Crown Counterbalance Forklift RC 3000 Parts, Service Manual
Type of Manual: Parts Catalog, Service Manual
Type of Machine: Forklift Truck
Model: Crown RC 3000 Counterbalance Forklift
RC 3000 Service Manual (35 files)
- CRO_ITD-1030-004
- DIA-1030-001
- DIA-1030-030
- HYD-1030-001
- ITD-1030-001
- M1.0-04.0-001
- M1.0-1030-001
- M1.9-14.0-001
- M10-1030-001
- M10-1030-020
- M2.0-1030-001
- M2.0-1030-020
- M2.0-1030-050
- M4.0-1030-001
- M4.0-1030-020
- M4.0-1030-040
- M4.1-1430-001
- M4.2-14.0-400
- M4.3-1030-001
- M4.3-1030-050
- M4.4-1030-001
- M4.4-6535-001
- M4.4-7330-025
- M4.4-7330-075
- M4.4-7334-025
- M4.5-1030-001
- M4.6-1030-001
- M4.7-1030-001
- M6.0-10.0-002
- M7.0-1030-001
- M8.6-1030-001
- MA-04.0-001-037
- MA-1030-100
- MA-1030-101
- MA-1140-050-037
RC 3000 Parts Catalog (545 Pages)
- Power Unit View
- Power Unit EE
- OHG
- Battery
- Hyds View 1
- Hyds View 2
- Hyds Mast TT
- Mast Hyds - Quad Mast
- Hyd Mast Accessories
- 02.04-1030-852
- 02.04-1030-853
- Pump, Lift - (30, 35, 40 RC)
- Motor, Pump 36V (30, 35, 40 RC)
- Valve
- Valve (1 Spool)(25, 30, 35, 40, 1.0, 1.25 1.6 RC)
- Valve (1 Spool)(30, 35, 40 RC)
- Valve (2 Spool)(25, 30, 35, 1.0, 1.25 1.6 RC)
- Valve - (1 Spool)(30, 35, 40 RC)
- Valve - (1 Spool)(20, 25, 30, 35, 40, 1.0, 1.25 1.6 RC)
- Valve, Spool - (30, 35, 40 RC)
- Counterbalance Valve - (30, 35, 40 RC)
- Manifold High Pressure Thru Multi-Function
- Manifold Accy
- Manifold Retractable OHG
- 02.4-1140-050
- Control Lever(s)
- Hose Reel 1 Accy (2)(30, 35, 40 RC)
- Hose Reel 2 Accys (4)(30, 35, 40 RC)
- Hyds Accy (TF)
- Hyds Accy (TL)
- Hyds Accys (TT)
- Hyds Accy (TT)
- Hyds - Accy - TT
- Hyds Accy - 1 Low Pressure
- Hyds - Accy - 1 Low Pressure
- Hyds Accy 1 Low and 1 High Pressure
- Hyds - Accy - 1 Low and 1 High Pressure
- Hyds Accy - 2 High Pressure
- Hyds - Accy - 2 High Pressure
- Hyds Accy High w/Remote Tilt Thru Lever
- Hyds Accy - 1 High Pressure thru Multi Task,1 Low Pressure with remote lever
- Hyds - Accy - 1 High Pressure thru Multi Task, 1 Low Pressure with remote lever
- Hyds Accy - 1 High Pressure thru Multi-Task, 1 High Pressure with remote lever
- Hyds - Accy - 1 High Pressure thru Multi Task, 1 High Pressure with remote lever
- Hyds Accy High Thru Multi-Function
- Hyds Accy Retractable OHG
- Hyds - Accy - Retractable OHG
- Hyds Accy Retractable OHG, High Pressure thru Multi-Task
- Hyds Accy Retractable OHG, High Pressure thru Multi Task
- Carriage Hyds
- Carriage Hyds - Quad Mast
- Drive Unit(30, 35, 40 RC)
- Motor, Traction - (30, 35, 40 RC)
- Tire, Traction(30, 35, 40 RC)
- Tire, Drive
- Electrical Component Location
- Electrical Components
- Contactor Panel
- Contactor Panel 36V EE
- SCR Panel - (30, 35, 40 RC)
- Fuse Box EE
- Contactor 117853-001
- Contactor 120975
- Contactor
- Contactor 110613-005
- Contactor - 1A, RB and P - EE
- Contactor - S - EE
- Contactor 116794-005
- Contactor 123470-001
- Contactor EE Function table
- Contactor 118282-005
- Multi-Function Control
- Controls Lockout on Std. Trucks
- Limit Switches Mast
- Entry Bar
- Controls Lockout on Retractable OHG Trucks
- Controls Lockout on Trucks with 5 or 10 deg. Extended Tilt
- Controls Lockout on Trucks with High Pressure Accy
- Freezer/Corrosion Components(30, 35, 40 RC)
- Battery Interrupt(30, 35, 40 RC)
- Freezer/Corrosion Components(25, 30, 35, 40, 1.0, 1.25 1.6 RC)
- Strobe Light
- OHG Accys
- Quad Mast Mounted Lights
- Brake System (30, 35, 40 RC)
- Brake (30, 35, 40 RC)
- Steering Assy
- Pump, Power Steering - (30, 35, 40 RC)
- Motor, Power Steering - (30, 35, 40 RC)
- Steer Wheel Assembly(30, 35, 40 RC)
- Steer Wheel(25, 30, 35, 40, 1.0, 1.25 1.6 RC)
- Steer Wheel Lubrication
- Mast (TL-TF)
- Mast (TT)
- Mast
- Fork Carriage
- Lifting Mechanism Parts Yoke Quad Mast
- Lift Chain - Quad Mast
- Load Backrest(30, 35, 40 RC)
- Load Backrest
- Fork(30, 35, 40 RC)
- Chart - Model, Fork Designation
- Chart - Fork Length
- Cyl Lift TL(30, 35, 40 RC)
- Cylinder Lift
- Chart 1 - TL Cylinder - Index 0, 6, 10
- Chart 2 - Roller Bar Assembly - Index 31
- Chart 3 - Chain Anchor - Index 40
- Chart 4 - Chain - Index 37
- Cyl, Lift (TF) - (30, 35, 40 RC)
- Cyl, Mast (TT)(30, 35, 40 RC)
- Cyl, Carriage (TT) - (30, 35, 40 RC)
- Quad Mast Lift Cylinder Chart
- Quad Carriage Cylinder
- Chart
- Index 0,8,9 - Cylinder-Ram
- Tilt Cylinder
- Cylinder Assembly Chart - RC3000 - 1805mm (71.0in) to 2250mm (88.5in) Mast
- Cylinder Assembly Chart - RC3000 - 2260mm (89.0in) to 2540mm (100.0in) Mast
- Cylinder Assembly Chart - SC
- Index 1, 2, 13 Chart
- Cyl, Sideshift (30, 35, 40 RC)
- Cyl, OHG - (25, 30, 35, 40, 1.0, 1.25 1.6 RC)
- Side Shift (30, 35, 40 RC)
- Sideshift Assembly (Cascade)
- Sideshift
- Retractable OHG
- Labels and Decals
