Crown Forklift C-5 1055 Diesel Pneumatic Parts Manual
Brand: Crown
Type of Machine: Forklift
Model: Crown C-5 1055 Diesel Pneumatic Forklift
Number of Pages: 737 Pages
Power Unit Parts
Power Unit
Extended Fenders
Debris Guard
Wheel Chocks
Counterweight
Hard Cabin Components
Hard Cabin Doors
Battery
Seat Bonnet – Hard Cabin
Motor Mounting Brackets
Overhead Guard and Covers
FlexSeat™
Hydraulic Parts
Reservoir, Filter, and Valve
Suction and Return Lines
Main Interlock
Steering Lines
Power Brake Components
Lift Lines – TL, TT, Truckers Mast
Lift Lines – TF Mast
Tilt Lines – All Masts
Power Unit Accessory Lines - TL, TT
Power Unit Accessory Lines - TF
Power Unit Accessory Lines - TL, TT, Truckers Masts
Pump Hose
Lift and Lower Lines - TL Mast
Lift and Lower Lines – TF Mast
Lift and Lower Lines – TT Mast
Lift and Lower Lines – Truckers Mast
Manual Hoist Lowering - TT, TL, Truckers Masts
Manual Hoist Lowering – TF Mast
Lift Lines – Quad Mast
Power Unit Accessory Lines – Quad Mast
Lift and Lower Lines – Quad Mast
Manual Hoist Lowering – Quad Mast
Hydraulic Motor
Control Valve - Three Spool
Control Valve - Four Spool
Four-Position Pressure Relief Valve
Control Valve Linkage - No Accessories
Control Valve Linkage - First Accessory
Control Valve Linkage - Second Accessory
Control Lever
Carriage Hydraulics – TT Mast
Carriage Hydraulics - TL Mast
Carriage Hydraulics – TF Mast
Carriage Hydraulics - Trucker’s Mast
Carriage Hydraulics – Quad Mast
Engine and Transaxle Parts
Transaxle Mounting – Power Brake
Transaxle Axle and Brake Mounting – Power Brake
Transaxle Transmission Housing
Transaxle Primary Shaft - Clutch
Transaxle Secondary Shaft
Transaxle Intermediate Shaft and PTO Output Shaft
Transaxle Converter
Transaxle Control Valve and Inching Lever
Transaxle Axle Housing
Transaxle Bevel Gear Kit and Output Shaft
Transaxle Differential and Half-Shafts
Transmission Cooling System
Transaxle - Sensors
Engine Mounts
Wiring Harness and Sensors
Oil Separator
Oil Pan
Water Pump and Thermostat
Oil Cooler and Filter
Starter Motor
Engine Oil Dipstick
Crankshaft Pulley and Belt
Timing System and Cover
Fuel System
Rear Oil Seal
Auxiliary Drive
Exhaust Manifold
Turbocharger
Flywheel and Housing
Rocker Arm
Rocker Arm Cover
Crankshaft and Bearings
Balance Shaft
Crankcase and Camshaft
Pistons and Connecting Rod
Engine Block Heater
Engine Exhaust
EGR System
Air Filter
Engine Air Intake
DS Disconnect Switch
Engine Cooling System
Engine Cooling System – Expansion Tank
Intake Manifold
Drive Tire
Dual Drive Tire
Electrical Parts
Electrical Components - Overhead Guard
Electrical Components - Overhead Guard - Hard Cabin
Electrical Components - Hard Cabin
Directional Control
D4 Armrest Assemblies and Mounting
Armrest - Upper
Armrest - Lower
Access 1
Access 1 - Hard Cabin
Diagnostic Port
Parking Brake Switch–Power Brake
Tilt Position Assist Switch
Tilt Limit Switch
Control Cable - TL Mast
Control Cable - TT Mast
Control Cable - TF Mast
Control Cable - Truckers Mast
Operator Fan
Strobe Light
Strobe Light - Hard Cabin
Front Worklights and Mirrors
Front Lights, Dome Light, and Mirrors - Hard Cabin
Overhead Guard - Rear Lights
Rear Worklight - Hard Cabin
Turn Signal
Floor Spot Light
Brake Parts
Two Pedal Assembly - Power Brake
Three Pedal Assembly - Power Brake
Power Brake
Brake Guard
Steering Parts
Steering Column - Part 1
Steering Column - Part 2
Steer Axle
Steer Tire
Lifting Mechanism Parts
Mast - Truckers
Mast - TL
Mast - TT
Mast - TF
Mast - Quad
Fork Carriage – TL, Truckers Masts
Fork Carriage – TT Mast
Fork Carriage – TF Mast
Fork Carriage – Quad Mast
Yoke - TT Mast
Yoke - TF Mast
Yoke - Quad
Lift Chain - TL Mast
Lift Chain - TT Mast
Lift Chain - TF Mast
Lift Chain - Truckers Mast
Lift Chain - Quad Mast
Load Backrest
Fork
Fork Positioner Forks
Cylinder Parts
Mast Cylinder - Truckers Mast
Mast Cylinder - TL Mast
Mast Cylinder - TT Mast
Mast Cylinder - TF Mast
Mast Cylinder - Quad Mast
Primary Cylinder – TT Mast
Primary Cylinder – TF Mast
Primary Cylinder - Quad Mast
Tilt Cylinder
Cascade Sideshifters
Rightline Sideshifting Fork Positioner
Rightline™ Fork Positioner Cylinder
Steer Cylinder
Attachment Parts
Cascade Hook-On Sideshifters
Cascade Sideshifting Fork Positioner
Cascade Sideshifting Fork Positioner – High Visibility
Integral Sideshifter
Integral Sideshifter – 6,500 lb Capacity
Rightline® Sideshifting Fork Positioner
Work Assist® Accessories
InfoLink® Accessories
Entry Assist Handle - Soft Cabin
Labels and Decals
Brand: Crown
Power Unit Parts
Power Unit
Extended Fenders
Debris Guard
Wheel Chocks
Counterweight
Hard Cabin Doors
Battery
FlexSeat™
Hydraulic Parts
Main Interlock
Steering Lines
Pump Hose
Hydraulic Motor
Control Lever
Transaxle Converter
Transaxle - Sensors
Engine Mounts
Oil Separator
Oil Pan
Starter Motor
Engine Oil Dipstick
Fuel System
Rear Oil Seal
Auxiliary Drive
Exhaust Manifold
Turbocharger
Rocker Arm
Rocker Arm Cover
Balance Shaft
Engine Block Heater
Engine Exhaust
EGR System
Air Filter
Engine Air Intake
Intake Manifold
Drive Tire
Dual Drive Tire
Electrical Parts
Directional Control
Armrest - Upper
Armrest - Lower
Access 1
Diagnostic Port
Tilt Limit Switch
Operator Fan
Strobe Light
Turn Signal
Floor Spot Light
Brake Parts
Power Brake
Brake Guard
Steering Parts
Steer Axle
Steer Tire
Mast - Truckers
Mast - TL
Mast - TT
Mast - TF
Mast - Quad
Yoke - TT Mast
Yoke - TF Mast
Yoke - Quad
Load Backrest
Fork
Cylinder Parts
Tilt Cylinder
Steer Cylinder
Attachment Parts
Labels and Decals
- Crown Rider Pallet Jack PE 4500 AC Service & Parts Manual_PF15302-006
- Crown Forklift SX3000 Series Parts Manual 812710-006
- Crown Forklift WAVE Service Manual
- Crown Forklift GPC2000 Series Maintenance Manual 812520-006-0M
- Crown Forklift WP3200S Series Maintenance Manual 812529-006
- Crown Reach Truck RR RD5700 AC Service & Parts Manual
- Crown Forklift WP2000 Series Service Manual
- Crown Forklift WP2300 Series Parts Manual 812684-006-0M
- Crown Forklift SC3200 Series Maintenance Manual 812548-006
- Crown Forklift WP2300 Series Maintenance Manual 812528-006-0M
- Crown Forklift WP2000S Series Service Manual
- Crown Reach Truck RR 5200 DC Service & Parts Manual_PF13364-006
- Crown Forklift WE WS 2000 Series Service Manual
- Crown Forklift GPW1000 Series Service and Parts Manual MP-GPW1000
