Martin Welker
104
230,310
Claas Forage Harvesters Jaguar 980-930 (494) Technical Repair Operators Manual
Brand: Claas
Type of Machine: Forage Harvesters
Type of Manual: Technical System, Repair Manual, Operators Manual, Electrical Schematic, Hydraulic Schematic
Model: Claas Jaguar 980-930 494 Harvesters Forage
List of Files:
Claas JAGUAR 980 - 930 00 0294 867 6 6.14.2013 Operator's Manual
Claas Metal detector measuring unit MG 4-1 . Metal detector measuring unit MG 4 00 2308 678 3 9.4.2017 Operator's Manual
Claas JAGUAR 980 - 930 Knife bolts and upper discharge chute extension 00 0292 800 0 6.19.2012 Supplement of Operator's Manual
Claas Dieselgines IIIB 00 0301 730 0 9.29.2015 Supplement to Operator's Manual
Claas JAGUAR 980 - 930 Chopper unit . Corn cracker 00 0292 782 0 3.13.2012 Supplement to Operator's Manual
Claas JAGUAR Troubleshooting and cleaning of discharge afront attachments 00 0295 776 1 5.12.2009 Fitting and Operating Instructions
Claas JAGUAR 980-950, JAGUAR 900-830 TELE CAM 00 0295 ccelerator 00 0292 502 0 3.16.2012 Supplement to Operator's Manual
Claas JAGUAR 960-930, JAGUAR 900-830 Adapter for LEXION 906 0 5.12.2009 Fitting and Operating Instructions
Claas JAGUAR 990 . 980 . 970 . 960 . 950 . 940 . 930 . JAGUAR 880 . 870 . 860 . 850 . 840 . 830 . JAGUAR 990 . 960 TERRA TRAC Adapter for CORIO . CONSPEED 00 0302 339 3 12.1.2021 Operator's Manual
Claas JAGUAR 980 - 930 00 0295 528 4 3.13.2014 Concise operating instructions
Claas TELEMATICS Website 00 0018 552 1 5.13.2016 Concise Operator's Manual
Claas GPS PILOT S10 Terminal - SW 3.30.9 00 1405 164 7 10.17.2018 Operator's Manual
Claas GPS PILOT S10 Terminal - SW 4.00.20 00 1420 028 4 11.29.2019 Operator's Manual
Claas GPS PILOT S7 Terminal - SW 1.30.8 00 1405 184 7 1.15.2019 Operator's Manual
Claas GPS PILOT S7 Terminal - SW 2.10.10 00 1420 056 2 11.14.2019 Operator's Manual
Claas PROFI CAM 3 00 0301 051 0 6.1.2015 Operator's Manual
Claas PROFI CAM 4 00 0303 482 0 1.14.2020 Operator's Manual
Claas JAGUAR 980-930 00 0294 910 6 1.10.2017 Repair Manual
Claas JAGUAR 980 - 930 Cutting cylinder housing 00 2308 659 0 9.5.2017 Repair manual
Claas JAGUAR Type 502, 500, 499, 498, 497, 496, 494 00 0305 431 0 9.29.2021 Supplement to Repair Manual . Vibrations check list
Claas GRAMMER Seat Spring System DS85, DS85H and MSG85 00 0107 838 3 12.7.2011 Repair manual
Claas GRAMMER seat suspension MSG95AL 1 183 409_e 7.7.2017 Repair manual
Claas GRAMMER seat suspension MSG95EL 00 0114 220 2 12.7.2011 Repair manual
Claas GRAMMER seat suspension MSG 97AL 1 160 241_e 7.7.2017 Repair manual
Claas GRAMMER upper seat part S721 - S742 00 1106 921 9 7.5.2012 Repair manual
Claas MAN D2868 . MAN D2862 00 0296 316 1 9.1.2014 Repair manual
Claas Mercedes-Benz OM460LA 00 0296 365 1 12.18.2020 Repair manual
Claas Mercedes-Benz OM502LA 00 0296 338 1 12.18.2020 Repair manual
Claas JAGUAR 00 0288 602 2 7.5.2019 Shear bar measuring instructions
Claas T4igines 3.29.2015 Test instructions for output assessment
Claas JAGUAR 3.28.2015 Test protocol
Claas OM 502 LA . OM 460 LA 12.11.2013 Inspection protocol
Claas JAGUAR 990-830 . Chopping A084 Shear bar adjustment generation II module 00 0303 966 1 3.19.2021 Supplement to Repair Manual
Claas JAGUAR 990-830 . Cooling system Rotary screen: Riveted perforated plate 00 0305 072 0 2.4.2021 Supplement to Repair Manual
Claas JAGUAR 980 - 930 from serial no. 49402914 00 0292 417 2 1.23.2014 Technical Systems . .
Claas JAGUAR 980 - 930 00 0295 733 5 1.26.2011 Technical Systems
Claas JAGUAR Type 502, 500, 499, 498, 497, 496, 494 00 0303 624 1 3.10.2021 Technical Systems - Supplement . Metal detector check list .
Claas JAGUAR 980-930 . Type 494 . JAGUAR 880 - 830 . Type 496 . JAGUAR 980-930 . Type 497 . JAGUAR 980-930 . Type 498 00 0303 170 0 7.9.2019 Technical Systems - Supplement . . AUTO FILL Function test
Claas MAN D2868 . MAN D2862 00 0296 326 2 12.15.2020 Technical systems
Claas MB OM460LA . MB OM502LA . MB OM906LA . MB OM926LA 00 0291 027 2 8.22.2014 Technical Systems
Claas PROFI CAM 3 00 0302 343 1 8.14.2020 Technical Systems - Supplement
Claas LEXION . JAGUAR . XERION Dieselgine starting problems . Mercedes-Benz: OM47xLA . OM502 . OM460 . MAN: D2862 . D4276 . D2676 . Perkins 2206 . Caterpillar C13 00 0305 863 0 5.9.2022 Supplement to Technical Systems documentation
Claas CLAAS HARNESS PARTS 10.29.2021 CHP-numbers for connectors
Claas Sensor system 00 0302 565 2 12.1.2020 Testing . Measuring . Adjusting
Claas AVERO.LEXION.TUCANO . JAGUAR . XERION . X10 Broadcast receiver 00 0303 217 0 8.12.2019 Assembly instructions
Claas JAGUAR . LEXION.TUCANO . XERION . X10 Cooling unit for thermobox M.L 00 0303 211 1 10.8.2021 Assembly instructions
Claas JAGUAR . LEXION . TUCANO . XERION CEBIS MOBILE 00 0292 018 3 6.1.2018 Assembly instructions
Claas JAGUAR 498-496 . JAGUAR 494 Convert radiator screen to 2.0 00 0305 602 1 7.21.2022 Assembly instructions
Claas JAGUAR 880 - 830 . JAGUAR 990 - 930 . JAGUAR 990 + 960 TERRA TRAC Roller blinds for feeder unit 00 0300 357 2 4.24.2020 Assembly instructions
Claas JAGUAR 980 . JAGUAR 970 Silencer 00 0301 757 1 1.21.2016 Assembly instructions
Claas JAGUAR 980-920 . TUCANO 580-320 Electric rear view mirrors 00 0288 115 1 8.16.2017 Assembly instructions
Claas JAGUAR 980-930 Segment drum setting gauges 00 1410 413 3 2.19.2020 Assembly Instructions
Claas JAGUAR 980 - 930 Stone detector 00 0290 049 2 5.25.2018 Assembly instructions
Claas JAGUAR 990-830 Broadcast receiver 00 0303 947 0 11.10.2020 Assembly instructions
Claas JAGUAR 990-830 Centre axle bolt 00 0288 877 2 2.26.2020 Assembly instructions
Claas JAGUAR 990-830 Centre axle bolt 00 0303 548 0 2.26.2020 Assembly instructions
Claas JAGUAR 990-830 Corncracker: electric gap adjustment 00 0290 081 1 9.8.2020 Assembly instructions
Claas JAGUAR 990-830 Outline lighting 00 0300 585 2 10.30.2020 Assembly instructions
Claas JAGUAR 990-930 . JAGUAR 980-930 . JAGUAR 880-830 Dual lubrication 00 2968 807 0 12.15.2021 Assembly instructions
Claas JAGUAR 990-930 Cutting cylinder segments 00 2936 532 0 12.16.2021 Assembly instructions
Claas JAGUAR 990-930 Front attachment drive fast 00 2777 524 0 6.22.2020 Assembly instructions
Claas Mercedes-Benz OM 47x LA . Mercedes-Benz OM 93x LA . MAN D2676 LE1xx . MAN D2862 LE1xx . MAN D4276 LE12x Repair kit for urea pump and dosing unit 00 0303 023 1 10.5.2021 Assembly instructions
Claas JAGUAR 980 - 930 Low pressure connection damper 00 1324 117 1 1.31.2011 Conversion instructions
Claas JAGUAR 980 . 960 . 950 . 940 . 930 Welding Instructions Compression Roller 906 211.2 00 1324 259 0 4.11.2011 Fitting Instructions
Claas JAGUAR 980-830 Nozzlesiling agent injection 00 0300 106 0 5.20.2014 Fitting Instructions
Claas JAGUAR 980 - 830 Sharpening stone setting gauge 00 1390 583 0 5.3.2013 Fitting Instructions
Claas JAGUAR 980 - 930, JAGUAR 900 - 830 Infeed auger housing wear plate 00 1324 110 0 10.9.2010 Fitting Instructions
Claas JAGUAR 980 - 930, JAGUAR 900 - 830 Plain roller scraper 00 1390 982 0 7.25.2013 Fitting Instructions
Claas JAGUAR 980 - 930, JAGUAR 900 - 830 Wear plate 00 0290 408 0 12.14.2009 Fitting Instructions
Claas JAGUAR 980 - 930 . JAGUAR 900 - 830 . JAGUAR 810 Wear plates PREMIUM LINE 00 0292 480 0 2.23.2012 Fitting instructions
Claas JAGUAR 980 - 930 . JAGUAR 900 - 830 Adjustable upper discharge chute flap 00 0292 655 0 3.16.2012 Fitting instructions
Claas JAGUAR 980-930 Typ497 . JAGUAR 980-920 Typ494 . JAGUAR 900-830 Typ493 shear bar 00 0495 277 3 4.5.2018 Fitting Instructions
Claas JAGUAR 980 - 930 Additional horn for field operation 00 0300 091 1 2.12.2015 Fitting instructions
Claas JAGUAR 980-930 Adhesive film - stripper 00 1390 152 1 3.13.2017 Fitting Instructions
Claas JAGUAR 980-930 Adjusting tool 00 2622 171 0 3.28.2017 Fitting Instructions
Claas JAGUAR 980 - 930 AUTO FILL 00 0291 241 0 4.20.2010 Fitting Instructions
Claas JAGUAR 980 - 930 AUTO FILL 00 0292 489 1 8.15.2014 Fitting Instructions
Claas JAGUAR 980 - 930 CAM PILOT 00 0295 903 1 10.19.2011 Fitting Instructions
Claas JAGUAR 980 - 930 CEBIS Printer 00 0290 406 0 12.7.2009 Fitting Instructions
Claas JAGUAR 980 - 930 central lubrication system 00 0291 235 0 4.30.2010 Fitting Instructions
Claas JAGUAR 980 - 930 Chopper knives - deflector 00 1318 726 3 5.31.2014 Fitting Instructions
Claas JAGUAR 980 - 930 Cover apron Feeder unit 00 0292 635 0 3.14.2012 Fitting instructions
Claas JAGUAR 980-930 Cutting cylinder housing wear plate 00 1324 045 1 11.10.2016 Fitting Instructions
Claas JAGUAR 980-930 Deflector - Chopping knives 00 1318 726 4 7.27.2018 Fitting Instructions
Claas JAGUAR 980 - 930 Discharge accelerator electric gap adjustment 00 0292 442 0 11.29.2011 Fitting instructions
Claas JAGUAR 980 - 930 DISCHARGE CHUTE PILOT 00 0290 062 1 12.14.2009 Fitting Instructions
Claas JAGUAR 980 - 930 Driven Steering Axle 00 0291 116 1 9.21.2010 Fitting Instructions
Claas JAGUAR 980 - 930 Dry mass sensor 00 0292 656 0 3.21.2012 Fitting Instructions
Claas JAGUAR 980 - 930 Dry mass sensor 00 0295 907 1 9.30.2009 Fitting Instructions
Claas JAGUAR 980 - 930 Dump Wagon Hydraulics 00 0291 956 0 5.9.2011 Fitting Instructions
Claas JAGUAR 980 - 930siling agent applicator system 00 0292 788 0 7.12.2012 Fitting instructions
Claas JAGUAR 980-930 Formed elements 00 1390 945 2 1.17.2020 Fitting Instructions
Claas JAGUAR 980 - 930 Formed elements 00 1390 945 0 5.28.2013 Fitting Instructions
Claas JAGUAR 980 - 930 GPS PILOT 00 1401 749 0 10.24.2012 Fitting Instructions
Claas JAGUAR 980 - 930 GPS PILOT 00 1402 820 1 9.3.2012 Fitting Instructions
Claas JAGUAR 980 - 930 GPS PILOT 00 1405 272 2 8.26.2016 Fitting Instructions
Claas JAGUAR 980 - 930 GPS PILOT FLEX 00 1405 257 0 2.5.2013 Fitting Instructions
Claas JAGUAR 980 - 930 GPS PILOT FLEX 00 1405 279 2 8.31.2016 Fitting Instructions
Claas JAGUAR 980 - 930 Hydraulic connection 00 0490 904 0 8.20.2012 Fitting Instructions
Claas JAGUAR 980 - 930 Knife Support 00 0291 309 0 6.2.2010 Fitting Instructions
Claas JAGUAR 980 - 930 Maintenance lighting 00 0292 794 0 6.12.2012 Fitting instructions
Claas JAGUAR 980 - 930 Maintenance space - Discharge pipe 00 0292 640 0 3.16.2012 Fitting instructions
Claas JAGUAR 980 - 930 Molasses pump 00 0290 459 0 12.14.2009 Fitting Instructions
Claas JAGUAR 980 - 930 NIR sensor for dry mass 00 0300 544 0 11.4.2014 Fitting instructions
Claas JAGUAR 980 - 930 OPTI FILL 00 0292 017 0 8.9.2011 Fitting Instructions
Claas JAGUAR 980-930 pivot bearing 00 2625 742 0 6.21.2017 Fitting Instructions
Claas JAGUAR 980-930 Plain roller scraper 00 1390 982 2 5.5.2021 Fitting Instructions
Claas JAGUAR 980 - 930 PROFI CAM 00 0297 919 0 11.29.2013 Fitting instructions
Claas JAGUAR 980 - 930 Pulling cylinders 00 0292 904 0 4.23.2014 Fitting instructions
Claas JAGUAR 980 - 930 Radiator screen brush 00 0292 512 0 2.28.2012 Fitting Instructions
Claas JAGUAR 980 - 930 Rear view camera 00 0297 990 0 11.29.2013 Fitting instructions
Claas JAGUAR 980 - 930 Repair Kit for the Shear Bar Adjustment Available 00 1410 990 0 4.25.2017 Fitting instructions
Claas JAGUAR 980-930 Sealing kit 00 2613 608 0 Size 11 MB 10.25.2016 Fitting Instructions
Claas JAGUAR 980 - 930 Second rotary chaff screen suction unit 00 0292 511 0 2.22.2012 Fitting instructions
Claas JAGUAR 980 - 930 Swivelling lights H9 00 0292 490 0 3.6.2012 Fitting instructions
Claas JAGUAR 980-930 TELEMATICS . Communication Module 00 0290 445 3 12.4.2014 Fitting Instructions
Claas JAGUAR 980 - 930 Trailer air brake 00 0290 443 1 12.6.2013 Fitting instructions
Claas JAGUAR 980 - 930 Typ 497 . 494 Replace the chopper knives 00 1410 174 3 4.28.2016 Fitting Instructions
Claas JAGUAR 980 - 930 upper discharge chute HD 00 0290 821 0 2.1.2010 Fitting Instructions
Claas JAGUAR 980 - 930 Windscreen washer sideways 00 0290 487 0 12.14.2009 Fitting Instructions
Claas JAGUAR 980 - 930 Windscreen washer sideways and rear 00 0290 488 0 12.7.2009 Fitting Instructions
Claas JAGUAR 980 - 950, TUCANO 450 - 430, TUCANO 340 - 320 Electric exterior mirrors 00 0290 059 1 5.10.2010 Fitting Instructions
Claas JAGUAR 980 - 950, Typ 494 Tension spring 00 1318 814 1 5.20.2013 Fitting Instructions
Claas JAGUAR 980-950 . TUCANO Telematics 00 0295 490 0 5.12.2009 Fitting Instructions
Claas JAGUAR 980 - 950 AUTOPILOT 00 0290 065 0 12.14.2009 Fitting Instructions
Claas JAGUAR 980 - 950 CLAAS Actisiler 20 00 0290 026 0 12.7.2009 Fitting Instructions
Claas JAGUAR 980 - 950 Coolant chamber 00 0290 060 0 12.14.2009 Fitting Instructions
Claas JAGUAR 980 - 950 Corn Cracker Gap Adjustment 00 0290 081 0 12.14.2009 Fitting Instructions
Claas JAGUAR 980 - 950 Discharge accelerator electrical gap adjustment 00 0290 029 0 9.24.2012 Fitting Instructions
Claas JAGUAR 980 - 950siling Agent Applicator System 00 0295 905 0 5.12.2009 Fitting Instructions
Claas JAGUAR 980 - 950 Fuel filter large water separator 00 0290 066 0 12.14.2009 Fitting Instructions
Claas JAGUAR 980 - 950 Quantimeter 00 0295 927 0 12.14.2009 Fitting Instructions
Claas JAGUAR 980 - 950 trailer hitch preparation 00 0290 061 0 12.14.2009 Fitting Instructions
Claas JAGUAR 980 - 950 Tyre pressure control system 00 0295 496 1 12.14.2009 Fitting Instructions
Claas JAGUAR 980 - 950 Upper discharge chute extension front attachment 10-row 00 0290 056 0 12.14.2009 Fitting Instructions
Claas JAGUAR 980 - 950 Upper discharge chute extension front attachment 8-row 00 0290 053 0 12.14.2009 Fitting Instructions
Claas JAGUAR 980 - 950 work lights H9 00 0290 057 0 12.14.2009 Fitting Instructions
Claas JAGUAR 980 - 950 work lights xenon and Sidefinder 00 0290 064 0 12.14.2009 Fitting Instructions
Claas JAGUAR 980-970 Alternator MAN D2868 - D2862 00 0300 562 1 9.6.2014 Fitting instructions
Claas JAGUAR 990-810 Rotating beacon 00 0300 344 2 11.2.2020 Fitting instructions
Claas JAGUAR 990-830 Roller blinds for side windows and rear window 00 0300 348 1 11.2.2020 Fitting instructions
Claas ORBIS 900 99201001 – 99201175, ORBIS 750 65901001 – 65901950, ORBIS 600 65801001 – 65803227, ORBIS 450 65701001 – 65701135 - JAGUAR 494 AUTO PILOT 00 0296 707 0 4.8.2013 Fitting Instructions
Claas Sharpening device setting gauge Spare parts list 00 2621 416 0 3.15.2017 Fitting instructions
Claas LEXION 780-510, TUCANO 480-320, . JAGUAR 980-830 . Amazone Pantera, Agrifac Condor, . Vervaet Hydro Trike GPS PILOT FLEX 00 1405 400 2 7.22.2014 Supplement to fitting instructions
Claas JAGUAR 980 - 930 Repair Kit for the Shear Bar Adjustment 00 1410 990 1 1.4.2019 Assembly instructions
Claas JAGUAR 980 - 930, Typ 494 Housing replacement-reinforcement 00 1318 881 0 7.12.2010 Conversion instructions
Claas JAGUAR 980 - 930, Typ 494 Reinforcement 00 1318 848 0 6.18.2010 Conversion instructions
Claas JAGUAR 980 - 930, Typ 494 Wiper + cam adjustment 00 1318 863 0 7.23.2010 Conversion instructions
Claas JAGUAR 980 - 930 Chopper Unit 00 1410 926 0 6.24.2014 Conversion instructions
Claas JAGUAR 980 - 930 Feeder housing spring assembly 00 1324 662 1 3.9.2012 Conversion instructions
Claas JAGUAR 980 - 930 Feeder unit wear plates 00 1390 525 0 6.3.2013 Conversion instructions
Claas JAGUAR 980 - 930 Housing replacement 00 1318 879 0 6.18.2010 Conversion instructions
Claas JAGUAR 980 - 930 Seal kit 00 1390 173 0 7.5.2012 Conversion instructions
Claas JAGUAR 980 - 930 Weld on wear bar 00 1324 988 1 5.28.2013 Conversion instructions
Claas JAGUAR 980 - 950, Typ 494 Damper - Reinforcement 00 1318 818 1 4.30.2010 Conversion instructions
Claas JAGUAR 980 - 950, Typ 494 GGS - lever 00 1318 840 0 5.17.2010 Conversion instructions
Claas JAGUAR 980-930 Typ497 . JAGUAR 980-920 Typ494 ET-Kit flange bearing 00 2606 813 3 5.20.2022 Fitting Instructions
Claas CLAAS Legend of symbols in fitting instructions 00 0290 143 2 3.17.2011 Catalogue
Claas CLAAS Filling unit 00 0292 437 0 10.14.2011 Fitting instructions
Claas JAGUAR . LEXION . TUCANO . AVERO . DOMINATOR Turning Tool 00 0295 105 1 4.25.2013 Fitting Instructions
Claas LEXION . TUCANO . JAGUAR oil level dipstick 00 0292 013 6 6.11.2019 Fitting Instructions
Claas General information about fitting, adjustments and operation 00 0300 374 1 1.1.2021 Information sheet
Claas RTK . Machine 00 0018 581 0 4.12.2016 Conversion instructions
