Challenger Tractor WT540HI Parts Catalog VBWT540H
Brand: Challenger
Model: Challenger WT540HI Tractor
Part Number: VBWT540H
Number of Pages: 273 Pages
Flywheel And Housing
Valve Mechanism
Crankshaft Mechanism
Front Cover
Sump
Air Filter
Inlet And Exhaust Manifold
Muffler And Instalation Air Filter
Turbocharger
Sedimentation Filter
Throttle System
S1
Gasket Set S1 + S2
Engine Repair Kit
Bosch
Iskra
90a
Cab Upper Eletrical System
Rear Electrical System
Instruments Panel
Lights
Panel Eletric System
Front Eletric System
Front Window Wiper
Battery And Support
Radio (Optional )
Rear Windor Wiper (Optional)
Fog Light (Optional)
Light Number Plate (Optional Equipment)
Single Clutch
Double Clutch
Single Clutch Control
Double Clutch Control
Gearbox Housing
Countershaft, Mainshaft, Bevel Pinion Shaft(Hd)
Gearbox Cooling
Levers Housing
Range And Speed Gear Levers
Range And Speed Gear Levers- Hi- Confort
Gearbox Speed Multiplyer
Power Take Off 540 Rpm
Pto Drive Lever
Service Brake Control Drive
Control Brake System
Final Drives And Brakes
Differential Lock Drive
Steering Wheel And Column
Steering Wheel And Adjustable Column
Hydraulic Steering
Hydrostatic Steering Unit Danfoss
Frame And Bearing Of Front Axle Carraro
Articulation Housing Carraro 20.43up-Pcr
Flange, Bevel Gear And Pinion Carraro-Pcr
Double Joint Carraro-Pcr
Planetary Gear Housing Carraro-Pcr
Carraro-Pcr
Front Drive Selecting
Cardan Shaft
Frame, Bearing And Cardan
4wd Zf Apl-359
Swivel Housing Planetary Gear 4wd Zf Apl 359
Steering Cylinder And Arm 4wd Zf Apl-359
Front Wheel 4 X 4
Rear Wheel
Rear Wheel (Optional)
Double Rear Wheel
Buffer And Front Counterweight
Rear Wheel Counterweight (Tyre 18.4 And 20.8 )- Accessory
Accessory
Rear Whell Counterweight (Tyre 24.5)
Roof
Cab Doors
Cab Windows
Insulating And Coating For Cab
Seat For Cab (Part 1)
Seat For Cab (Part 2)
Seat For Cab (Part 3)
Front Mudguards
Low Speed Vehicle Indicator
Cab Visor
Rear View Mirror
Intern Rear View Mirror
Aditional Seat
Front Shields
Air Conditioning
Heating Unit
Hydraulic Valve
Gearbox Upper Cover
Hydraulic Lever System
Lift Cylinder
Upper Link Rod And Pecker Lift
Lift Connection
Auxiliary Lift Cylinder
Auxiliary Cylinder D=65mm
Auxiliary Cylinder D= 80mm
Auxiliary Cylinder D=76,2mm
Directional Control Valve
Trailer Hitch
Planting Implement Kit
Sugar Cane Implement With Motor-Hi-Confort
Sugar Cane Implement Without Motor- Hi-Confort
Hi Confort
Cardan Of Pump
Adhesives (Portuguese)
Adhesives (Spanish)
Adhesives (English)
Brand: Challenger
Valve Mechanism
Front Cover
Sump
Air Filter
Turbocharger
Throttle System
S1
Gasket Set S1 + S2
Engine Repair Kit
Bosch
Iskra
90a
Instruments Panel
Lights
Front Window Wiper
Battery And Support
Radio (Optional )
Single Clutch
Double Clutch
Gearbox Housing
Gearbox Cooling
Levers Housing
Pto Drive Lever
Hydraulic Steering
Carraro-Pcr
Cardan Shaft
4wd Zf Apl-359
Front Wheel 4 X 4
Rear Wheel
Double Rear Wheel
Accessory
Roof
Cab Doors
Cab Windows
Front Mudguards
Cab Visor
Rear View Mirror
Aditional Seat
Front Shields
Air Conditioning
Heating Unit
Hydraulic Valve
Gearbox Upper Cover
Lift Cylinder
Lift Connection
Trailer Hitch
Hi Confort
Cardan Of Pump
Adhesives (Spanish)
Adhesives (English)
