Challenger Tractor WT540B Parts Catalog VBWT540B
Brand: Challenger
Model: Challenger WT540B Tractor
Part Number: VBWT540B
Number of Pages: 292 Pages
Flywheel And Housing
Valve Mechanism
Crankshaft Mechanism
Front Cover
Sump
Inlet And Exhaust Manifold
Muffler And Instalation Air Filter
Side Muffler
Turbocharger
Air Filter
Sedimentation Filter
Throttle System
S1
Gasket Set S1 + S2
Engine Repair Kit
Iskra
Alternator Iskra 55a- Platform
Alternator Iskra 120a- Cab
Upper Electrical System
Rear Eletrical System Cab
Instruments
Lights
Front Eletric System
Front Window Wiper
Battery And Support
Radio
Rear Window Wiper And Washer
Fog Light (Optional)
Light Number Plate (Optional)
Single Clutch
Double Clutch
Single Clutch Control
Double Clutch Control
Gearbox Housing
Countershaft, Mainshaft, Bevel Pinion Shaft(Hd)
Gearbox Cooling
Levers Housing
Range And Speed Gear Levers
Gearbox Speed Multiplyer
Power Take Off 540 Rpm
Pto Lever System
Service Brake Control Drive
Control Brake System
Final Drives And Brakes
Differential Lock Drive
Steering Wheel And Column
Steering Wheel And Adjustable Column
Hydraulic Steering
Hydrostatic Steering Unit Danfoss
Frame And Bearing Of Front Axle Carraro
Articulation Housing Carraro 20.43up-Pcr
Flange, Bevel Gear And Pinion Carraro-Pcr
Double Joint Carraro-Pcr
Planetary Gear Housing Carraro-Pcr
Carraro-Pcr
Front Drive Selecting
Cardan Shaft
Front Drive Selecting Lever
Front Wheel 4 X 4
Rear Wheel
Rear Wheel (Optional)
Double Rear Wheel
Buffer And Front Counterweight
Rear Wheel Counterweight (Tyre 18.4 And 20.8 )- Accessory
Accessory
Rear Whell Counterweight (Tyre 24.5)
Roof
Cab Frame
Door And Glass Of The Cab
Front Glasses
Rear Window And Glass Of The Cab
Windscreen
Insulating And Coating For Cab
Front Mudguards
Rear Mudguard
Seat (Part 1)
Seat (Part 2)
Seat (Part 3)
Seat For Cab (Part 1) Optional
Seat For Cab (Part 2) Optional
Seat For Cab (Part 3) Optional
Instruments Panel
Plataform
Front Shields
Safety Frame And Roof (Optional )
Air Conditioning
Heating Unit
Intern Rear View Mirror
Hydraulic Pump And Pipe System
Hydraulic Valve
Gearbox Upper Cover
New Hydraulic Lever System
Directional Control Valves Levers
Lift Cylinder
Upper Link Rod And Pecker Lift
Lift Connection
Ball Pin Traction Kit
Auxiliary Lift Cylinder
Auxiliary Cylinder D=76,2mm
Trailer Hitch
Planting Implement Kit
Sugar Cane Implement With Motor
Sugar Cane Implement Without Motor
Cardan Of Pump
Hydraulic Oil Container
Eletronic Hilift
Eletronic Hilift Overflow
Assembled Eletrical Ehrb
Common Hilift
Spanner
Adhesives (Portuguese)
Adhesives (Spanish)
Adhesives (English)
