Challenger Tractor WT390 Parts Catalog VBWT390
Brand: Challenger
Model: Challenger WT390 Tractor
Part Number: VBWT390
Number of Pages: 264 Pages
Flywheel And Gear Rim
Gear Housing
Valve Mechanism
Crankshaft Mechanism
Oil Filter
Sump
Air Filter
Inlet And Exhaust Manifold
Tier Ii
Muffler
Turbocharger
Sedimentation Filter
Usa
Throttle System
Fuel Pipes
Water Pump And Fan
Gasket Set S1
Gasket Kit S1 + S2
Repair Kit
Bosch
Iskra
90a
Instruments Panel
Working Headlight (Optional )
Light Number Plate (Optional Equipment)
Rear Fog Light (Optional )
Double Clutch Luk
Clutch Cover And Pedal
Pto Drive Lever
Gearbox Housing
Gear Shift Levers
Mainshaft
Countershaft And Front Drive Axle
Countershaft And Front Shaft
Bevel Conical Pinion Shaft
Bevel Conical Pinion Shaft(272)
Transmission Differential
Lock Differential Lever
Lubrication System
Gearbox Cooling
Creeper
Spliter
Unit
Drive Lever Shuttle-Unit
Power Take Off
Final Drive
Parking Brake Control
Brakes
Brake Control Drive
Steering Wheel Column
Hydraulic Steering
Hydrostatic Steering Unit Danfoss
Front Axle
Steering Cylinder
Front Drive Selecting Lever
Cardan Propeller Shaft
Front Axle 4wd Zf Apl-335
4wd Zf Apl-335
Drive Shaft 4wd Zf Apl-335
Planetary Gear Housing 4wd Zf Apl-335
Bevel Pinion Shaft 4wd Zf Apl-335
Differential 4wd Zf Apl-335
Steering Cylinder 4wd, Zf Apl-335
Front Mudguards (Optional) 4wd Zf
Fuel Tank And Hydraulic Tank
Buffer And Suport Engine
Buffer And Front Counterweight (Optional)
Front Wheel
28 R2
Rear Wheel Tyres 16.9-30, 18.4-34, 13.6-38, 18.4-3r1, 18.4-30r2
Rear Wheel Tyres 23.1-26r1, 23.1-26r2)
Rear Whell Counterweights (Tyre 18.4 X 30 And 18.4 X 34)
Rear Whell Counterweights (Tyre 18.4 X 34 , 18.4 X 38)
Rear Whell Counterweights (Tyre 23.1 X 26)
Rear Whell Counterweights (Tyre 18.4 X 34 E 18.4 X 38)
Rear Shields
Seat (Part 1)
Seat (Part 2)
Front Shields
Safety Frame And Roof (Optional Equipment)
Rear View Mirror (Optional)
Hydraulic Pump And Suction Filter
Hydraulic Pipes System
Hydraulic Valve
Lift Arm
Lift Cylinder
Auxiliary Cylinder
Hydraulic Lever System
Three Points System Stabilizer
Upper Link Rod And Lift Connection
Trailer Hitch
Double Action Valve
2 Double Action Control Valve
3 Double Action Control Valve
Control Valves Levers
Trailer Hitch Tier Ii
Spanner
Adhesives (Portuguese)
Adhesives (Spanish)
Adhesives (English)
Adhesives (Usa)
Adhesives ( Inglês)
Brand: Challenger
Gear Housing
Valve Mechanism
Oil Filter
Sump
Air Filter
Tier Ii
Muffler
Turbocharger
Usa
Throttle System
Fuel Pipes
Water Pump And Fan
Gasket Set S1
Gasket Kit S1 + S2
Repair Kit
Bosch
Iskra
90a
Instruments Panel
Double Clutch Luk
Pto Drive Lever
Gearbox Housing
Gear Shift Levers
Mainshaft
Lubrication System
Gearbox Cooling
Creeper
Spliter
Unit
Power Take Off
Final Drive
Brakes
Brake Control Drive
Hydraulic Steering
Front Axle
Steering Cylinder
4wd Zf Apl-335
Front Wheel
28 R2
Rear Shields
Seat (Part 1)
Seat (Part 2)
Front Shields
Hydraulic Valve
Lift Arm
Lift Cylinder
Auxiliary Cylinder
Trailer Hitch
Double Action Valve
Spanner
Adhesives (Spanish)
Adhesives (English)
Adhesives (Usa)
Adhesives ( Inglês)
