Martin Welker
104
230,310
Crown Forklift C-5 Pneumatic Engine 4024AN20 Parts Manual
Brand: Crown
Type of Machine: Forklift
Model: Crown C-5 Pneumatic Engine 4024AN20 Forklift
Number of Pages: 917 Pages
Frame and Chassis
Power Unit
Suspension Seat
Battery
B-Post Handle
B-Post Handle - Hard Cabin
Counterweight
Extended Fenders
FlexSeat™
Hard Cabin Components
Hard Cabin Doors
LPG Bottle Bracket - Fixed
LPG Bottle Bracket - Tiltable
Motor Mounting Brackets
Overhead Guard and Covers
Seat Bonnet - Hard Cabin
Seat Deck and Support
LP Fuel Bottle Bracket - Swing Out
Hydraulic Parts
Reservoir, Filter, and Valve
Suction and Return Lines
Main Interlock
Steering Lines
Power Brake Components
Lift & Tilt Line - TL/TT
Lift and Tilt Lines – TL, TT
Power Unit Accessory Lines - TL, TT
Pump Hoses
Lift and Lower Lines - TL Mast
Accessory Lines - TL Mast
Lift and Lower Lines – TT Mast
Accessory Lines - TT Mast
Manual Hoist Lowering - TL, TT
Lift and Tilt Lines - Quad
Power Unit Accessory Lines - Quad
Manual Hoist Lowering - Quad
Hydraulic Pump - 4,000/5,000 lb Capacity
Hydraulic Motor
Control Valve - Three Spool
Control Valve - Four Spool
4-Position Pressure Relief Valve
Carton Clamp Interlock
Lift Lines - Quad
Lift/Lower Manifold Block - Quad Mast
Control Valve Linkage - No Accessories
Control Valve Linkage - First Accessory
Control Valve Linkage - Second Accessory
Control Lever
Carriage Hydraulics - One Accessory - TL, TT
Carriage Hydraulics – TT Mast
Carriage Hydraulics - One Accessory - Quad
Carriage Hydraulics - Two Accessories - TL
Carriage Hydraulics - Two Accessories - TT
Carriage Plumbing - Two Accessories
Quad Carriage Hydraulics - Two Accessories
Carriage Hydraulics – Quad Mast
Engine and Transaxle Parts
Transaxle Mounting - Power Brake
Transaxle Axle and Brake Mounting - Power Brake
Transaxle Transmission Housing
Transaxle Primary Shaft - Clutch
Transaxle Secondary Shaft
Transaxle Intermediate Shaft and PTO Output Shaft
Transaxle Converter
Transaxle Control Valve and Inching Lever
Transaxle Axle Housing
Transaxle Bevel Gear Set and Output Shaft
Transaxle Differential and Half-Shafts
Transmission Cooling System
Transaxle - Sensors
Engine Mounts and Lift Straps
Wiring Harness - LP Fuel
Oil Separator
Oil Pan
Rocker Arm Cover
Water Pump and Thermostat
Oil Cooler and Filter
Starter Motor
Engine Oil Dipstick
Ignition System
Fan Drive and Belt Tensioner
Timing Gear Cover and Crankshaft Pulley
Fuel System
Rear Oil Seal
Auxiliary Drive
Oil Pump
Exhaust Manifold
Flywheel and Housing
Rocker Arm
Crankshaft/Bearings
Balancer Shaft
Cylinder Block and Camshaft
Engine Block Heater
Pistons and Connecting Rod
Engine Block Heater-Hard Cabin
Engine Exhaust and Oxygen Sensors
Air Filter
Engine Air Intake
LPS Disconnect Switch
Engine Cooling System
Engine Cooling System - Coolant Bottle
Drive Tire
Dual Drive Tire
Electrical Parts
Electrical Components - Overhead Guard
Connectors
Electrical Components - Overhead Guard - Hard Cabin
Electrical Components - Hard Cabin
Directional Control
Access 1
Access 1 - Hard Cabin
Diagnostic Port
Parking Brake Switch - Power Brake
Tilt Limit Switch
Tilt Position Assist Switch
Control Cable - TL
Operator Fan
Strobe Light
Strobe Light - Hard Cabin
Overhead Guard - Front Worklights and Mirrors
Hard Cabin - Front Lights, Dome Light, and Mirrors
Overhead Guard - Rear Lights
Hard Cabin - Overhead Guard Rear Lights
Hard Cabin - Back Travel Lights
Turn Signal
Floor Spotlight - TT, TL, and Quad Mast
Brake Parts
Two Pedal Assembly - Power Brake
Three Pedal Assembly - Power Brake
Power Brake
Brake Guard
Steering Parts
Steering Column - Part 1
Steering Column - Part 2
Steer Axle
Steer Tire
Lifting Mechanism Parts
Fork
Fork Carriage - TL
Fork Positioner Forks
Lift Chain - TL
Lift Chain - TT
Load Backrest
Mast - TL
Mast - TT
Quad Fork Carriage
Quad Mast
Fork Carriage - TT
Yoke - Quad
Yoke - Standard and 1 Accessory - TT
Yoke - TT Mast
Mast - Truckers
Fork Carriage – TL, Truckers Masts
Lift Chain - Truckers Mast
Cylinder Parts
Mast Cylinder - TL
Mast Cylinder - TT
Mast Cylinder - Quad
Carriage Cylinder - TT
Tilt Cylinder
Sideshifter Cylinder
Fork Position Cylinder
Steer Cylinder
Attachment Parts
Sideshifter
Integral Sideshifter - 2,495 kg (5,000 lb)
Integral Sideshifter - 4,000–5,500 lb - TT Mast
Integral Sideshifter - 2,722 kg (6,000 lb)
Integral Sideshifter - 6,000 lb - TT Mast
Integral Sideshifter - Class III - 6,500 lb Capacity
Integral Sideshifter - 6,500 lb - TT Mast
Integral Sideshifter - 5,500 lb - TL Mast
Fork Positioner
Integral Sideshifter-Quad Mast
Work Assist Accessories
InfoLink® Accessories
Entry Assist Handles - Soft Cabin
Labels and Decals
