702,800
Chevrolet Captiva and Holden Captiva 2009-2012 Service and Repair Manual
Brand: Chevrolet
Type of Machine: Automotive
Type of Manual: Service and Repair Manual, Electrical Diagrams
Model: Chevrolet Captiva, Holden Captiva Automotive
Date Model: 2009-2012
Number of Pages: 4651 Pages
1st and Reverse Brake (B3) and One Way Clutch No.2 (F2) Illustration
2 nd Coast Brake (B1) and 2 nd Brake (B2) Inspection
2nd Coast Brake (B1) and 2nd Brake (B2) Assembly
2nd Coast Brake (B1) Hub, 2nd Brake (B2) Hub and One Way Clutch No.1 (F1) Assembly
2nd Coast Brake (B1) Hub, 2nd Brake (B2) Hub and One Way Clutch No.1 (F1) Disassembly
2nd Coast Brake (B1), 2nd Brake (B2) Hub, One Way Clutch No.1 (F1) Illustration
3rd Row Rear Seat Replace (Captiva)
A - Diagnostic System Check
ABS Basic Knowledge Required
ABS System Components
AC Compressor Relay Replace
AC Expansion Valve Replace
AC High-pressure Pipe Line Replace
AC Module Replace
AC Pressure Transducer Replace
AC Suction Hose Assembly Replace
AC System Charging Capacity
Accelerator Pedal Module (APM) Replace
Accessory Belt and Tensioner Replace
Accessory Drive Belt Idler Pulley Replace
Accessory Drive Belt Replace
Accessory Drive Belt Replace1
Accessory Drive Belt Tensioner Assembly Replace
Accessory socket
Adding Keys
Additional work for replace rear bumper cladding in vehicles with towbar
Add-on heater, electrically operated, passenger compartment
Add-ons for Replace Side Panel
Add-ons for Replacing Front
Adjustment data for Antara Z 20 DM (2.0 CDTI ECOTEC) 93 kW
Adjustment data for Antara Z 20 DMH (2.0 CDTI ECOTEC) 110 kW
Adjustment data for Antara Z 24 XE (2.4 ECOTEC) 103 kW
Adjustment data for Antara Z 32 SE (3.2 V6 ECOTEC) 167 kW
Air Charging System Illustration
Air Cleaner Assembly Replace
Air Cleaner Assembly Replace1
Air Cleaner Element Replace
Air Cleaner Element Replace1
Air conditioning
Air Filter Element Replace
Air Filter Replace
Air Inlet Grille Panel Replace
Air Inlet Grille Panel Sealing Strip Replace
Air Intake Hose for Auxiliary Heating, Remove and Install - Webasto
Air Intake System Illustration
Air Intake System Illustration1
Airbag (SDM C10X)
Airbag (SDM C10X)1
AISIN 55-51LE Automatic Transmission
All Wheel Drive Systems
Alternator Repair
Alternator Replace
Alternator Specifications
Ambient Air Temperature Sensor Replace
Antara - Overview
Antenna
Anti-Lock Brake System (ABS Teeves)
Anti-Lock Brake System (ABS Teeves)1
Anti-lock Brake System (ABS)
Anti-lock Brake System (ABS)1
Anti-Theft Systems
Anti-theft warning system
Anti-theft warning system1
A-pillar, Replace
A-pillar, Replace1
Audio Remote Controller Replace (Antara)
Audio Remote Controller Replace (Captiva)
Audio Systems Replace (Antara)
Audio Systems Replace (Captiva)
Audio Systems
Automatic Temperature Control Assembly Replace (Antara)
Automatic Temperature Control Assembly Replace (Captiva)
Automatic Transmission Assembly Remove and Install 1
Automatic Transmission Components Illustration
Automatic Transmission Hydraulic Test
Automatic Transmission Identification Number Plate Location
B-001 - Diagnostic System Check
B-002 - System Selection
B-003 - Code Index for AHL
B-004 - Code Index for DIS
B-005 - Code Index for Radio
B5 Brake & Rear Case Assembly
B5 Brake Disassembly
B5 Brake, Forward Clutch (C1), Direct Clutch (C2), Underdrive Clutch (C3) Inspection
B-006 - Audio Index for EHU
B-007 - Temperature Code Index
B-008 - Code Index for Mobile Phone Portal
Back window washer wiper
Balancing weights which contain no heavy metals
Balancing weights which contain no heavy metals1
Ball Joint Inspection
Bank 1 Exhaust Camshaft Position Actuator Replace (HMC Engine)
Bank 1 Intake Camshaft Position Actuator Replace (HMC Engine)
Bank 1 Secondary Timing Chain Installation Illustration
Bank 2 Exhaust Camshaft Position Actuator Replace (HMC Engine)
Bank 2 Intake Camshaft Position Actuator Replace (HMC Engine)
Base Plate Replace (Antara)
Battery and Battery Tray Replace1
Battery and Battery Tray Replace2
Battery Specifications
Beauty Cover Replace
Bleeding System
Blower Motor Replace
Blower Resistor Replace
Body Control Module (BCM) Replace (Antara)
Body Control Module (BCM) Replace (Captiva)
Body control module, auxiliary
Body Control Module
Body control module1
Body Identification Number Plate Location
Body rear - Behind rear panelling
Body rear - Behind side panel, rear left
Body rear - Behind side panel, rear left1
Body rear - D-pillar, left
Body rear - D-pillar, left1
Body rear - D-pillar, right
Body rear - Fuel Tank
Body rear - Roof, rear
Body rear - Under vehicle
Body rear - Wheel suspension, left
Body rear - Wheel suspension, right
Body, front, left1
Body, front, left2
Body, rear, left
Body, rear, right
Boost Pressure Sensor (T-MAP Sensor) Replace
Bracket for Auxiliary Heating, Remove and Install - Webasto
Bracket for Fuel Dosing Pump for Auxiliary Heating, Remove and Install - Webasto
Brake Caliper Inspect
Brake Fluid Reservoir Replace
Brake Modulator Assembly Replace
Brake Pad Inspect
Brake Pads Replace
Brake Pads Replace1
Brake Pedal Replace
Brake Pedal Travel Measurement and Inspect
Brake Rotor Assembled Lateral Runout Measure
Brake Rotor Assembled Lateral Runout Measure1
Brake Rotor Surface and Wear Inspect
Brake Rotor Surface and Wear Inspect1
Brake Rotor Thickness Measure
Brake Rotor Thickness Measure1
Brake Rotor Thickness Variation Measure
Brake Rotor Thickness Variation Measure1
Brake System Vacuum Source Test
Brake Systems
Bulb Usage Chart (Antara)
Bulb Usage Chart (Captiva)
C-001 - Diagnostic Tester Power Supply Circuit
C-112 - Engine Start Signal Circuit
C-113 - Ignition Key Position Circuit
C-116 - Power Supply Circuit
Camshaft Cover Replace - Left Side
Camshaft Cover Replace - Right Side
Camshaft Gears Replace
Camshaft Position (CMP) Sensor Replace
Camshaft Position Actuator Assembly (HMA Engine) Replace
Camshaft Position Actuator Solenoid Replace
Camshaft Position Sensor (CMP) Replace
Camshaft Position Sensor Replace
Camshaft Replace - Left Side
Camshaft Replace - Right Side
Camshaft Replace
Camshafts Replace
CAN bus communication
CAN-bus (Left-hand drive)
CAN-bus (Right-hand drive)
CAN-bus high speed (Left-hand drive)
CAN-bus high speed (Right-hand drive)
CAN-bus low speed
CAN-bus mid speed
Catalytic Converter Replace
Catalytic Converter Replace1
Central door locking & Anti-theft warning system
Central door locking (Left-hand drive)1
Central door locking (Left-hand drive)2
Central door locking (Right-hand drive)1
Central door locking (Right-hand drive)2
Central door locking1
Central door locking2
Centre High-Mounted Stoplamp (Antara)
Centre High-Mounted Stoplamp Replace (Captiva)
Centre Pillar Lower Garnish Moulding Replace
Centre Pillar Upper Garnish Moulding Replace
Changing the tyres and wheel trims
Changing the tyres and wheel trims1
Charge Air Cooler Replace
Charging Air System Replace
Chassis Alignment Values for Antara
Chassis Alignment Values for Antara1
Cigar Lighter Replace (Antara)
Cigar Lighter Replace (Captiva)
Cigarette lighter
Cigarette lighter1
Clock Spring Replace
Clutch and Transmission Housing Cleaning and Inspection
Clutch gen info
Clutch Housing Components Illustration
Clutch Master Cylinder Repair
Clutch Master
Clutch Pedal Position Switch Replace
Clutch Pedal Replace
Clutch switch
Combustion Air Fan Unit, Remove and Install - Webasto
Common Rail Pressure Sensor Replace
Common Rail Regulator Replace
Component Index, Block Diagrams
Component Index, Circuit Diagrams
Component Overview of Auxiliary Heating - Webasto
Compression Pressure Check
Compression Pressure Check1
Compressor Clutch Coil Repair
Compressor Clutch Function Test
Compressor Oil Balancing Procedure
Compressor Oil Charge Requirement
Compressor Pulley and Bearing Assembly Repair
Compressor Replace
Compressor, air conditioning
Compressor, air conditioning1
Compulsory make of tyre
Concentric Slave Cylinder Replace
Condenser Replace
Condition of tyres
Connecting Rod Bearings Gauging Plastic
Connecting Rod Bearings Gauging Plastic1
Connecting Rods and Bearings Replace
Control unit - Anti-Lock Brake System
Control unit - Climate control
Control unit hard and software
Controls - Heating air conditioning
Coolant temperature sensor
Cooling Fan Assembly Replace
Cooling Fan Assembly Replace1
Cooling Path Illustration
Cooling System Specifications
Cradle Replace (Antara)
Crankshaft and Bearings Replace
Crankshaft and Main Bearing Visual Inspection
Crankshaft and Main Bearings Replace
Crankshaft Balancer Replace
Crankshaft Balancer Replace1
Crankshaft Balancer Unit Assembly Replace
Crankshaft Bearings - Gauging Plastic
Crankshaft Bearings Gauging Plastic
Crankshaft Front Oil Seal Replace
Crankshaft Measurement
Crankshaft Position (CKP) Sensor Replace
Crankshaft Position (CKP) Sensor Replace1
Crankshaft Position Sensor Replace
Crankshaft Rear Seal And Plate Assembly Replace
Crankshaft Replace
Cross member, instrument panel
Cruise Control Switch Replace (Antara)
Cruise Control Switch Replace (Captiva)
Cruise Control Turn signal Switch and Lever Replace (Antara)
Cylinder Block Deck Flatness Inspection
Cylinder Block Replace
Cylinder Head and Gasket Replace
Cylinder Head and Gasket Replace1
Cylinder Head Assembly Illustration
Cylinder Head Cover Assembly Illustration
Cylinder Head Cover Replace
Cylinder Head Cover Replace1
Cylinder Head Deck Flatness Inspection
Cylinder Head Disassemble and Assemble
Cylinder Head Disassemble and Assemble1
Cylinder Head Inspection
Cylinder Head Inspection1
Cylinder Head Replace - Left Side
Cylinder Head Replace - Right Side
Cylinder Head Valve Train Components Replace
Diagnostic link
Diesel Particulate Filter (DPF) Pressure Sensor Replace
Diesel Particulate Filter (DPF) Replace
Different tyre types
Differential Gear Illustration
Digital Clock Replace (Captiva)
Dimmer Headlamp Levelling Mirror Control Switches Replace (Captiva)
Direct Ignition System (DIS) Replace
Disabling the Supplemental Inflatable Restraints (SIR)
Door Assembly Replace
Door Assembly Replace1
Door Hold-Open Link Replace ( Captiva )
Door Hold-Open Link Replace (Antara)
Door Lock Cylinder Replace
Door Lower Weatherstrip Replace
Door Speakers Replace
Door Striker Adjustment
Door Striker Replace
Door Water Deflector Replace (Antara)
Door Water Deflector Replace (Captiva)
Door Weatherstrip Replace
Doors - Driver door
Doors - Driver door1
Doors - Front passenger door
Doors - Front passenger door1
Doors - Rear door, left
Doors - Rear door, right
Doors - Tailgate
Doors
Draining and Refilling the Cooling System
Drive Axle Assembly Replace
Driver Airbag Module Replace (Antara)
Driver Airbag Module Replace (Captiva)
Driver Information Centre (DIC) Replace (Antara)
Driver Information Centre Replace (Captiva)
Driver Knee Bolster Replace
Dual Horns Replace
Duct Sensor Replace
Dust Boot Replace
Easy diagnosis and trouble-shooting
ECU Sensor Integrated (SI) Replace (Antara)
EGR System Replace
EGR Vacuum Solenoid Valve Replace
EGR Valve Adapter and Internal PCV Pipe Replace
EGR Valve Replace
Electric Cooling Fan Assembly Replace
Electric Throttle Control (ETC) Replace
Electrochromatic inside mirror
Electronic Brake Control Module Replace
Electronic climate control
Electronic Throttle Body Replace
Enabling the Supplemental Inflatable Restraints (SIR)
Engine and Transmission Availability
Engine and Transmission Mounts Illustration
Engine Bed Plate Replace
Engine Block Assembly Illustration
Engine Block Replace
Engine compartment - Behind front panelling, left
Engine compartment - Front
Engine compartment - Fuse & Relay box
Engine compartment - Radiator
Engine compartment - Radiator1
Engine compartment - Rain channel
Engine compartment - Rear
Engine compartment - Under vehicle
Engine compartment - Wheel suspension
Engine Compartment Illustration
Engine compartment, left
Engine Control Module (ECM) Replace
Engine Control Module Replace
Engine Control Module Replace1
Engine Controls Component Illustration
Engine Coolant Temperature (ECT) Sensor Replace
Engine Coolant Temperature (ECT) Sensor Replace1
Engine Coolant Temperature Sensor Replace
Engine cooling
Engine Dress Cover Replace
Engine Electrical - Z 24 XE, Z 32 SE and Z 20 DMH
Engine Exhaust - Z 24 XE, Z 32 SE and Z 20 DMH
Engine Flywheel Replace
Engine Front Cover Illustration
Engine Front Cover Replace
Engine Front Shield Replace
Engine Lower End Illustration
Engine Lower End Illustration1
Engine Mount Assembly (RH Side) Replace
Engine Mount System Illustration
Engine Mount System Illustration1
Engine Number Location
Engine Number
Engine Oil Filter and Cooler Replace
Engine Oil Pressure Sensor Replace
Engine Overview - Z 20 DMH
Engine Overview - Z 20 DMH1
Engine Overview - Z 24 XE
Engine Overview - Z 24 XE-1
Engine Overview - Z 32 SE
Engine Overview - Z 32 SE-1
Engine Specifications
Engine Specifications1
Engine Under Covers Replace
Engine Upper End Illustration
Engine Upper End Illustration1
Engine with Transmission Remove and Install
Engine Z20DM Z20DMH, EDC 16 C39
Engine Z20DM, EDC 16 C39
Engine Z24XE, Motronic 7.9.9
Engine Z32SE, Motronic 7.6.1
Engraved VIN Location
Entertainment Head Unit (EHU) Programming (Antara)
ESP OFF Switch DCS Switch Replace
Evaporative (EVAP) Emission Canister Assembly Replace
Evaporative (EVAP) Emission Canister Assembly Replace1
Evaporative (EVAP) Emission Canister Filter Replace
Evaporative (EVAP) Emission Canister Filter Replace1
Evaporative (EVAP) Emission Canister Purge Solenoid Valve Replace
Evaporative (EVAP) Emission Pipe Assembly Replace
Evaporative (EVAP) Emission Pipe Assembly Replace1
Evaporative Emission Canister Purge Valve Replace
Evaporator Core Replace
Exhaust Front Pipe Replace
Exhaust Gas Temperature (EGT) Sensor 1 Replace
Exhaust Gas Temperature (EGT) Sensor 2 Replace
Exhaust Manifold Assembly Replace
Exhaust Manifold Replace
Exhaust Manifold Replace1
Exhaust Particulate Filter Clean
Exhaust System Illustration (Antara)1
Exhaust System Illustration (Antara)2
Exhaust System Illustration (Captiva)1
Exhaust System Illustration (Captiva)2
Exterior lighting
External Rear View Mirror Replace
Fender Replace (Antara)
Fender Replace (Captiva)
Filter heating
Fitting winter tyres
Five-Speed Manual Transmission (D33)
Flame Monitor Glow Plug, Check (Webasto System)
Flame Monitor Glow Plug, Check (Webasto System)1
Flame Monitor Glow Plug, Remove and Install - Webasto
FlexFix - Rear Bicycle Carrier
Floor Carpet Replace
Floor Console Replace
Floor Panel Rear Extension Replace
Floor, under seat, right
Fluid Capacity
Fluid Specifications
Fog Lamps Replace (Antara)
Fog Lamps Replace (Captiva)
Fog lamps, front
Fog lamps, rear
Foreword to Chassis Alignment Values for Model Year 2007
Foreword to Chassis Alignment Values for Model Year 20071
Formed Headliner Replace (Antara)
Formed Headliner Replace (Captiva)
Forward (C1) and Direct Clutch (C2) Disassembly
Forward (C1) and Direct Clutch (C2) Inspection
Forward Clutch (C1) and Direct Clutch (C2) Assembly
Forward Clutch (C1) and Direct Clutch (C2) Illustration
Front and Rear Panelling
Front Brake Hose Replace
Front Bumper Energy Absorber Replace (Antara)
Front Bumper Energy Absorber Replace (Captiva)
Front Bumper Fascia Replace (Antara)
Front Bumper Fascia Replace (Captiva)
Front Bumper Impact Bar Replace (Antara)
Front Bumper Impact Bar Replace (Captiva)
Front Caliper Bracket Replace
Front Caliper Replace
Front Camber Adjustment
Front Caster Adjustment
Front Control Arm Ball Joint Replace
Front Control Arm Replace
Front Disc Brake Mounting and Hardware Inspect
Front Door Channel Replace
Front Door Glass Replace
Front Door Lock Replace (Antara)
Front Door Lock Replace (Captiva)
Front Door Opening Weatherstrip Replace
Front Door Outside Handle Replace (Captiva)
Front Door Step Lamp Replace
Front Door Tamper and Door Contact Switch Replace
Front Door Trim Panel Replace (Antara)
Front Door Trim Panel Replace (Captiva)
Front Door Window Weatherstrip Replace
Front Drive Axle Body Remove and Install
Front Drive Axle Illustration
Front Drive Axle Intermediate Shaft Seal Replace
Front end - Behind front panelling
Front Fender Insulator Replace
Front Fender Wheel Opening Moulding Replace
Front Heated Oxygen Sensor Replace
Front lamps (not Xenon light)
Front lamps (Xenon light)
Front lamps, relays
Front Object Alarm Sensor Replace (Antara)
Front Planetary Ring Gear Assembly
Front Planetary Ring Gear Disassembly
Front Rotor Replace
Front Seat Belt Height Adjuster Replace
Front Seat Cushion Replace
Front Seat Replace
Front Seat Track Replace
Front Seat Trim Replace
Front Seatback Replace
Front Side Door Lower Moulding Replace
Front Side Door Retainer Replace
Front Side Door Window Frame Rear Applique Replace
Front Silencer Replace (Antara)
Front Silencer Replace (Antara)1
Front Silencer Replace (Captiva)
Front Silencer Replace (Captiva)1
Front Sill Panelling, Replace
Front Sill Panelling, Replace1
Front Splash Shield Replace
Front Strut Replace
Front Suspension Illustration
Front Suspension
Front Toe Adjustment
Front Wheel Speed Sensor
Front Wheelhouse Liner Replace
Front Window Applique Replace (Antara)
Front Window Applique Replace (Captiva)
Front Window Retainer Replace
Front, Replace Complete
Front, Replace Complete1
Fuel Common Rail Replace
Fuel Filler Door Replace
Fuel Filter Water in Fuel Sensor Fuel Heater and Temperature Sensor Replace
Fuel Hose or Pipes Routing Component Locator
Fuel Injection Line Routing Component Locator
Fuel Injection Pump Replace
Fuel Injector Flow Rate Programming
Fuel Pressure Inspection (Low Pressure Line)
Fuel Pressure Test
Fuel Priming
Fuel Pump Assembly Replace
Fuel pump
Fuel Rail and Injectors Replace
Fuel Rail Assembly Replace
Fuel Return Line Assembly Replace
Fuel Sender Replace
Fuel System Pressure Relief
Fuel Tank Replace
Function Check and Troubleshooting - Auxiliary Heating (Eberspaecher System)
Function Check and Troubleshooting - Auxiliary Heating (Eberspaecher System)1
Fuse relay box, diesel
Fuses Circuits
Gear Shift Control Illustration
General Body Construction
General Description (Webasto System)
General Description (Webasto System)1
General Description, Auxiliary Heating - Webasto
General Specifications
General System Description
General Warnings and Safety Regulations
Glass Systems
Glow Plug Replace
Ground distribution
Guide Values for Torque, Auxiliary Heating (Eberspaecher System)
Guide Values for Torque, Auxiliary Heating (Webasto System)
Head Restraint Replace
Headlamp Turn signal Switch and Lever Replace (Captiva)
Headlamp washer
Headlamps Replace (Antara)
Headlamps Replace (Captiva)
Heat Exchanger for Auxiliary Heating, Remove and Install - Webasto
Heated back window
Heater Core Replace
Heater Hoses Replace
Heating Mat Replace
Heating Unit, Functional Check (Webasto System)
Heating Unit, Functional Check (Webasto System)1
Heating Unit, Functional Check, Auxiliary Heating - Webasto
Heating, Ventilation and Air Conditioning
Heating, Ventilation and Air Conditioning1
Height Adjustment Lever Replace
High Pressure Fuel Feeding Pipes Replace
High-blower Relay Replace
Hood Contact Switch Replace (Antara)
Hood Contact Switch Replace (Antara)1
Hood Hinges Replace
Hood Insulation Replace
Hood Latch Release Cable Replace
Hood Primary Latch Support Replace
Hood Primary Latch Support Replace1
Hood Replace
Hood Replace1
Hood Struts Replace
Hub and Parking Brake Shoe Back Plate Replace
Hydraulic Brake System Bleeding (Manual)
Hydraulic Clutch Components Illustration
Hydraulic Cylinder Lines Replace
Identification of Rims and Tyres
Identification of Rims and Tyres1
Idle Learn Procedure
Ignition Coil Replace
Ignition Switch Replace
Ignition switch
Immobiliser
Immobiliser1
Immobilizer (PK3+) Replace (Antara)
Immobilizer (PK3+) Replace (Captiva)
Inclination Sensor Replace
Independent Heater
Info Display
Injector Replace
Inlet Air Door Motor Replace
Inner Joint Seal Replace
Input Shaft and Output Shaft Cleaning and Inspection
Input Shaft Assembly
Input Shaft Disassembly
Input Speed Sensor and Output Speed Sensor Check
Input Speed Sensor Replace
Instructions for Manual Function Check and Troubleshooting (Eberspaecher System)
Instructions for Manual Function Check and Troubleshooting (Eberspaecher System)1
Instrument Cluster Dimmer Headlamp Leveling Switch Replace (Antara)
Instrument Cluster Replace (Antara)
Instrument Cluster Replace (Captiva)
Instrument Compartment Lamp Replace (Antara)
Instrument Compartment Lamp Replace (Captiva)
Instrument Compartment Replace
Instrument Panel and Driver Information
Instrument Panel Lower Compartment Replace (Captiva)
Instrument Panel Replace (Antara)
Instrument Panel Replace (Captiva)
Instrument Panel Steering Column Opening Pillar Replace
Instrument Panel Vents Replace (Antara)
Instrument Panel Vents Replace (Captiva)
Instrument
Instrument1
Intake Air Temperature (IAT) Sensor Replace
Intake Exhaust System Illustration
Intake Manifold Assembly Illustration
Intake Manifold Assembly Replace
Intake Manifold Replace
Intake Manifold Replace1
Intake Manifold Tuning Control Solenoid Valve Replace
Interior lights
Interior Trim
Intermediate Drive Shaft Assembly
Intermediate Drive Shaft Disassembly
Intermediate Shaft Assembly
Intermediate Shaft Disassembly
Intermediate Shaft Joint and Dash Seal Replace
Introduction - International Pre-delivery Inspection
Introduction Service Plan international
Introduction
Intrusion (Shock) Sensor Replace
IP Centre Speaker Replace (Antara)
IP Centre Speaker Replace (Captiva)
Key Cylinder Replace (Antara)
Key Cylinder Replace (Captiva)
Key Hole Lamp Replace
Knock Sensor Replace
Knock Sensor Replace1
Knuckle, Hub Replace
Left Input Shaft Seal Replace
Left Transmission Mounting Bracket Replace
Licence plate lamps
License Plate Lamps Replace
Liftgate Applique Replace
Liftgate Glass Defogger Braided Lead Wire Repair
Liftgate Glass Defogger Grid Line Repair
Liftgate Glass Replace
Liftgate Latch Replace (Antara)
Liftgate Latch Replace (Captiva)
Liftgate Lower Trim Replace (Antara)
Liftgate Lower Trim Replace (Captiva)
Liftgate Replace
Liftgate Strut Replace
Liftgate Tamper Switch Replace (Captiva)
Liftgate Upper Applique Replace (Antara)
Liftgate Upper Applique Replace (Captiva)
Liftgate Weatherstrip Replace
Liftgate Window Latch Replace
Liftgate Window Side Garnish Moulding Replace (Antara)
Liftgate Window Side Garnish Moulding Replace (Captiva)
Liftgate Window Strut Replace
Liftgate Window Upper Garnish Moulding Replace
Lighting rear (not Rear Bicycle Carrier)
Lighting rear (Rear Bicycle Carrier)
Lighting Systems
Line Pressure Check 1
Line Pressure Check
Line Pressure Specification
Lumbar Support Knob Replace
Major Component Assembly
Major Component Assembly1
Major Component Disassembly
Major Component Disassembly1
Manifold Absolute Pressure (MAP) Sensor Replace
Manual Transmission Assembly Remove and Install
Manual Transmission Housing Components Illustration
Manual Transmission Identification Number Plate Location
Map Lamp Replace (Antara)
Map Lamp Replace (Captiva)
Mass Air Flow (MAF) Sensor Assembly Install
Mass Air Flow Sensor (MAF) Replace
Master Cylinder Assembly Replace
Microphone Replace (Antara)
Mode Door Motor Replace
Model Identification
Models for MY 2007
Mud Guards Replace
No communications
Object Alarm Control Module Replace (Antara)
Oil Cooler Line Assembly Replace
Oil Cooler Line Seals Replace
Oil Pan Assembly Illustration
Oil Pan Replace
Oil Pressure Check
Oil Pressure Check1
Oil Pressure Switch Replace
Oil Pump and 2nd Coast Brake (B1), 2nd Brake (B2) Disassembly
Oil Pump and 2nd Coast Brake (B1), 2nd Brake (B2) Flange, Disc and Plate Inspection
Oil Pump and 2nd Coast Clutch (B1), 2nd Brake (B2) Illustration
Oil Pump Assembly Replace
Oil Pump Assembly
Oil Pump Bushing Inspection
Oil Pump Replace
Oil Pump Replace1
Oil Strainer Replace
Operation Check Of 1 Way Clutch No.2 (F2)
Outer Joint Seal Replace
Outer Tie Rod Replace
Outer Window Replace
Output Shaft Assembly
Output Shaft Disassembly
Output Speed Sensor Replace
Outside mirror (Left-hand drive)
Outside mirror (Right-hand drive)
Outside Rearview Mirror Glass Replace
Park pilot
Parking and Front Turn Signal Lamps Replace (Antara)
Parking and Front Turn Signal Lamps Replace (Captiva)
Parking Brake Adjustment Rear Disc Brakes
Parking Brake Cable Replace
Parking Brake Lever Replace
Parking Brake Warning Lamp Switch Replace
Parking lamps (Xenon light)
Passenger Airbag Module Replace (Antara)
Passenger Airbag Module Replace (Captiva)
Passenger Assist Handles Replace (Antara)
Passenger Assist Handles Replace (Captiva)
Passenger compartment - A-pillar
Passenger compartment - Behind centre console
Passenger compartment - Behind instrument panel, driver side
Passenger compartment - Behind instrument panel, driver side1
Passenger compartment - Behind instrument panel, front passenger side
Passenger compartment - B-pillar
Passenger compartment - Centre console Under front seats
Passenger compartment - Centre console Under front seats1
Passenger compartment - Door sill, front, right
Passenger compartment - Electronic climate control
Passenger compartment - Fuse & Relay box1
Passenger compartment - Fuse & Relay box2
Passenger compartment - Instrument panel, behind glove box
Passenger compartment - Instrument panel, behind glove box1
Passenger compartment - Instrument panel, driver side Under steering column
Passenger compartment - Roof, front
Passenger compartment - Tunnel
Passenger compartment - Under driver seat
Passenger compartment - Under front passenger seat
Passenger compartment - Under front seat, right
PCV Valve and Adapter Replace
Pedal position sensor
Pedal position sensor1
Piston and Connecting Rod Components Illustration
Piston and Rings Replace
Pistons And Connecting Rods Assembly
Pistons and Connecting Rods Replace
Planetary Gear Assembly Illustration
Planetary Gear Assembly Inspection
Power Booster Assembly Replace
Power Driver Seat Slide Assembly Replace
Power Module Replace
Power steering (SSPS C10X)
Power steering (SSPS C10X)1
Power Steering Fluid Supply Hose Replace
Power Steering Pump Hoses and Pipes Replace
Power Steering Pump Replace
Power Steering System Pressure Test
Power train - Automatic transmission1
Power train - Automatic transmission2
Power train - Engine, cowl panel side
Power train - Engine, distribution side
Power train - Engine, exhaust side
Power train - Engine, intake side
Power train - Engine, radiator side1
Power train - Engine, radiator side2
Power train - Engine, top
Power train - Engine, transmission side
Power Window Regulator Replace
Pre-delivery Inspection – Technical check from MY 2006 – International
Pre-delivery Inspection, visual appearance – Hand-over to customer from MY 2006
Pre-delivery Inspection, visual appearance – Hand-over to customer from MY 2006-1
Preselection Clock, Check (Webasto System)
Preselection Clock, Check (Webasto System)1
Pressure Plate and Clutch Disc Replace 1
Pretensioner Front Seat Belt Buckle Replace
Primary and Bank 2 Secondary Timing Chain Installation Illustration
Primary Camshaft Drive Chain and Sprockets Replace
Primary Catalytic Converter Replace
Procedure for fitting spare wheel in event of puncture
Propeller Shaft Replace
Push-button Switch for Auxiliary Heating, Remove and Install - Webasto
Quarter Window Garnish Moulding Replace (Antara)
Quarter Window Garnish Moulding Replace (Captiva)
Quarter Window Replace
Race and Bearing Specifications
Rack and Pinion Assembly Replace
Radiator and Fan Illustration
Radiator Grille Guide Replace (Antara)
Radiator Grille Guide Replace (Captiva)
Radiator Grille Replace (Antara)
Radiator Grille Replace (Captiva)
Radiator Replace
Radio
Radio1
Rear Brake Hose Replace
Rear Bumper Fascia Replace (Antara)
Rear Bumper Fascia Replace (Captiva)
Rear Bumper Impact Bar Replace
Rear Caliper Bracket Replace
Rear Caliper Replace
Rear Camber Adjustment
Rear Case and B5 Brake Illustration
Rear Case Disassembly
Rear Coil Spring Insulators Replace
Rear Combination Lamps Replace
Rear Compartment Stow Tray Replace
Rear Disc Brake Mounting and Hardware Inspect
Rear Door Channel Replace
Rear Door Glass Replace
Rear Door Opening Weatherstrip Replace
Rear Door Outside Handle Replace (Captiva)
Rear Door Trim Panel Replace (Antara)
Rear Door Trim Panel Replace (Captiva)
Rear Door Window Weatherstrip Replace
Rear Drive Axle Illustration
Rear Drive Module Repair
Rear Drive Module Replace
Rear Heated Oxygen Sensor Replace
Rear Knuckle Replace
Rear Left and Centre Buckle or Seat Belt (Folding Seat) Replace (Captiva)
Rear Left and Centre Buckle or Seat Belt Replace (Antara)
Rear Left and Centre Seat Belt Buckle (Double Folding Seat) Replace (Captiva)
Rear Lower Control Arm Replace
Rear Object Alarm Assembly Replace (Captiva)
Rear Object Alarm Control Module Replace (Captiva)
Rear Object Alarm Sensor Replace (Antara)
Rear Object Alarm Sensor Replace (Captiva)
Rear Output Drive Housing Assembly
Rear Output Drive Housing Assembly1
Rear Output Drive Housing Cleaning and Inspection
Rear Output Drive Housing Disassembly
Rear Right Seat Belt Buckle (Double Folding Seat) Replace (Captiva)
Rear Right Seat Belt Buckle (Folding Seat) Replace (Captiva)
Rear Right Seat Belt Buckle Replace (Antara)
Rear Rotor Replace
Rear Seat Back Replace
Rear Seat Replace
Rear Seat Trim Replace
Rear Shock Absorber Replace
Rear Side Door Lower Moulding Replace
Rear Side Door Retainer Replace
Rear Silencer Replace (Antara)
Rear Silencer Replace (Antara)1
Rear Silencer Replace (Captiva)
Rear Silencer Replace (Captiva)1
Rear Sill Panelling, Replace
Rear Sill Panelling, Replace1
Rear Stabilizer Shaft Insulator Replace
Rear Stabilizer Shaft Link Replace
Rear Stabilizer Shaft Replace
Rear Suspension Illustration
Rear Suspension
Rear Timing Belt Cover Replace
Rear Toe Adjustment
Rear Upper Control Arm Replace
Rear Wheel Bearing Hub Replace
Rear Wheel Drive Shaft Illustration
Rear Wheel Drive Shaft Repair
Rear Wheel Drive Shaft Replace
Rear Wheel Opening Moulding Replace
Rear Wheel Speed Sensor Replace
Rear Wheelhouse Liner Replace
Rear Wheelhouse Trim Panel Replace (Antara)
Rear Wheelhouse Trim Panel Replace (Captiva)
Rear Window Applique Replace (Antara)
Rear Window Applique Replace (Captiva)
Rear Window Retainer Replace (Antara)
Rear Window Retainer Replace (Captiva)
Rear Wiper Arm Park Replace
Rear Wiper Arm Replace
Rear Wiper Motor Replace
Rear Wiper Nozzles Replace
Recirculation Pump for Auxiliary Heating, Remove and Install - Webasto
Recommended Fluids and Lubricants
Recommended Materials for Waterleak Repairs
Recommended Torque Values
Remote Control Receiver for Auxiliary Heating, Remove and Install - Webasto
Remote Control Transmitter, Check (Telestart) (Webasto System)
Remote Control Transmitter, Check (Telestart) (Webasto System)1
Remote control, radio
Remote Function Actuation (RFA C10X)
Remote Function Actuation (RFA C10X)1
Replace B-pillar complete
Replace B-pillar complete1
Replace extension rear frame longitudinal member
Replace extension rear frame longitudinal member1
Replace Flex Fix System
Replace outer B-pillar
Replace outer B-pillar1
Replace sill panelling complete
Replace sill panelling complete1
Replace towbar
Replace towbar1
Reprogrammable Electronic Control Units
Retrofitting wheeltyre combinations
RFA (Remote Function Actuation) Receiver Replace
Right Input Shaft Seal Replace
Rocker Arm Replace
Rocker Panel Moulding Replace (Captiva)
Roof Moulding Replace
Roof Rail Airbag Module Replace (Antara)
Roof Rail Airbag Module Replace (Captiva)
Roof, Replace
Room Lamp Replace
RunFlat tyres
Safety Regulations
Safety Restraint System
Seat adjustment
Seat Belts
Seat heating, front (Left-hand drive)
Seat heating, front (Right-hand drive)
Seat Recliner Lever Replace
Seats
Secondary Camshaft Drive Chain Replace - Left Side
Secondary Camshaft Drive Chain Replace - Right Side
Sensing and Diagnostic Module (SDM) Replace
Sensor - Rain
Sensor, air conditioning
Shaft Assembly and Shift Fork Illustration
Shaft Components Illustration
Shift Control Cable Adjustment 1
Shift Control Cable Replace manual
Shift Control Knob Replace
Shift Control Lever Assembly Replace
Shift Control Lever Housing Replace
Shift Fork Cleaning and Inspection
Shift Select Control Illustration
Shift Shaft Assembly
Shift Shaft Components Illustration
Shift Shaft Disassembly
Shift Speed Technical Data
Shimming Procedures
Side Airbag Sensor Replace
Side Glass Antenna Module Replace (Captiva)
Side Panel, Replace
Side Panel, Replace1
Side Turn Signal Lamps Replace (Antara)
Side Turn Signal Lamps Replace (Captiva)
Silencer for Auxiliary Heating, Remove and Install - Webasto
Silencer Support Replace
SIR Component Illustration (Antara)
SIR Component Illustration (Captiva)
SP17 Air Conditioning Compressor Overhaul
SP17 Compressor Illustration
Spark Plug Replace
Spark Plug Specifications
Spark Plug Specifications1
Speakers, front doors
Speakers, Instrument panel
Speakers, rear doors
Special Service Tools
Special Tools
Speed Sensitive Power Steering (SSPS) Control Module Replace
Splash Guard Replace - Front
Spring Bump Stop Replace
Stabilizer Link Replace
Stabilizer Shaft Cradle Replace
Start & Charging
Start & Charging1
Starter Motor Repair
Starter Replace
Starter Replace1
Starter Replace2
Starter Specifications
Stationary Hydraulic Lash Adjuster Replace
Steering Angle Sensor Centring
Steering Angle Sensor Replace
Steering Column Cover Replace (Antara)
Steering Column Cover Replace (Captiva)
Steering Column Replace (Antara)
Steering Column Replace (Captiva)
Steering Wheel and Column
Steering Wheel Replace (Antara)
Steering Wheel Replace (Captiva)
Stop lamp - Middle
Stop lamp switch
Stoplamp Switch Replace
Stoplamp Switch Replace1
Structural Wheels
Structural Wheels1
Sun roof
Sun roof1
Sun Sensor Replace
Sun Visors with Vanity Mirror Replace (Antara)
Sun Visors with Vanity Mirror Replace (Captiva)
Sunroof Air Deflector Replace
Sunroof Drain Inspect and Clean
Sunroof Frame Replace
Sunroof Housing Front Drain Hose Replace
Sunroof Housing Rear Drain Hose Replace
Sunroof Motor Actuator Initialization Teach Process
Sunroof Motor Actuator Replace
Sunroof Panel Side Opening Closeout Cover Replace
Sunroof Sunshade Replace
Sunroof Switch Replace
Sunroof Track Timing Synchronization
Sunroof Water Gutter Replace
Sunroof Window Height and Opening Fit Adjust
Sunroof Window Replace
Surge Tank Replace
Surge Tank Replace1
Surge Tank Replace2
Switch - Reversing lamp
Switch unit - Light
Switch unit - Steering column, left (Not Holden)
Switch unit - Steering column, right (Holden)
Switch unit - Steering column, right (Holden)1
Switch unit, centre console
Synchronizers Cleaning and Inspection
System Index
System Voltage Circuits
Tailgate Latch Striker Replace
Technical ABC
Technical Data – Z 24 XE, Z 32 SE, Z 20 DMH
Technical Data (Eberspaecher System)
Technical Data (Webasto System)
Technical Data
Technical Data1
Technical Data2
Temperature Door Motor Replace
Theft Deterrent Alarm Replace
Thermistor Replace
Thermostat Replace
Thermostat Replace1
Thermostat Replace2
Third Row Rear Seat Belt Buckle Replace (Captiva)
Three-Point ELR Front Seat Belt Replace
Three-point ELR Rear Seat Belt Replace
Three–point ELR Third Row Rear Seat Belt Replace (Captiva)
Throttle Body Assembly Replace
Thrust Washer and Bearing Cleaning and Inspection
Timing Belt Adjustment
Timing Belt Check and Adjust
Timing Belt Replace
Timing Belt System Illustration
Timing Belt System Replace
Timing Chain Component Inspection
Timing Chain Components Illustration
Toe Link Replace
TPS (Tyre Pressure Sensor) ID Registration Procedure
Trailer Hitch Preparation (12-pin connector)
Trailer Hitch Preparation (16-pin connector)
Trailing Arm Bracket Replace
Trailing Arm Replace
Transfer Case Assembly
Transfer Case Cleaning and Inspection
Transfer case control module (TCCM C10X)
Transfer Case Disassembly
Transfer Case Exploded View
Transfer Case Fluid Replace
Transfer Case Replace 1
Transmission Control Module (TCM) Replace
Transmission Fluid Check
Transmission Fluid Level Check 1
Transmission Fluid Replace manual
Transmission Front Mount Assembly Replace
Transmission Gear Ratio
Transmission Gears Cleaning and Inspection
Transmission Mount Assembly (LH Side) Replace
Transmission Range (TR) Switch Adjustment
Transmission Range (TR) Switch Replace
Transmission Rear Mount Assembly Replace
Trim Height Inspect
Troubleshooting and Fault Elimination (Webasto System)
Troubleshooting and Fault Elimination (Webasto System)1
Troubleshooting and Fault Elimination, Auxiliary Heating - Webasto
Trumpet horn
Turbocharger Replace
Turn signal lamps
Tyre filling system
Tyre Pressure Monitoring
Tyre Pressure Sensor Illustration
Tyre Pressures Antara - Model Year 2007 to 2010
Tyre Size and Pressure Specifications
Tyre with specified direction of running
Underbody Catalytic Converter (UCC) Replace
Underbody Catalytic Converter (UCC) Replace1
Underbody Dimensions (Antara)
Underbody Dimensions Illustration (Captiva)
Underdrive Brake (B4) Illustration
Underdrive Brake (B4) Piston Assembly
Underdrive Brake (B4) Piston Disassembly
Underdrive Clutch (C3) Assembly
Underdrive Clutch (C3) Disassembly
Underdrive Clutch (C3) Illustration
Underdrive Rear Planetary Gear Assembly Illustration
Universal Handsfree Phone (UHP) Module Replace (Antara)
Upper Front, Partially Replace
Upper Front, Partially Replace1
Upper Intake Manifold Replace
Vacuum Hose Replace
Vacuum Pump Replace
Valve and Seat Grinding
Valve and Seat Reconditioning Procedure
Valve Body Assembly Illustration 1
Valve Body Assembly
Valve Body Disassembly
Valve Body Inspection
Valve Grind
Valve Guide Measurement
Valve Guide Ream
Valve Margin Measurement
Valve Seat Cut
Valve Seat Measurement
Valve Spring Inspection and Measurement
Valve Stem Height Measurement Procedure
Valve-to-Seat Concentricity Measurement
Vehicle and Component Identification
Vehicle Dimensions and Weights (Antara)
Vehicle Dimensions and Weights (Captiva)
Vehicle Identification (VIN) Plate
Vehicle Lifting Procedures
VIN EU-type
VIN Plate Location
VIN Plate Type A
VIN Plate Type B
Voice controlled telephone
Voice controlled telephone1
Voltage distribution
Wash Wipe Systems
Washer nozzles, heated
Washer Pump Replace
Washer Reservoir Replace
Water Outlet Port Replace
Water Pump and Thermostat Illustration
Water Pump Replace
Wheel Alignment Differences Between Front and Rear
Wheel Alignment Differences Between Front and Rear1
Wheel Alignment Specifications
Wheel Alignment Specifications1
Wheels and Tyres
Window lifters (Left-hand drive)
Window lifters (Right-hand drive)
Window Outer Sealing Strip Replace (Captiva)
Window Outer Sealing Strip Replace (Captiva)1
Windscreen washer
Windscreen wiper
Windshield Arm Blade Replace
Windshield Garnish Moulding Replace
Windshield Replace
Windshield Washer Hoses Replace
Windshield Washer Nozzles Replace
Windshield Wiper Arm Replace
Windshield Wiper Motor Replace
Windshield Wiper Transmission Replace
Wiper Blade Element Replace
Wiper Cruise Control Switch and Lever Replace (Captiva)
Wiper Switch and Lever Replace (Antara)
Wiper washer switch (Holden)
Wiper washer switch (Not Holden)
Wiper washer system
Wiring harnesses
X-Body Control Module (BCM) Replace (Antara)
X-Body Control Module (BCM) Replace (Captiva)
Yaw Rate Sensor Replace
