Challenger Tractor WT470 Parts Catalog VBWT470
Brand: Challenger
Model: Challenger WT470 Tractor
Part Number: VBWT470
Number of Pages: 273 Pages
Flywheel And Gear Rim
Valve Mechanism
Crankshaft Mechanism
Gear Housing
Engine Oil Cooler
Sump
Air Filter
Inlet And Exhaust Manifold
Muffler
Turbocharger
Instalation Air Filter
Sedimentation Filter
Feed Pump And Fuel Filter
Throttle System
Water Pump And Fan
Gasket Set S1
Gasket Kit S1 + S2
Repair Kit
Bosch
Iskra
55a
90a
Rear Eletrical System For Cab
Instruments
Lights
Panel Eletric System
Front Eletric System
Radio (Optional )
Front Window Wiper And Washer (Optional)
Rear Window Wiper And Washer
Rear Fog Light (Optional)
Light Number Plate
Clutch
Housing Gear Box And Drive System
Gear Shift Levers
Countershaft
Mainshaft
Bevel Conical Pinion Shaft
Bevel Conical Pinion Shaft (Tab)
Transmission Differential
Valve Plate
Transmission Cooling
Multitorque Control
Shift On The Go Under Drive
Power Take Off 540 Rpm
1000 Rpm
Power Take Off 540 Rpm Proporcional
Rear Housing And Pto Lever
Rear Cover
Final Drive
Differential Lock Drive
Brake Control Drive
Steering Wheel Column
Hydraulic Steering (4x4)
Hydrostatic Steering Unit Danfoss
Front Drive Selecting Lever
Front Axle Dana (4x4)
Dana
Differential Dana
Apl 350
Front Drive Axle Zf Apl350
Axle Zf Apl350
Front Axle Casing Zf As3050
Zf As3050
Multitorque
Front Wheel (4x2)
Front Wheel (4x4)
Rear Wheel
Rear Wheel (Optional)
Double Rear Wheel 13.6 X 38, 14.9 X 28
Buffer And Front Counterweight
Rear Wheel Counterweights (Tyre 18.4 X 34 E 18.4 X 38)
Rear Wheel Counterweights (Tyre 18.4 X 34,18.4 X 30 And 13.6 X 38) )
Rear Whell Counterweights (Tyre 23.1 X 26 E 23.1 X 30))
Accessory
Roof
Cab Frame
Door And Glass Of The Cab
Windscreen
Rear Window And Glass Of The Cab
Cab Insulator
Insulating And Coating For Cab
Seat (Part 1)
Seat (Part 2)
Seat (Part 3)
Instruments Panel
Open Cab
Front Shields
Safety Frame And Roof (Optional )
Air Conditioning (Optional)
Heating Unit
Hydraulic Pump And Pipe System
Pcr
Lift Arm
By-Pass And Pressure Relief Valve
Hydraulic Control Levers And Control
Upper Link Rod And Sensitivity System
Lift Connection And Stabilizer
Lift Cylinder
Antique
New
Trailer Hitch
Toll's Box
Adhesives (Spanish)
Adhesives (English)
Adhesives (Portuguese)
Brand: Challenger
Valve Mechanism
Gear Housing
Engine Oil Cooler
Sump
Air Filter
Muffler
Turbocharger
Throttle System
Water Pump And Fan
Gasket Set S1
Gasket Kit S1 + S2
Repair Kit
Bosch
Iskra
55a
90a
Instruments
Lights
Radio (Optional )
Light Number Plate
Clutch
Gear Shift Levers
Countershaft
Mainshaft
Valve Plate
Multitorque Control
1000 Rpm
Rear Cover
Final Drive
Brake Control Drive
Dana
Differential Dana
Apl 350
Axle Zf Apl350
Zf As3050
Multitorque
Front Wheel (4x2)
Front Wheel (4x4)
Rear Wheel
Accessory
Roof
Cab Frame
Windscreen
Cab Insulator
Seat (Part 1)
Seat (Part 2)
Seat (Part 3)
Instruments Panel
Open Cab
Front Shields
Heating Unit
Pcr
Lift Arm
Lift Cylinder
Antique
New
Trailer Hitch
Toll's Box
Adhesives (Spanish)
Adhesives (English)
