full Free
Mastff3000 -Lift Group-Ffl-Sec.-3000mm
Mastff3000 -Relay-Lift
Mastff3500 -Mast Group-Ffl3500
Mastff3500 -Cylinder Group,Lift-Ffl
Mastff3500 -Cylinder Group,Lift-Ffl Sec 3500mm
Mastft4000 -Mast Group-Fft4000
Mastft4000 -Mast Gp - Fft
Mastft4000 -Mount Assy-Lift,Fft
Mastft4000 -Cylinder,Primary-Eg 1ton (Mfh :4000)
Mastft4000 -Relay Assy-Fft-Lift
Mastft4000 -Lift Group-Fftl-Sec.-4000mm
Mastft6000 -Mast Group-Fft6000
Mastft6000 -Cylinder,Primary-Eg 1ton (Mfh :6000)
Mastft6000 -Lift Group-Fftl-Sec.-6000mm
Mastst2000 -Mount Group,Lift;Std,Bsc
Mastst2000 -Mast Group-Std2000
Mastst2000 -Cylinder Group,Lift-Std 2000mm
Mastst2000 -Relay-Lift
Mastst3000 -Mast Group-Std3000
Mastst3000 -Lift Group,Standard-3000mm
Mastst3300 -Mast Group-Std3300
Mastst3300 -Lift Group,Standard-3300mm
Mastst3700 -Mast Group-Std3700
Mastst3700 -Lift Group,Standard-3700mm
Mastst5000 -Mast Group-Std5000
Mastst5000 -Lift Group,Standard-5000mm
Atli1000 -Line Group,Side Shift-Standard
Atli1030 -Line Group,Attachment-Secondary,3way
Atli1040 -Lines Gp,Att,Secondary,Ffl,3 Way
Atli1090 -Line Group,Attachment-Secondary,4way
Atli1150 -Line Group,Attachment-Secondary,4way
Atli1120 -Line Group,Attachment-Sec(3way-Lh)
Atli1130 -Line Group,Attachment-Sec(3way-Lh)
Forks
Fork1000 -Hook, 35x100x900, Cl2
Fork1030 -Hook, 35x100x1050, Cl2
Fork1060 -Hook, 35x100x1200, Cl2
Fork1110 -Fork - D580471 - Hook On, 2.0ton, 40mm
Fork1160 -Hook, 40x100x1500, Cl2
Fork1080 -Fork-D580474-Hook On, 2.0ton, 40mm
Fork1070 -Hook, 40x100x1600, Cl2
Fcap1000 -Fork Cap-230106-00010-1.5-2.0ton
Fcap1030 -Fork Cap-230106-00011-1.5-2.0ton
Fcap1060 -Fork Cap-230106-00012-1.5-2.0ton
Fork1010 -Hook, 35x100x950, Cl2
Fork1020 -Hook, 35x100x1000, Cl2
Fork1040 -Hook, 35x100x1100, Cl2
Fork1050 -Hook, 35x100x1150, Cl2
Fork1070 -Hook, 35x100x1350, Cl2
Fork1090 -Fork-D580469-Hook On, 2.0ton, 40mm
Fork1120 -Fork-D802107-Hook On, 2.0ton, 40mm
Fork1130 -Fork-D580472-Hook On, 2.0ton, 40mm
Fork1140 -Fork-D580473-Hook On, 2.0ton, 40mm
Fork1240 -Fork-D580475-Hook On, 2.0ton, 45mm
Fork1250 -Fork-D580476;Hook On, 2.0ton, 45mm
Fork2180 -Hook, 35x100x900, Att, Cl2
Fork2190 -Hook, 35x100x1000, Att, Cl2
Fork2200 -Hook, 35x100x1050, Att, Cl2
Fork2210 -Hook, 35x100x1150, Att, Cl2
Fork2220 -Hook, 35x100x1200, Att, Cl2
Fork2240 -Fork, Attachment-230106-00042-Hook On, 2
Fork2250 -Fork, Attachment-230106-00043;Hook On, 2
Fork2260 -Fork, Attachment - 230106-00044 - Hook On, 2
Fork2270 -Fork, Attachment-230106-00045-Hook On, 2
Carriage
Atli1170 -Lines Group Att-Fft,Pri-4way
Atli1160 -Lines Group Att-Ffl,Pri-4way
Atli1160 -Line Group-Old
Qick1000 -Coupling Group-3way
Qick1000 -Coupling,Quick-4way
Fopr2920 -Mount Group-Carriage
Fopr2920 -Mount Group - Int.Shifting Fork Positioner
Fopr2920 -Line Group
Fopr2960 -Line Group-Carriage(Std)
Fopr2960 -Mount Group - Int.Shifting Fork Positioner
Fopr2960 -Cylinder Group,Lift-Standard
Fopr2970 -Line Group-Carriage (Ffl)
Fopr2980 -Line Group-Carriage (Fft)
Fopr3220 -Backrest Gp
Bart1330 -Rest Assy,Back-Gc,Bc15/18/20s(C) 1220mm
Bart1800 -Rest,Back-Load Gp-Change Over Arr
Bart1830 -Arrangement,Changeover-Load Backrest Gro
Carr1000 -Carriage Arrangement-Std
Carr1730 -Arrangement,Changeover-Carriage(Std,Crow
Carr1740 -Arrangement,Changeover-Carriage(Ff,Crown
Carr1750 -Arrangement,Changeover-Carriage(Fft,Crow
Sdsf1380 -Mount-Carriage
Sdsf1380 -Carriage Group
Sdsf1380 -Cylinder,Gas - Side Shifter
Sdsf1380 -Carriage Group-Integral Side Shifter(Std
Sdsf1380 -Line Group-Std
Sdsf1600 -Line Group-Carriage - Ff, Fft
Sdsf1600 -Carriage Group
Sdsf1600 -Carriage Group-Integral Side Shifter(Ff)
Sdsf1900 -Side Shifter Assy-Gp-Change Over Arr
Sdsf2040 -Carriage Group,Crown
Sdsf2050 -Carriage Group,Crown
Sdsf2060 -Carriage Group,Crown
Miscellaneous Parts
Gene1450 -Location Chart Part
Crown, Parts Catalog, CGC15S-9, Forklift,
