Challenger Tractor WT490B Parts Catalog VBWT490B
Brand: Challenger
Model: Challenger WT490B Tractor
Part Number: VBWT490B
Number of Pages: 250 Pages
Flywheel And Gear Rim
Valve Mechanism
Crankshaft Mechanism
Gear Housing
Engine Oil Cooler
Sump
Air Filter
Inlet And Exhaust Manifold
Muffler
Turbocharger
Instalation Air Filter
Intercooler System
Sedimentation Filter
Feed Pump And Fuel Filter
Throttle System
Water Pump And Fan
Gasket Set S1
Gasket Kit S1 + S2
Repair Kit
Iskra
Alternator Iskra 55a- Platform
Alternator Iskra 120a- Cab
Upper Electrical System
Rear Eletrical System For Cab
Instruments
Lights
Front Eletric System
Front Window Wiper
Radio
Rear Window Wiper And Washer
Fog Light (Optional)
Light Number Plate (Optional)
Clutch
Housing Gear Box And Drive System
Gear Shift Levers
Countershaft
Mainshaft
Bevel Conical Pinion Shaft
Bevel Conical Pinion Shaft (Tab)
Transmission Differential
Valve Plate
Transmission Cooling
Multitorque Control
Shift On The Go Under Drive
Redutor Creeper
Creeper
Drive Level- Creeper
Power Take Off 540 Rpm
1000 Rpm
Power Take Off 540 Rpm Proporcional
Rear Housing And Pto Lever
Rear Cover
Final Drive
Differential Lock Drive
Brake Control Drive
Control Hand Brake
Steering Wheel And Column
Steering Wheel And Adjustable Column
Hydraulic Steering (4x4)
Hydrostatic Steering Unit Danfoss
Front Drive Selecting Lever
Front Axle Casing Zf As3050
Zf As3050
Multitorque
Front Wheel (4x4)
Rear Wheel
Rear Wheel (Optional)
Double Rear Wheel 13.6 X 38, 14.9 X 28
Buffer And Front Counterweight
Rear Wheel Counterweights (Tyre 18.4 X 34,18.4 X 30 And 13.6 X 38) )
Rear Whell Counterweights (Tyre 23.1 X 26 E 23.1 X 30))
Accessory
Roof
Cab Frame
Door And Glass Of The Cab
Front Glasses
Rear Window And Glass Of The Cab
Windscreen
Insulating And Coating For Cab
Seat (Part 1)
Seat (Part 2)
Seat (Part 3)
Front Mudguards
Rear Mudguard
Instruments Panel
Front Wheel
Plataform
Safety Frame And Roof (Optional )
Air Conditioning (Optional)
Heating Unit
Intern Rear View Mirror
Hydraulic Pump And Pipe System
Lift Arm
By-Pass And Pressure Relief Valve
Hydraulic Control Levers And Control
Upper Link Rod And Sensitivity System
Lift Connection And Stabilizer
Lift Cylinder
New
Trailer Hitch
Toll's Box
Adhesives (Portuguese)
Adhesives (Spanish)
Adhesives (English)
Brand: Challenger
Valve Mechanism
Gear Housing
Engine Oil Cooler
Sump
Air Filter
Muffler
Turbocharger
Intercooler System
Throttle System
Water Pump And Fan
Gasket Set S1
Gasket Kit S1 + S2
Repair Kit
Iskra
Instruments
Lights
Front Window Wiper
Radio
Clutch
Gear Shift Levers
Countershaft
Mainshaft
Valve Plate
Multitorque Control
Redutor Creeper
Creeper
1000 Rpm
Rear Cover
Final Drive
Brake Control Drive
Control Hand Brake
Zf As3050
Multitorque
Front Wheel (4x4)
Rear Wheel
Accessory
Roof
Cab Frame
Front Glasses
Windscreen
Seat (Part 1)
Seat (Part 2)
Seat (Part 3)
Front Mudguards
Rear Mudguard
Instruments Panel
Front Wheel
Plataform
Heating Unit
Lift Arm
Lift Cylinder
New
Trailer Hitch
Toll's Box
Adhesives (Spanish)
Adhesives (English)
