James Rodrigues
Super Moderator
140
1,164,656
CLAAS WebTIC Offline ZH_China 07.2022 Operator Manual Repair Manual & Service Documentation DVD
[WebTIC_ZH] CLAAS WebTIC Offline ZH_China 07.2022 Operator Manual Repair Manual & Service Documentation DVD
Size: 44.1 GB (Winrar Filles)
Document Language: Only ZH
Type of software: CLAAS WEBTIC Repair Manual, Assembly Instruction, Time Schedule, Miscellaneous, Technical System, Training Document, Operator Manual.
Make: Claas Agricultural
Region: WorldWide
Amount of DVD: 1 DVD ZH_China
Version: WebTIC Offline 4.0.5
Database updated: July 2022
Date: 07.2022
OS: Windows 7, Windows 8, Windows 10 32 & 64 bit(Tested on window 10 pro 1607 64bit & Window 7 ultimate 64bit)
Print Functions: Present
Instruction: Present
Installation: Multiple PCs
High-Speed Link Download
Fitting instructions
Operators manual
Repair manual
Time schedule
Miscellaneous
Technical system
Training document
Conversion instructions
Assembly instructions
Combines
Forage Harvester
Tractors
Balers
Mowers
Tedders
Swathers
Loader Wagons
Telehandlers
Wheel Loaders
EASY
Miscellaneous
Master
Administrator
703
7,939,979
#3
Region: WorldWide
Date: 07.2022
Master
Administrator
703
7,939,979
#5
Region: WorldWide
Date: 07.2022
