Clark-Hurth Powershift Transmission 5000 Series Repair and Maintenance Manual RU
Language: Russian
Brand: Clark-Hurth
Type of Machine: Powershift Transmission
Type of Manual: Maintenance Manual, Repair Manual
Model: Clark-Hurth 5000 Series Powershift Transmission 4 Speed
Number of Pages: 60 Pages
Assembly Instructions
Gearbox Operation
Shafts And Clutch Identification
Diagrams And Parts Identification
Front And Rear Views, Shaft Identification
Gearbox Housing And Internal Lines
Control Valve Block
Gearbox Clutches And Gears
Input Shaft, Reverse, 3rd And 4th Gear Clutches
1st And 2nd Gear Clutches
Torque Converter And Gearbox External Hydraulic Line Diagram
Gearbox Disassembly
Gearbox Assembly
Maintenance Machines
After Gearbox Overhaul
Technical Specifications And Reference Data
Lubrication
Troubleshooting
Oil Pressure And Flow Rate Specifications
Threaded Connection Tightening Torques
Procedure For Checking Oil Pressure And Flow Rate
Installing Tapered Bearings Of Couplings
Coupling For Pressure Modulation Circuit
Pressure Modulation Valve
Language: Russian
Brand: Clark-Hurth
Gearbox Operation
Control Valve Block
Gearbox Disassembly
Gearbox Assembly
Lubrication
Troubleshooting
- Atlas Copco Workshop Manuals Pack
- Atlas Copco ROC L6(25) / L6(30) / L8(25) / L8(30) operation manual
- Atlas Copco XA 60, 80, 120, 160 DD y XAS
- Atlas Copco Instruction Manual for Portable Compressors XRHS 486 Md XRHS 396 Md XRVS 466 Md XRV
- Atlas Excavator 1304 Hydraulic and Wiring Diagram
- Atlas Copco Instruction book for compressors GA11 - GA15 - GA18 - GA22
- Atlas Copco Instruction Manual and Parts List for Portable Compressors XRVS455 Md
- Atlat Copco XAHS 146 Dd - XATS 156 Dd - XA(S) 186 Dd - XAVS 166 Dd - XAHS 186 Dd Operation Manual
- Atlas Copco DM45 Parts Catalog
- Atlas Copco ROC D7-11 Technical Training Circuit Diagram Parts Manual
- Atlas Copco Stationary Air Compressors ZR, ZT 55 Parts Manual
- Atlas Copco Scooptram ST1030 Diagrams & Drawings
- Atlas Copco ROCKET BOOMER S1D Spare Parts Catalogue
- Atlas Copco Instruction Manual XAMS 407 CD XAMS 850 CD7; XATS 377 Cd
- Atlas Copco Scooptram ST1030 Service manual
