Challenger Tractor WT450B Parts Catalog VBWT450B
Brand: Challenger
Model: Challenger WT450B Tractor
Part Number: VBWT450B
Number of Pages: 240 Pages
Flywheel And Gear Rim
Valve Mechanism
Crankshaft Mechanism
Gear Housing
Engine Oil Cooler
Sump
Air Filter
Inlet And Exhaust Manifold
Muffler
Instalation Air Filter
Oil Pan Protector
Sedimentation Filter
Feed Pump And Fuel Filter
Throttle System
Water Pump And Fan
Gasket Set S1
Gasket Kit S1 + S2
Repair Kit
Iskra
Alternator Iskra 55a- Platform
Alternator Iskra 120a- Cab
Upper Electrical System
Rear Eletrical System For Cab
Instruments
Lights
Front Eletric System
Front Window Wiper
Radio
Rear Window Wiper And Washer
Fog Light (Optional)
Light Number Plate (Optional)
Clutch
Housing Gear Box And Drive System
Gear Shift Levers
Countershaft
Mainshaft
Bevel Conical Pinion Shaft
Bevel Conical Pinion Shaft (Tab)
Transmission Differential
Valve Plate
Transmission Cooling
Multitorque Control
Shift On The Go Under Drive
Redutor Creeper
Creeper
Drive Level- Creeper
Power Take Off 540 Rpm
1000 Rpm
Power Take Off 540 Rpm Proporcional
Rear Housing And Pto Lever
Rear Cover
Final Drive
Differential Lock Drive
Brake Control Drive
Control Hand Brake
Steering Wheel And Column
Hydraulic Steering (4x2)
Steering Wheel And Adjustable Column
Hydraulic Steering (4x4)
Hydraulic Steering 4x2 E 4x4
Hydraulic Steering- Pcr
Hydrostatic Steering Unit Danfoss
Front Axle Support
Front Axle With Steering Cylinder
Front Drive Selecting Lever
Frame And Bearing Of Front Axle Carraro-Pcr
Articulation Housing Carraro 20.43up-Pcr
Flange, Bevel Gear And Pinion Carraro-Pcr
Double Joint Carraro-Pcr
Planetary Gear Housing Carraro-Pcr
Carraro-Pcr
Apl 350
Front Axle Casing Zf As3050
Zf As3050
Multitorque
Pcr
Front Wheel (4x2)
Front Wheel (4x4)
Rear Wheel
Rear Wheel (Optional)
Double Rear Wheel 13.6 X 38, 14.9 X 28
Buffer And Front Counterweight
Rear Wheel Counterweights (Tyre 18.4 X 34 E 18.4 X 38)
Rear Wheel Counterweights (Tyre 18.4 X 34,18.4 X 30 And 13.6 X 38) )
Rear Whell Counterweights (Tyre 23.1 X 26 E 23.1 X 30))
Accessory
Front Glasses
Seat (Part 1)
Seat (Part 2)
Seat (Part 3)
Instruments Panel
Front Wheel
Air Conditioning (Optional)
Hydraulic Pump And Pipe System
Hydraulic Control Levers And Control
Toll's Box
Adhesives (Portuguese)
Adhesives (Spanish)
Adhesives (English)
Brand: Challenger
Valve Mechanism
Gear Housing
Engine Oil Cooler
Sump
Air Filter
Muffler
Oil Pan Protector
Throttle System
Water Pump And Fan
Gasket Set S1
Gasket Kit S1 + S2
Repair Kit
Iskra
Instruments
Lights
Front Window Wiper
Radio
Clutch
Gear Shift Levers
Countershaft
Mainshaft
Valve Plate
Multitorque Control
Redutor Creeper
Creeper
1000 Rpm
Rear Cover
Final Drive
Brake Control Drive
Control Hand Brake
Front Axle Support
Carraro-Pcr
Apl 350
Zf As3050
Multitorque
Pcr
Front Wheel (4x2)
Front Wheel (4x4)
Rear Wheel
Accessory
Front Glasses
Seat (Part 1)
Seat (Part 2)
Seat (Part 3)
Instruments Panel
Front Wheel
Toll's Box
Adhesives (Spanish)
Adhesives (English)
