Martin Welker
104
230,310
Crown Forklift CB40X-7 CB45X-7 CB50X-7 Parts Manual
Brand: Crown
Type of Machine: Forklift
Model: Crown CB40X-7 CB45X-7 CB50X-7 Forklift
Number of Pages: 485 Pages
Power Unit Parts
Slio-Ch/Ov Ar. Slio
Siro-Ch/Ov Ar. Srio
Controller Group,Drive
Mount Group - Overhead Guard
Master Cylinder As - Odb
Cylinder,Steering P/S, D45s
Gear Pump Assy
Line Group - Service Brake
Plate Assy,Floor
Mount Group - Fcu
Brake Group
Hood Group - B40/50x
Brake Assy - B50x-7
Tank,Hydraulic
Panel - Outer
Mount Group - Steer Axle
Line Group - Ps
Pump,Gear - Group
Wiring Group - B50x-7
Panel,Control - B50x-7
Mount Group - Tilt Cylinder
Line Group - Mo
Axle Assy,Steer
Axle Group,Steer
Ctwt-Weight Group,Counter B45x-7
Ctwt-Weight Group,Counter - B40x-7
Ctwt-Weight Group,Counter - B50x-7
Moun-Mounting Gp. - Ovhg,Fcu(Bt/Bx-7)
Strp-Strap - Gp-Ground
Tilt-Cylinder Gp-Tilt - Std
Tool-Tool Gp
Baco-Connector Group - Battery - B50x-7 Inside
Baco-Connector Group - Battery - B50x-7 Outside
Siro-Ch/Ov Ar. - Srio, B40x
Slio-Ch/Ov Ar. - Silo, B40x
Rubc-Tilt Boots Group - Front
Bepl-Changeover Ar. - Motor Cover
Hood Module - Std
Cylinder,Side Shift - Attachment
Cylinder,Steering - P/S, D45s
Lang-Seat Group - Suspension (Nacd)
Driving Module Parts
Tire-Tire Group Solid,Double,Odb
Tire-Tire Group - Drive & Rear,B40x
Tire-Tire Group - Drive & Rear,B45/50x
Tire-Tire Group - Non-Marking, B45/50x
Axle Group,Drive
Tire-Tire Group - Non-Marking, B40x
Axle Assy,Drive - Axle Assy,Drive - Lh - Pms85
Axle Assy,Drive - Axle Assy,Drive - Rh - Pms85
Electric Power Parts
Batt-Battery,Local,80v,720ah
Char-Charger Ar
Char-Charger Gp
Char-Charge Ar
Motor Assy,Drive
Motor Assy,Pump
Motor,Hydraulic
Dmtr-Motor Assy,Drive - B50x-7 - Ip54
Dmtr-Motor Assy,Pump
Char-Charger As-Battery - Std - 3p Ac220v/60hz
Char-Charger As-Battery - Option - 3p Ac380v/60hz
Char-Charger As-Battery - Option - 3p Ac440v/60hz
Char-Charger Gp - 3p,440v,930ah
Batt-Battery Gp - Afs/Sunlight/80v/930ah
Operating Module Parts
Alar-Alarm Group - Audiable
Alar-Alarm Group - Back Up
Lcom-Lamp Assy,Comb -Rh (Halogen)
Lcom-Lamp As-Combi - Ohg,F/Led & R/Led
Lcom-Lamp Assy,Combination - Head(Fcu)
Lcom-Lamp Assy,Combo Lh (Halogen)
Lcom-Harness Gp - Led
Lcom-Harness Gp - Halogen
Crve-Valve Arrangement - 2s/2l - With F/R
Crve-Valve Sub Assy - 2sec 2lev
Crve-Valve Arrangement - 4s/4l - With F/R
Crve-Valve Assy - 2sec 2lev - With Fr,Tilt Sw
Crve-Valve Assy - 2sec 2lev- With Fr
Crve-Wiring Group- B50x-7 Fingertip
Crve-Valve Arrangement - 3s/3l - With F/R
Crve-Valve Arrangement - 2s/2l - With F/R,Tilt
Crve-Valve Assy - 3sec 3lev - With Fr
Crve-Valve Sub Assy - 3sec 3lev
Crve-Rest,Arm - Fingertip 3way
Crve-Rest,Arm - Assy-Fingertip
Crve-Valve Assy - 3sec 3lev - With Fr,Tilt Sw
Crve-Valve Arrangement - 4s/4l - With F/R,Tilt
Crve-Valve Arrangement - 3s/3l - With F/R,Tilt
Crve-Mount Group - Armrest,3way - Daewon
Crve-Hood Group - Fingertip
Crve-Valve Assy,Control - 4 Section
Crve-Bracket,Valve Mnt - 4 Lever
Crve-Switch Assy - Group
Crve-Valve Assy,Control - 3 Section
Crve-Bracket Assy - Levervalve 3 Spool
Crve-Valve Assy,Control - 2 Section
Crve-Valve Assy - 4sec 4lev - With Fr
Dico-Switch Assy - Monopedal
Dico-Arrangement,Changeover - Mono Ped Control
Empd-Emergency Power Disconnect Gp. - B22/25x
Fcuu-Front Cockpit Unit,Basic - Basic
Fcuu-Cover Group
Fcuu-Wheel Group - D280mm
Fcuu-Reservoir, Fcu
Fcuu-Control Unit - Parking
Fcuu-Steering Group - B50x, Fingertip
Fcuu-Instrument Group
Fcuu-Front Cockpit Unit,Basic - Fingertip
Fcuu-Steering Unit
Lfrt-Harness Gp - Led
Lfrt-Harness Gp - Halogen
Lfrt-Lamp - Head
Lfrt-Lamp Group - Head(Fcu)
Lfrt-Lamp Assy - Head(Ohd)-Led
Knob-Knob-Steering Wheel
Ovhd-Overhead Guard
Ovhd-Overhead Guard - 2350mm
Ovhd-Overhead Guard - 2350mm, Slio/Srio
Lrea-Rear Lamp Gp - Halogen
Lrea-Lamp As-Combi - Ohg,F/Led & R/Led
Mirr-Mirror Gp - Large
Mirr-Changeover Ar. - Paranomic Mirror
Warn-Ch/Ov Blue Spot Light - W/Mtg.& Harness Ho
Seat-Seat Group-Ama - Without Armrest
Seat-Seat Gp-Grammer - Std+Armrest
Seat-Seat Group - Grammer,Full,12v
Seat-Seat Group-Ama - Std
Seat-Seat Group - Static
Seat-Seat Assy - Static,Nacd,Cloth
Seat-Seat Assy - Static - Std (Non-Nacd)
Seat-Seat Group - Suspension (Nacd)
Seat-Seat,Suspension - W/ Arm Rest
Seat-Seat Assy - Ama - Komodo - Std
Seat-Seat Group - Static (Nacd Cloth)
Seat-Seat Group - Static (Nacd)
Seat-Seat Assy - Suspension,W/ Belt S
Seat-Seat Group - Grammer Full Seat
Seat-Seat Assy - Static - Nacd
Seat-Seat Assy - Static,Nacd,Vinyl
Seat-Seat Group - Suspension (Nacd Cloth)
Seat-Seat,Operator - Grammer,Std,Armrest
Seat-Seat Assy - Static,Non-Nacd
Seat-Seat Assy - Static - Nacd,Cloth
Seat-Seat (Vinyl) Suspension-Armrest
Seat-Seat - Ama
Seat-Seat - Ama - W/Armrest
Seat-Grammer Seat Assy
Sbel-Interlock Gp - Seat Belt
Lstb-Strobe Assy - Amber, Below
Lstb-Lamp - Head
Lstb-Strobe Assy - Red, Above
Lstb-Strobe Assy - Red, Below
Lstb-Strobe Assy - Amber, Above
Appk-Aux. Power Package Gp. - B22/35x
Crve-Bracket Assy,Valve - 2spool
Crve-Valve Group
Crve-Valve Gp-Section-Lift
Crve-Ring,Wear - D50/70s-5
Crve-Valve Assy - Section
Homo-Ul Safety - Type Ee
Crve-Line Group - Fingertip, 3way
Crve-Wiring Group - B50x-7 Fingertip
Crve-Mount Group - Armrest,4way - Daewon
Crve-Line Group - Fingertip, 4way
Crve-Mount Group - Armrest,4way - Grammer
Crve-Rest,Arm - Fingertip 4way
Crve-Mount Group - Armrest,3way - Grammer
Crve-Valve - Module,Fingertip,4way
Crve-Valve- Module,Fingertip,3way
Dico-Cover Group
Crve-Valve Assy - 3s/3l - Normal/Auto Tilt
Crve-Valve Arrangement - 3s/3l - Tilt
Crve-Valve Assy- 4s/4l - Normal- Auto Tilt
Crve-Valve Arrangement- 4s/4l - Tilt
Dico-Arrangement,Changeover - F/R Lever
Crve-Valve Assy- 3s/3l - Normal
Crve-Valve Assy - 4s/4l - Normal
Crve-Valve Arrangement - 4s/4l - Normal
Crve-Valve Arrangement - 2s/2l - Tilt
Crve-Valve Assy - 2s/2l- Normal
Crve-Valve Arrangement - 2s/2l - Normal
Crve-Valve Arrangement - 3s/3l - Normal
Tmst-Nfc Harness
Opli-Ch/Ov Autotilt Leveling - Manual, Lines Gp
