Challenger Tractor WT540 Parts Catalog VBWT540
Brand: Challenger
Model: Challenger WT540 Tractor
Part Number: VBWT540
Number of Pages: 313 Pages
Flywheel And Housing
Valve Mechanism
Crankshaft Mechanism
Front Cover
Sump
Air Filter
Inlet And Exhaust Manifold
Muffler And Instalation Air Filter
Turbocharger
Sedimentation Filter
Throttle System
S1
Gasket Set S1 + S2
Engine Repair Kit
Bosch
Iskra
90a
Rear Eletrical System For Cab
Rear Eletrical System Cab
Magnet
Lights
Panel Eletric System
Front Eletric System
Rotating Light (Optional )
Radio (Optional )
Windscreen Wiper And Washer
Rear Window Wiper And Washer
Rear Fog Light (Optional)
Light Number Plate (Optional )
Single Clutch
Double Clutch
Clutch Control
Double Clutch Control
Gearbox Housing And Shift Levers
Gearbox Housing
Countershaft, Mainshaft, Bevel Pinion Shaft(Hd)
Gearbox Cooling
Levers Housing
Range And Speed Gear Levers
Gearbox Speed Multiplyer
Power Take Off 540 Rpm
Pto Lever System
Service Brake Control Drive
Control Brake System
Final Drives And Brakes
Differential Lock Drive
Steering Wheel And Column
Steering Wheel And Adjustable Column
Hydraulic Steering
Hydrostatic Steering Unit Danfoss
Frame And Bearing Of Front Axle Carraro
Articulation Housing Carraro 20.43up-Pcr
Flange, Bevel Gear And Pinion Carraro-Pcr
Double Joint Carraro-Pcr
Planetary Gear Housing Carraro-Pcr
Carraro-Pcr
Front Drive Selecting
Cardan Shaft
Frame, Bearing And Cardan
4wd Zf Apl-359
Swivel Housing Planetary Gear 4wd Zf Apl 359
Steering Cylinder And Arm 4wd Zf Apl-359
Front Wheel 4 X 4
Rear Wheel
Rear Wheel (Optional)
Double Rear Wheel
Buffer And Front Counterweight
Rear Wheel Counterweight (Tyre 18.4 And 20.8 )- Accessory
Accessory
Rear Whell Counterweight (Tyre 24.5)
Roof
Open Cab
Cab Frame
Door And Glass Of The Cab
Rear Window And Glass Of The Cab
Windscreen
Insulating And Coating For Cab
Cab Insulator
Muldguards And Plate Floor
Front And Rear Mudguards
Front And Rear Mudguards- Axle Zf359
Front And Rear Mudguards- Carraro
Seat (Part 1)
Seat (Part 2)
Seat (Part 3)
Seat For Cab (Part 1) Optional
Seat For Cab (Part 2) Optional
Seat For Cab (Part 3) Optional
Instruments Panel
Front Shields
Safety Frame And Roof (Optional)
Air Conditioning
Heating Unit
Hydraulic Pump And Pipe System
Hydraulic Valve
Gearbox Upper Cover
New Hydraulic Lever System
Lift Cylinder
Upper Link Rod And Pecker Lift
Lift Connection
Auxiliary Lift Cylinder
Auxiliary Cylinder D=65mm
Auxiliary Cylinder D= 80mm
Auxiliary Cylinder D=76,2mm
Directional Control Valve
Trailer Hitch
Planting Implement Kit
Sugar Cane Implement With Motor
Sugar Cane Implement Without Motor
Sugar Cane Implement With Motor-Hi-Confort
Sugar Cane Implement Without Motor- Hi-Confort
Hi Confort
Cardan Of Pump
Spanner
Standard (Portuguese)
Standard (Spanish)
Standard (English)
