Hyundai
86
176,834
Chery A11 2002 Workshop Manual
Brand: Chery
Type of Machine: Automotive
Type of Manual: Workshop Manual, Electric Diagrams
Model: Chery A11 2002
Number of Pages: 784 Pages
A11 electric diagram-1-forward and content
A11 electric diagram-2
A11 electric diagram-3
A11 electric diagram-4-SPI electic injection
A11 electric diagram-5
A11 electric diagram-6
A11 SQR7160 VEHICLE CIRCUIT MANUAL
A11 sunroof
AQ015 manual gearbox
Seal Washer
Oil Seal
Snap Ring
Bolt & Nut
Bearing
Shim Adjusting
Disassembly
Adjustment of gear-5 fork
Repair of Rear Housing
Procedures of Assembly
Adjustment of Output Shaft
Assembly of Left Oil Seal
Assembly of Output Flange
CAC engine maintenance and operaiton (Page 39-46)
Instruction Book on Using and Maintenance of SQR7160 engine
Marelli electric injection system
Min. stroke ensured by pusher: 8.9 mm
Chapter Two: Basic Principle for EFI System Failure Diagnosi
Failure: too high system votage
MOTOROLA electric injection system manual
A
SQR7160 AT dismantling & assembling booklet
SQR7160 AT fault diagnose booklet
4HP14 Automatic transmission special tool
4HP14 Automatic transmission assembly sketch
4HP14 Automatic transmission assembly’s service
Automatic transmission bolt tightening torque
Fault analysis when the control handle is at Position N
Fault analysis when the control handle is at Position D
Fault analysis when the control handle is at Position 2
Oil leaking fault
Vehicle speed sensor
Oil pan and gasket
Side cover and gasket
Oil cooling pipe
Front suspension
Brief introduction of the automatic transmission
Torque converter
Oil pump
Planetary gear mechanism
Control element
One-way overrun clutch
Clutch and brake
Brake band
Automatic transmission’s power transfer
Parking brake
Hydraulic control system
Centrifugal governor
SQR7160 engine maintenence guide
Operation
Testing Method
SQR480EC EI system faults and trouble shooting
SQR7160 ET circuit diagram
the service handbook of CHERY vehicle
United elctronic fuel injection system
Failure code: P0122 too low circuit voltage of throttle posi
Failure code: P0325 circuit error of knock sensor
